Welcome to the North American Subaru Impreza Owners Club Sunday April 11, 2021
Old 02-24-2021, 12:22 PM   #1
Mindriddle
Member#: 491668
Default Short Block Replacement..CR question
In a nutshell, I acquired a refreshed block with new CP std size pistons, 8.2:1 CR, new Manley rods and new crank. This is going in my 08 WRX running E85 (car is already set for it) with the stock VF52 turbo. This will be mated with my stock D25 heads and everything else just transferred from the old engine with new seals, timing belt and pumps of course. With this setup, I was recommended a 1.1mm headgasket to bring the CR back to WRX, from what I read is 8.55:1. Is this correct?
Mindriddle is offline   Reply With Quote
Old 02-24-2021, 06:29 PM   #2
cboggess
Member#: 30804
87 Yugo
Red
Yes. That is correct. Tomei makes a 1.1.
cboggess is offline   Reply With Quote
Old 02-24-2021, 07:23 PM   #3
benflynn
Member#: 515308
Thinnest you could find if ur E85 all the time, I just built an 8:5 engine but would of gone 9.5:1 if I had planned it better. If I was running 93 Id leave it 8.2 and see how o liked it.
benflynn is offline   Reply With Quote
Old 02-24-2021, 09:13 PM   #4
Haevn
Member#: 495950
2011 WRX
let me know if you run a thicker head gasket and can't get your header to bolt up right if you run aftermarket. i have an iag closed deck block with .039 JE head gaskets and my aftermarket header wouldn't fit was like 1/8 to wide so i had to go back to stock header
Haevn is offline   Reply With Quote
Old 02-25-2021, 05:37 AM   #5
Mindriddle
Member#: 491668
The car has the flex kit so I will be using E85 for the most part and 93 occasionally. Would you still recommend having a bit higher CR? Possible goal after the engine is done is to upgrade the turbo, just depending on how happy I am with its performance with the stock VF52.
Old 02-25-2021, 05:39 AM   #6
Mindriddle
Member#: 491668
Still a debate whether ill be changing the stock header. Thanks for the heads up though.
Old 02-25-2021, 11:29 AM   #7
Jedi03
Member#: 491095
2009 STi Blue
I personally prefer higher compression...much better response and economy, many tuners have issues due to size of injectors needed to make this safe...the few I have done SR20 @ 9:1 and Honda at 10:1 were great...had to really throttle the boost to near nothing on the honda for multiple reasons the SR still running strong an getting 30 mpg on the highway
Jedi03 is offline   Reply With Quote
Old 02-25-2021, 02:27 PM   #8
Mindriddle
Member#: 491668
Hmm..ill keep this in mind when i start to buy all the supporting parts, aka headgasket. The car currently has 1050cc injectors and AEM high flow fuel pump.
