Welcome to the North American Subaru Impreza Owners Club Tuesday May 18, 2021
Old 10-01-2009, 10:21 AM   #1
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
Default How many thousandths is .1 for the CR?
Ok Ive searched quite a bit on here and google. Perhaps I am not using the correct search terms...I dont know.
Anyhow, when shaving/ milling a cylinder head/ block how much does that increase the CR? How many thousandths off is 1/10th of a CR (.1)?
Many thanks to whomever can shed some light on this for me.
BlackJavaPearl04 is offline   Reply With Quote
Old 10-01-2009, 11:03 AM   #2
Turborider
Member#: 55885
I don't know if this will help but here it goes. Many Many years ago I used to race oval tracks. I used to run what chevy calls steel shim head gaskets. They are about 1-2 thousands thick (thickness of your thumb nail). It raised my compression from 9:1 to 9:9:1. Almost 10:1 but not quite. Now this is a small block chevy v8. I assume the actually raising of compression would also be related to bore size. With regular felpro head gaskets on a 8:1 small block chevy. With the heads shaved 30 thou. gives you about 11:1 comp. Like I said I don't know if it helps but its the best I can do.
Turborider is offline   Reply With Quote
Old 10-01-2009, 11:03 AM   #3
rjburner
Member#: 167014
2005 WRX
Crystal Grey Metallic
You have to calculate the CR for each engine. There is no .001 shaved off the head equals some increase in CR. You need to know bore, stroke, head gasket bore, head gasket thickness, combustion chamber volume, piston dish/dome, and piston to deck clearance. If you know all of these parameters then you just have plug them in.
rjburner is offline   Reply With Quote
Old 10-01-2009, 11:20 AM   #4
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
Yes i Know and understand that is the correct way to determine it. I am just looking for a general rule of thumb so to speak.
Im quite sure that there must be some general rule of thumb for say wrx Heads. Like for every .005-.006" is 3/10s of a 1 CR...this was given to me by someone and I'd like to see if anyone else has something similar to say.
The 02-05 wrx heads are 49 cc. But mine have been decked a few times. Just trying to see if i can approximate the increase in CR without having to cc and such.
Old 10-01-2009, 11:37 AM   #5
T_Racer69
Member#: 188079
2003 Stg 2 Bug Wagon
Sonic Yellow
I would think the only safe way would be to CC the heads. This can be done very cheaply, just for verification. Though, you may be able to run a thicker headgasket and keep the stock compression if that is what you are worried about.
I would call a head gasket manufacturer and ask them, maybe like Cometic and talk with a tech. Tell him what you have, what you are trying to do, and what products they have that may help you achieve that goal. This will at least give you a baseline of info, even if you don't use their stuff.
Travis
T_Racer69 is offline   Reply With Quote
Old 10-01-2009, 11:48 AM   #6
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
Thanks Travis, thought i could get a few quick common assumptions but I may as well just cc them to be sure... just remembered my mother works at an animal hospital she is going to get me a 60cc syringe....I certainly will figure it out for sure now. Ill report back with my findings to give other people an idea in the future
Old 10-02-2009, 04:25 PM   #7
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
look for an epic post by user sponaugle in which he details many of the parameters you're after.
Old 10-05-2009, 07:54 PM   #8
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
Thanks Ride, any key search terms i should use to ease the search?
BTW guys im getting 47.5-48 cc for the wrx heads...thats with .025-.030" taken off.
Old 10-05-2009, 08:48 PM   #9
elevenpoint7five
Member#: 187798
elevenpoint7five is offline   Reply With Quote
Old 10-05-2009, 08:50 PM   #10
elevenpoint7five
Member#: 187798
Old 10-05-2009, 11:15 PM   #11
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
Thanks Eleven, I think I found one of those threads not too long ago but Im actually just looking for an approximation or rule of thumb when milling/ decking your heads and block.
At this point I already went ahead and cc'd the combustion chamber. I have all the other parameters except for the piston to deck height which I will be getting soon. I really just need to see which thickness of HG to use.
How many miles is it apropriate for a new car to have on the odometer? urgewrx General Community 53 07-05-2006 07:11 PM
How many miles is too many for a used WRX? MitchGT General Community 25 12-10-2005 03:44 PM
How many threads is SubEd the 1st or 2nd responder for? rogue Off-Topic 15 07-08-2005 05:55 PM
How many evos are slated for the NE area? Mgardenier New England Impreza Club Forum -- NESIC 17 04-03-2003 10:11 PM
how many miles is normal off the truck? bdtaylor88 Newbies & FAQs 23 04-09-2002 01:54 PM
