![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 30351
Vehicle:1999 GC8 STI V7 6spd Silver Coupe |
![]() I am looking at getting a set of Teins for my GC8 coupe. I have heard the Sti, WRX and the GC8 2.5rs share the same struts? Is this true? I would also like to know if the rear struts are adjustable at the lower body like AGX KYB(which I have, or do adjust at the top(which would really suck)? If so probabley have to go with the EDFC unit. I need to be able to road course with them, is the a model for street and road course, or all the same? Any help is needed(except sarcasm).
#2 |
Member#: 18978
SCIC
Vehicle:96 brighton 05 AP2 ,09 GE8 |
![]() yes, they are the same except the rear top hats. to use wrx ones, you would have to put gc rear top hats on the wrx coilovers
#3 |
Member#: 30351
![]() Don't they make GC STI top hats for for the front and rear?
#4 |
Member#: 18978
SCIC
![]() you have to be specific with which teins you're getting. tein ra's, ha's, ss, flex, hg, rs, re?what exactly are you asking? no stock struts have adjustments on them. also, which sti are you talking about? why do adjustments at the top suck? the only reason they have adjustments where they do is mostly because of the shock design(inverted vs non inverted. if you're going to take them on a road course, you might as well just get pillowball top hats
#5 |
Member#: 30351
![]() Well I really don't know the model design at all. Everybody I have talked to said to use the Teins. I need something from street to road course, which do you guys recommend. The rear adjustable tops, you have to remove your seat to adjust, whereas the AGX KYB can be adjusted underneath on the rear.
#6 |
Member#: 30351
![]() Do have model info? Do they come with front adustable camber plates?
#7 |
Member#: 62628
South East
Vehicle:MY99 Ver6 Type R aspen white |
![]() i am running WRX Tein Flexs with EDFC on my GC coupe. the WRX Flexs have both caster and camber adjustments so they offer the GC owner a little more adjustability at a cost-you have to trim the rear strut bar to fit the rear hats. kind of a pain, but well worth the added adjustment.
personally i wouldnt have anything else..........except Tein RAs or HAs. |
Suspension question for the 18 millionth time | MitchGT | Legacy Forum | 15 | 03-21-2005 02:56 PM |
Suspension Questions for the 2000 Legacy | Acejam2k | Legacy Forum | 6 | 10-15-2003 06:48 PM |
The ultimate suspension setup for the GC8 | Teh Legacy | Brakes, Steering & Suspension | 3 | 02-01-2003 02:01 AM |
suspension question for the master techs: bushing differences between FWD/AWD? | RaceCarRiot | Brakes, Steering & Suspension | 2 | 05-14-2002 09:08 AM |
Another suspension question for the class | gtguy | Legacy Forum | 3 | 11-06-2000 12:26 AM |
