Welcome to the North American Subaru Impreza Owners Club Monday April 12, 2021
Old 02-22-2021, 02:57 PM   #1
GeoNV
Member#: 518830
2009 WRX
dark grey metallic
Default Finished building engine- throttle body makes noise
Hey, finished my engine build. started it for the first time last night. before I started it with the key on my throttle body was whining (kind of like a high pitch door buzzer from an old car). I read that that's not abnormal and will go away after starting it. It did change after I started it the first time- now with the key on it sounds almost like clicks and buzzes that remind me of electrical arcing. no smell, and no heat that I can feel- I can't hear it once the engine starts. Is this normal?
Checking the data logs the throttle sensor and motor seem to work fine- just the odd noise with the key on.
GeoNV is online now   Reply With Quote
Old 02-22-2021, 06:38 PM   #2
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
It's normal you can adjust the screw if you pull cover off tb and might fix that. Basically throttle isn't in trim. It's a servo. So once you figure out how to set trim the noise will go away.
spoolinsti05 is offline   Reply With Quote
Old 02-22-2021, 07:51 PM   #3
GeoNV
Member#: 518830
2009 WRX
dark grey metallic
Ah, thanks. Appreciate the input.
