Welcome to the North American Subaru Impreza Owners Club Saturday April 10, 2021
Old 12-05-2019, 10:36 AM   #1
OhThatHurt
Member#: 490876
2016 STI
Ice Silver Metallic
Default Stock Ride Height Measurement - 2015+ STI
I searched and can't find this info anywhere. Anyone have the front and rear fender to ground measurements a stock 2015+ STI?
OhThatHurt is offline   Reply With Quote
Old 12-05-2019, 03:35 PM   #2
mcursch88
Member#: 483138
2015 STI
Crystal black silica
if i am not mistaken, it will say in the car's manual. not sure which section though
mcursch88 is offline   Reply With Quote
Old 12-05-2019, 03:35 PM   #3
mcursch88
Member#: 483138
2015 STI
what are you trying to figure out?
Old 12-05-2019, 03:54 PM   #4
Jack
Add Lightness
Member#: 13699
2021 Building
It Better
I don't find it in the manual. They can be downloaded from Subaru's site easily and searched. Closest thing is overall height and ground clearance. I suppose the overall height could be used, then measure your own car and compare.
Old 12-05-2019, 04:13 PM   #5
OhThatHurt
Member#: 490876
2016 STI
Ice Silver Metallic
Trying to find stock height for original reference starting point. I have had a few different sets of aftermarket springs (RCS yellow and black) on the car and lost track of stock height. I just installed coilovers and want to verify what a 1" drop from stock would be.
Old 12-05-2019, 04:23 PM   #6
mcursch88
Member#: 483138
2015 STI
damn, i would take measurements from my car but i put 19s on it.
but i suppose some maths could be done to figure out what it would be with 18s
if i can remember, ill check it out tonight or tomorrow
Old 12-05-2019, 04:28 PM   #7
mcursch88
Member#: 483138
2015 STI
ahem...ground clearance (ride height) for stock 2015 STi is 4.9inches (road to bottom of rocker panels)
Old 12-05-2019, 04:38 PM   #8
OhThatHurt
Member#: 490876
2016 STI
Ice Silver Metallic
I did not know where the 4.9" reference point was. Is road to bottom of rocker panels a confirmed measurement?
Old 12-06-2019, 08:02 AM   #9
mcursch88
Member#: 483138
2015 STI
"Ground clearance is measured as the minimum distance between the lowest part of the vehicle and the road surface. Ride height is measured from the lowest hanging component of the vehicle i.e the subassembly or differential or chassis and the ground."
this is according to Gogle, and the 4.9" came from the manual. therefore, i am assuming it is the stock measurement
Old 12-06-2019, 10:19 AM   #10
OhThatHurt
Member#: 490876
2016 STI
Ice Silver Metallic
Ya, I get all that. And agree 4.9" is the stock clearance height. However I have never found any documentation that states the exact measuring point for the 4.9" stated height.
Anyway, reason I am asking for stock fender to ground height is because it is a easy measurement and accounts for front and rear difference.
Old 12-06-2019, 10:58 AM   #11
mcursch88
Member#: 483138
2015 STI
i agree. there is no definitive point of reference. it just says 4.9".
Old 12-07-2019, 05:16 PM   #12
OhThatHurt
Member#: 490876
2016 STI
Ice Silver Metallic
I received measurement form a 2020 STI. Ground to edge of fender, centered.
26.75" RF
26.75" RR
26.5" LF
26.5" LR
Anyone else have stock suspension measurements to compare?
Old 12-08-2019, 08:48 AM   #13
Norm Peterson
Member#: 498642
'19 WRX Ltd 6M dgm
'08 Mustang GT (the toy)
What you're looking for will be in the factory shop manual. And it will probably be defined from the axle center rather than the ground. That takes differences in tire diameter out of the equation.
Looking at the 2018 FSM for the STi, the front wheel arch height measured that way is 370 mm, and the rear wheel arch height is 362 mm. Both of those numbers have rather generous tolerances listed (+12mm / -24mm). It's on the alignment specifications page. I don't expect the 2016 to be different, but you should probably check to be sure.
Norm
Old 12-08-2019, 11:21 AM   #14
OhThatHurt
Member#: 490876
2016 STI
Ice Silver Metallic
Norm
Thanks for sharing your knowledge, Norm. This is incredibly useful information. It also addresses my suspicion that fender heights may very form car to car and/or side to side. I thought Subaru would have this info listed somewhere, but did not know where.
