Welcome to the North American Subaru Impreza Owners Club Thursday April 22, 2021
Old 03-28-2020, 02:40 PM   #151
TylerHartman
Member#: 307597
1999 Legacy GT
JDM option Tiger stripe mats
Zero/Sports plate frame
Ended up getting a hold of my Dream Greddy/Trust Lip for the JDM Bumper (it happened to come pre-painted white, so been running it, temp)
Here are a few pics of the lip with other grills etc I have
Here's the Prova hood lip I also bought
Prova grille
Hipposleek Grille
Nightpager Catch can/Washer tank
TylerHartman is offline   Reply With Quote
Old 03-28-2020, 02:40 PM   #152
TylerHartman
Member#: 307597
1999 Legacy GT
I decided to Test Fit my SYMS Skirts after I got the front lip... Holy crap it looks good
APS 70mm Cold Air intake, I love the ARC look. But Pod Filter Succ is amazing
APS 3" Inlet
Got some Esams Turn Signal Mirrors to retrofit on
I worked on running the wire and rear tweeters of my second TX65C Kit for the rear. Still haven't wired them in or hooked up speakers
Old 05-10-2020, 02:50 AM   #153
TylerHartman
Member#: 307597
1999 Legacy GT
These are going to be out of order but here it goes
Installed Slash Rotor Covers and Spline lug nuts
also have my hipposleek/zerosports grill in currently with syms skirts. but they still need paint
installed a Zero/Sports badge on the M20TB pod
Old 05-10-2020, 02:52 AM   #154
TylerHartman
Member#: 307597
1999 Legacy GT
Now here's the spice
Got a big order from a dealer in japan right before covid got EMS shutdown
Re wrapped my Spec C Long runner Intake wiring harness (deletes TGV Plugs)
Got my V8/V9 Long runner coated along with APS Parts
Figured you know with No car meets or anything wildy fun to do.. May as well tear this thing down and finally get it done.. so that's what happened
Found the correct tank and rubber hose for v8/v9 tank
Installed the TurboSmart EWG
Replaced all the hoses under the Intake for the most part along with new bolts etc.. Ended up being the right move, Half of the PCV hoses cracked upon removal
Old 05-10-2020, 02:53 AM   #155
TylerHartman
Member#: 307597
1999 Legacy GT
Installed GDT Cyl4 ReRoute
APS SR/40 (GT2876R) installed along with Mamba SS Line kit
size difference (TD04HL VS APS SR/40) it very clear how big this thing is from the top and back
Pretty much done now, Had to cut up the HKS pipe to make it fit with the APS 70MM intake, etc.. Lots of little stuff I didn't picture
here's the list of the new part
All new hoses/bolts, All fuel lines in bay redone with Gates hose good for every biofuel up to 225psi. etc..
EJ207 V8/V9 Long runner
APS SR/40 Turbo with Mamba SS Line kit
APS 3" inlet Pipe
APS 70mm Cai
TurboSmart 40mm Gate
ID1050X Injectors
GDT Cyl4 Reroute
Grimmspeed MAF delete
Grimmspeed EWG stopper
Grimmspeed 3Port EBCS
STI Silicone turbo inlet
130Amp Tribeca Alternator
spent alot of time fixing all the hoses, crusty bolts etc.. Straighten out the Fins on IC a little and finally have the correct 08-14 Bracket IC mount now too. There's a few things left to do, but overall very happy with how it's looking and will be glad to be done with this part of the build for a bit to focus on other things
93 tune + e85 (flex fuel Via ECF-1 into rear 02 sensor with Carberry rom)
Working on tuning it right now, will post up some videos at some point in future.
Did Motul Gear300 75w-90 in my Transmission and holy crap it made the world of difference, Doing Mazda RX8 oil Filter/5w-40 oil/V9 Spec C oil cooler here soon
