Welcome to the North American Subaru Impreza Owners Club Friday May 14, 2021
Old 06-03-2010, 11:08 PM   #1
Jagular1785
Member#: 194452
The Mr.
Wizard
Default .010 oversize rings + factory piston... Yay or Nay?
I'm in the process of rebuilding a 95 legacy EJ22 to swap in for my 97 impreza outback EJ22. I just pulled the motor apart and checked the ring gap. It seems that with the new rings, I have .014" gap, where the manual calls for .005-.014". I was thinking of buying the first step of oversize rings which are .010" over (.25mm). Could I get by with using the factory piston with these rings? Should I have the block bored out to the full .010" over or could I leave it to what it is currently (I would guess that I am sitting at about .005" over as it sits). I don't really want to go buy pistons if I can avoid it safely.
Jagular1785 is offline   Reply With Quote
Old 06-04-2010, 01:37 AM   #2
mbtech
Member#: 215510
2001 2.5 RS
I've seen guys do this at shops I've worked at but if it were my car I would not especially if boosted
mbtech is offline   Reply With Quote
Old 06-04-2010, 07:23 AM   #3
toyjunkie
Member#: 177315
2004 sti
wrb
oh H**L no!
toyjunkie is offline   Reply With Quote
Old 06-04-2010, 11:23 AM   #4
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
Uh... you have a measured .014 in gap and the spec calls for .005 - .014 in gap. You are in spec, if nothing else is wrong install the rings and get on with it...
I should also add that if you are concerned about ring gap then you should do the due diligence and measure the bore for roundness a taper...
-soobaviator
soobaviator is offline   Reply With Quote
Old 06-06-2010, 01:45 AM   #5
Jagular1785
Member#: 194452
The Mr.
Wizard
Ok, general consensus is a nay, I'll go with that. But in doing more measurements, it looks more like a .013 or .012 overall on all cylinders. I'm guessing that I had the ring slightly crooked (I'm new at this, if you couldn't tell) and made the measurement off by a little bit. I'm just going to go with what I've got, standard rings and pistons, and be happy.
tint strip on window or no?pics? mud flaps yay or nay? evol04gt Interior & Exterior Modification 20 05-10-2009 01:21 PM
Group N tops with SPT pinks or Prodrives... yay or nay? Davemeister Brakes, Steering & Suspension 2 08-12-2005 10:07 AM
silver and gold, yay or nay NateDogg Interior & Exterior Modification 5 04-02-2002 02:15 AM
Yay or Nay? Daven Texas Impreza Club Forum -- TXIC 7 03-06-2002 06:49 PM
Last call: Kartboy setup, yay or nay? Siper2 Technical Forum Archive 22 07-27-2000 04:50 AM
