Welcome to the North American Subaru Impreza Owners Club Sunday May 16, 2021
Old 08-02-2009, 07:16 PM   #1
undrgroundskat3r
Member#: 197274
2009 Impreza WRX
Default Broken Boost Gauge or Boost problems?
i just got my car back from the dealership after they put in new flywheel and my boost gauge reads nowhere near what it did.. usually it goes up to about 5psi at full throttle and about -6psi with no throttle now it goes to only -2psi at full throttle and still at -6psi sitting still... im not totally sure on this but when you turn off the car its supposed to go to 0 right? well it sits at -3 now when the cars off. Is it the guage or my engine?
undrgroundskat3r is offline   Reply With Quote
Old 08-02-2009, 07:54 PM   #2
Deserted1
Member#: 110902
2010 Toyota Tacoma
Super White
huh i would say theres an issue with where its hooked up.. you sure its psi and not bar? psi your not even boosting....
Deserted1 is offline   Reply With Quote
Old 08-02-2009, 08:16 PM   #3
undrgroundskat3r
Member#: 197274
2009 Impreza WRX
i dont even know the factory boost guage reads in "mPa" if thats what bar is... psi is like mPa x1.5 or something like that so im just guessing
where does the guage hook up at? somewhere near the turbo?
Old 08-02-2009, 09:32 PM   #4
96SubyImpreza
Member#: 157692
2004 WRX
"Big Red"
You should be running ~13.5 psi under WOT. check to make sure everything is hooked up correctly still before you jump to any conclusions.
96SubyImpreza is offline   Reply With Quote
Old 08-02-2009, 09:47 PM   #5
undrgroundskat3r
Member#: 197274
2009 Impreza WRX
is that stock boost?
Old 08-02-2009, 10:01 PM   #6
s0ber_p
Member#: 172689
2004 WRX
yes, and your vac should be around -20 depending on altitude. Sounds like you could have a leak in the hoses somewhere. Check out all the hoses for tears, or dry rot. I had a leak right at the base of my boost gauge line that was making read off. How is your idle?
edit- didn't see that it was reading off with the car not running...might even be a broken gauge, which one is it?
s0ber_p is offline   Reply With Quote
Old 08-02-2009, 10:21 PM   #7
undrgroundskat3r
Member#: 197274
2009 Impreza WRX
i think its Lamco or something... idle is rough when i first start the car.
Old 08-03-2009, 12:02 AM   #8
s0ber_p
Member#: 172689
2004 WRX
If the idle is indeed a bit rough, that would likely point to vac leak. But with the gauge reading that low with the engine off, if could even be a combo of both
WTB boost gauge or sideskirts or 06-07lip mcyyy123 SCIC Private Classifieds 3 07-23-2009 12:54 AM
WTB: Used stock boost gauge or other cheap boost gauge. cefu63 NWIC Private Classifieds 3 12-04-2006 02:16 PM
bad boost gauge or other problem? NETWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-07-2005 02:07 PM
Anyone have a factory boost gauge or gauge package for sale? Hokie-wrx wagon Mid Atlantic Impreza Club -- MAIC 1 05-19-2005 09:06 PM
Boost Gauge or TT? avsrule414 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-12-2002 11:00 AM
