Welcome to the North American Subaru Impreza Owners Club Sunday April 11, 2021
Old 03-03-2020, 02:04 PM   #1
frugalrhombus
Member#: 494291
2019 STI
Dark Gray
Default Cobb Ethanol Sensor going bad after a year
OK so I have a 2019 STI that I have been running flex fuel for about a year (still trying to track down a receipt to figure out exact date). A few times in the past few months I had an issue where I would start the car and the ethanol level would be reading 0.0 and I assume my tune was adjusting for that and it was idling around 15.5 AFR but it would fix itself by just turning the car off and waiting a few minutes and restarting it.
But yesterday it did it to me while I was driving on the highway, it went from 76% which is what I filled up at and spiked to 100% then dropped to 0.0 again. I immediately threw it in neutral and as I was coasting for somewhere to pull over it went back to normal.
I have been talking to a few people about this locally and they said that the ethanol sensor itself is actually just a GM sensor and its the rest of the kit that is made by Cobb. Does anyone know if this is true? I would rather not pay the $300 for a replacement from Cobb if it has been after a year and the warranty is over if it is going to take a **** after a year again.
Also if it is true does anyone have a part number?
frugalrhombus is offline   Reply With Quote
Old 03-03-2020, 02:05 PM   #2
frugalrhombus
Member#: 494291
2019 STI
Dark Gray
I should add that I do not believe it is the entire harness which several people have suggested because it is not throwing any codes, it is simply going down to 0.0 on both raw ethanol and final ethanol
Old 03-03-2020, 03:24 PM   #3
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Yeah it's just a gm sensor. Buy one from Cobb return the broken one clean her up good and get your money back.
spoolinsti05 is offline   Reply With Quote
Old 03-03-2020, 03:25 PM   #4
neg_matnik
Member#: 132389
From what I can see, it looks like GM uses at least 3 different sensors, all 3 at around $100.
Two of them are actually made by Continental and I'm not sure about the 3rd one.
Summit Racing 13577394, 13577379, 13577429.
neg_matnik is offline   Reply With Quote
Old 03-04-2020, 11:18 AM   #5
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
All you need to know is the resistance value of the Cobb and the GM if they're equal they will be interchangeable even if the plug is different.. just wire in the new plug.
Old 03-04-2020, 11:28 AM   #6
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Cobb should provide you with this info so you can test the sensor with a DVM
The gm info will be hard to get. You'd need a fsm. Or can go to the dealer and bring your DVM and test them right at the counter. To determine the sensor you need to buy.
Old 03-04-2020, 01:45 PM   #7
frugalrhombus
Member#: 494291
2019 STI
Dark Gray
They haven't told me anything yet but I can ask. They want me to get a log of when it is happening again but of course as soon as they told me what to capture in the log it hasn't happened again since lol
Old 03-04-2020, 02:50 PM   #8
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Lol ask them for the values on the sensor then test it. You might be getting some sort of interference also.
Old 03-04-2020, 05:28 PM   #9
djoye
Member#: 50072
2017 STI
https://www.amazon.com/dp/B01GQR9C5O...v_ov_lig_dp_it
The linked sensor was referenced on the Cobb site in the reviews from another person that had a failed sensor. This sensor supposedly can replace it.
djoye is offline   Reply With Quote
Old 02-26-2021, 10:35 PM   #10
Iwonthedeadpool
Member#: 522653
2007 Sti
Green
Default part number
having a similar issue with my 07 sti can anyone tell me or link me an interchangeable part number so i can buy a new sensor? ive tried searching and get overwhelmed with the different ones available. dont want to spend unnecessary money.
Iwonthedeadpool is offline   Reply With Quote
Old 02-26-2021, 11:26 PM   #11
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Dom 1.5xtr JJ tuned
This. They fixed the exact same issue with my build.
Dave D. is offline   Reply With Quote
