Welcome to the North American Subaru Impreza Owners Club Tuesday April 20, 2021
Old 08-11-2020, 12:12 AM   #451
iRishman514
Member#: 378501
2011 STI Hatch
Plasma Blue Pearl
Originally Posted by Scargod View Post
The return line, which has the restrictor and/or check valve is not a "suction hose". Where there is suction is the large (I believe 5/8") feed hose from the reservoir to the pump.
I'm going to see if I can find my return hose and clear this up once and for all. I think I kept that section.
Iím thinking if the restrictor creates a back pressure though the rack, this might help with the pump whine as right now the fluid flows too quickly to the reservoir.
iRishman514 is offline   Reply With Quote
Old 08-22-2020, 10:52 AM   #452
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
Well, this weekend was the true test.... Since my last track day (May 24th) when all hell broke lose, I did the following mods:
'15 STi Rack
CSF Racing aluminum radiator/oil cooler kit
Mishimoto sandwitch plate
Whiteline Roll Center Kit
Whiteline 24mm front/rear swaybars
Whiteline front/rear HD Endlinks
Whiteline RSB HD mount kit
Full gauge install (EGT, Oil pressure, Oil Temp, Water Temp, Voltage (considering fuel pressure, but have a tiny battery and I'd like to know the voltage)
The car ran great! I did have some weird steering issues, which I think are still due to my underpowered PS pump. The shuddering was mostly gone except under rapid steering input changes. The most important thing is the car...just...turns... I thought the car was neutral before (mid corner if I got on the gas it would understeer, and if I let off it would start to oversteer), but now... it just turns. It's incredibly neutral and even when I get on the gas it keeps on the same line.
Thanks to everyone in this thread that helped and/or gave some support even when SHTF and I was kinda done working on the car (in the 100+ CA heat). But this weekend made it worth it.
Now on to my next project....brakes, which I now desperately need.
DDMan is offline   Reply With Quote
Old 08-22-2020, 11:19 AM   #453
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
The track is definitely the true test of the car and how all you've done to it makes it handle close to it's limits. It makes you really appreciate all you've done to the car and love the car even more. Glad things worked out for you.
REX_WGN is offline   Reply With Quote
Old 08-23-2020, 08:02 AM   #454
Scargod
Member#: 260314
2007 STI
silver gray metallic
'15 STi Rack
... The most important thing is the car...just...turns... I thought the car was neutral before (mid corner if I got on the gas it would understeer, and if I let off it would start to oversteer), but now... it just turns. It's incredibly neutral and even when I get on the gas it keeps on the same line...
I've gathered that this is an '02 2.5RS that you have had coilovers on but kinda looks like you went back to struts?
What wheels and tires? It's great that it is neutral. You say "track day", but all I can tell is that you have been doing autocross for many years. It being neutral while autocrossing is quite a feat! What is your whole suspension package? I have an '07 I'm preparing, and we might like to know your secrets!
Scargod is offline   Reply With Quote
Old 09-02-2020, 02:00 PM   #455
joshoohahh
Member#: 506078
EDITED - Turns out the Heidts fitting I bought had bad threads, got a new one sent out and it went right in.
Having a bit of trouble here...
I purchased a used 2019 STI power steering pump and the Heidts power steering fitting PS-030 but it doesn't want to thread into my power steering pump. Did the threads change on the newer pumps or something? I looked up the part number for the banjo bolt and it shows that they fit 04-20 STI's. Anyone know what the problem could be?
joshoohahh is offline   Reply With Quote
Old 09-04-2020, 09:49 AM   #456
Scargod
Member#: 260314
2007 STI
Must have changed? Is it loose, won't go in or wrong thread pitch?
Question: Is the Heidt"s power steering fitting PS-030 steel or aluminum? They don't say.
Old 09-04-2020, 09:53 AM   #457
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
Old 09-19-2020, 05:44 PM   #458
rjwoods77
Member#: 336151
Originally Posted by kos View Post
121s still leak. Source: I am a Parts Manager and stock a few
We on our 3rd rack in my GF Sally's VA chassis TA car, and it's starting to weep after only 2 events since we had it replaced
Hey Kos,
Do the racks after the VA121's (VA130,VA131,VA140 & VB010) have the same leak issues? The Valve Steering Gear Box on the 2015-17 racks is 34113VA001 while the 2018+ is 34113VA031 so there is some sort of change that might be related to the "spool area" you mentioned. I know that the 2018+ changed the OTR and Clamp Gear Box Pinion...
https://forums.nasioc.com/forums/sho...postcount=1322
...of which the OTR cost difference is negligible where as the Clamp Gear Box Pinion isn't. The Clamp Gear Box Pinion on the 2015-2017 rack is 34166AG030 at $6.30 MSRP and the 2108+ is 34166VA030 at $100.70 MSRP. The 2015-2017 racks are 716.45 MSRP while the 2018+ racks is 999.96 MSRP. I wonder if the Valve Steering Gear Box change along with the stiffer Clamp Gear Box Pinion on the 2018+ racks solved the leaking issue along with increasing the cost of the rack. I was about to buy the VA121 and am now wondering it paying the extra $283.51 MSRP for a 2108+ is worth it to avoid any future leakage problems on my project car.
rjwoods77 is offline   Reply With Quote
Old 09-19-2020, 07:21 PM   #459
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
Originally Posted by rjwoods77 View Post
Hey Kos,
...of which the OTR cost difference is negligible where as the Clamp Gear Box Pinion isn't. The Clamp Gear Box Pinion on the 2015-2017 rack is 34166AG030 at $6.30 MSRP and the 2108+ is 34166VA030 at $100.70 MSRP. That the 2015-2017 racks are 716.45 999.96 MSRP while the 2018+ racks is 999.96 MSRP. I wonder if the Valve Steering Gear Box change along with the stiffer Clamp Gear Box Pinion on the 2018+ racks solved the leaking issue along with increasing the cost of the rack. I was about to buy the VA121 and am now wondering it paying the extra $283.51 MSRP for a 2108+ is worth it to avoid any future leakage problems on my project car.
Great research. Please keep us posted.
Old 09-24-2020, 03:56 PM   #460
rjwoods77
Member#: 336151
Hey all,
So I managed to find out some more information from a motorsport friendly dealership about the 2018+ 13:1 rack and pinions. They have a different computer system that shows the exact models these come on so trusting the "what it fits" section in online sources isn't completely 100 percent. The 34110VB010 is for the WRX STI S209 of which they only sell to people that own one. The 34110VA140 is for the WRX STI Type RA of which anyone can buy. The 34110VA131 (supersedes 34110VA130) is for the WRX STi, WRX STi Limited and WRX STi Premium of which anyone can buy. We couldn't find any individual part differences between these three models so they might actually be the same but labelled differently for maintaining a controlled quantity of replacements for the limited production runs of the S209 and Type RA. An important dealer visible quantity exists for each of these which is called UIO (Units In Operation). The 34110VA131 has much larger UIO than the other two therefore it would makes sense to use that one out of all the 2018+ racks in case it has to be replaced down the line even though they all cost the same. I am going to take a chance on the idea that the Subaru fixed the leaky Valve Steering Gear Box on the 2015-2017 models (34113VA001) in the 2018+ plus models (34113VA031) to justify paying the extra $283 USD MSRP in hopes that I will never have an issue with it. I would love to hear from Kos in the future to validate or correct any of this.
Old 09-24-2020, 04:53 PM   #461
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
Hey all,
Wow, great detective work!
car_freak85 is offline   Reply With Quote
Old 09-25-2020, 10:54 AM   #462
kos
Member#: 118334
2006 Red GDA-F
2005 Aspen White GDA-E
I started to type a reply yesterday after reading my PM, but then got busy here at work and forgot
Hey Kos,
I have only sold 2 of the 2018+ STi rack under warranty, but heaps of the 2015-2017, granted we have had many more UIO of the 15-17 models, so we'll have to watch this space and see how it goes on 18+.
Hey all,
FWIW, I would never trust these online parts' site catalogs for drilling down to what you need specifically, as it's just a glimmer of what the actual Subaru Parts Catalog is. Yes, the prices are almost always cheaper online, but you may have to factor in shipping and tax, not to mention you're just ordering off a site, and hoping that site is correct. You're not dealing with a Parts Person to ensure what you're getting is correct (if they're a good parts person ), plus you'll have to ship it back if incorrect, etc, so sometimes it is worth it to pay a little more to work with a local Dealer, as well as building rapport, which could help with pricing in the future
Now that's out of the way, you've done some good research, and are correct in the fact that S209 parts are indeed VIN locked.
I too would like to think that the 18+ rack has "solved the issue," so it might be worth it to buy and try, you may be pleasantly surprised.
kos is offline   Reply With Quote
Old 09-25-2020, 11:26 AM   #463
rjwoods77
Member#: 336151
Hello Kos,
Thank you for the feedback. I always use this site...
https://parts.subaru.com/
...to get my part numbers from since I find it to be the most accurate. I then take that information to the dealer to order from them. They correct any errors I occasionally have but I find it best to come to them informed instead of having weird convos on the phone about some obscure little thing I am looking for. I have a Frankenstein of a car (1995 L Coupe with full 07 STi swap but using a EG33 instead of a EJ257 along with an 01 RS interior swap and rear mounted radiator) so i've learned to avoid the "whats your VIN". I totally agree with you about ordering locally to avoid any issues and later shipping charges. I just ordered the VA131 and it's being mounted solid in a MooreSport front subframe so I think it will be a good test of the 2108+ for leaks.
Old 09-29-2020, 01:13 AM   #464
joshoohahh
Member#: 506078
Default spacers
so what did everyone use for spacers for their install?
Old 10-30-2020, 07:32 PM   #465
FATgc8
Member#: 98838
2005 STi
CGM
Default Install: 2015 STi 13:1 steering rack into a GD
I would also like to know the right spacers to use for mounting up the rack to the cross member. I got the two 3/8 spacers that was mentioned, but for some reason it doesnít really sit right using the factory four bolt bracket.
FATgc8 is offline   Reply With Quote
Old 11-02-2020, 12:04 PM   #466
Zeonic
Member#: 490131
2005 Impreza WRX
I figured that just getting the Front Subframe from TSS Fab and using the 15+ Steering Rack option would be better instead of trying to Frankenstein it, plus I get to shave weight and have more rigidity. I'm more worried about the plumbing and have been wondering if anyone has figured out the right combination to putting everything together with no issues.
Zeonic is offline   Reply With Quote
Old 01-06-2021, 03:20 PM   #467
Craig4g63
Member#: 217175
2003 WRX
I'm in process of getting parts for this swap on my 03 WRX sedan.
I've already ordered a TSS Fab subframe, 15 rack, ITR adapters, STI steering column coupler, and a few other items. I think I'm clear on what is needed for this part of the install.
I have decided to order an 08+ pump and 04 bracket as my existing pump has issues at the auto x at times already. Where I'm not clear is what lines/adapters I'll need for this part of the setup.
I assume the low pressure part will be similar, but what are those with the 08+ pump using for the high pressure setup?
Any input is appreciated.
Craig4g63 is offline   Reply With Quote
Old 01-06-2021, 10:50 PM   #468
MortonCharbo
Member#: 487057
2002 WRX Wagon
I did this on my 02 wagon a couple years ago. I used two IAG power steering lines. For adapters, I used a Russell 640830, and a 640820 at the rack end. I hope that helps.
I had a Chase Bays kit installed previously with my stock rack. That included an -an adapter for the pump, and also included the tank and fittings for that, so I'm not completely sure what all you might need there if you are using stock stuff.
MortonCharbo is offline   Reply With Quote
Old 01-07-2021, 10:32 AM   #469
Craig4g63
Member#: 217175
2003 WRX
This does help.
Does the 08+ pump use the same fitting at the stock pump to adapt to AN?
Old 01-07-2021, 10:35 AM   #470
Craig4g63
Member#: 217175
2003 WRX
This does help.
Does the 08+ pump use the same fitting as the stock pump to adapt to AN?
If so I think the IAG line comes with that adapter.
Old 01-07-2021, 10:35 AM   #471
Scargod
Member#: 260314
2007 STI
This does help.
Seems you are being pretty lazy.
https://forums.nasioc.com/forums/showpost.php?p=46376985&postcount=430
Old 01-07-2021, 11:50 AM   #472
MortonCharbo
Member#: 487057
2002 WRX Wagon
I wish you had that info up when I put my rack in. I used both of the Russell fittings you said not to, but my setup is a bit more complex(unnecessarily lol) than what you outlined. I'm assuming that's why my experience was different.
I understand you were talking to Craig, not me. Your info is probably better than what I could give him at this point. I highly recommend getting that MSI adapter to simplify things. I wish I had known about it when doing my install. Thanks for taking the time to put that together!
Old 01-07-2021, 02:13 PM   #473
Craig4g63
Member#: 217175
2003 WRX
"For some reason i can't open that doc. I just assumed the doc wasn't there anymore.
Does it have what i'm looking for in it. I can try opening it on another computer to see if that fixes my issue."
EDIT:
Okay, my phone opens your doc.
It doesn't indicate what pump you are using, I assume it's the 07? That should be the same fitting for my 03 pump but is the fitting the same for 08+ pump?
IAG doesn't indicate what fittings are included in their kit, I will assume it's the same you have listed and it's using a 6AN line?
Old 01-07-2021, 03:03 PM   #474
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
One of the parts on your list lol
murrdogg24 is offline   Reply With Quote
Old 03-22-2021, 03:36 PM   #475
racersky
Member#: 77817
2005 STI
What power steering pump are you guys running? I did the conversion for almost a year but feels like my 2005 pump is not strong enough for the 2015 rack
racersky is offline   Reply With Quote
