Welcome to the North American Subaru Impreza Owners Club Wednesday May 12, 2021
Old 10-22-2002, 01:38 AM   #1
brazymstrp
Member#: 18860
2002 WRX Wagon
WR Blue
Question Boost problem...did i fry my stock boost controller
okay, i felt like beind adventurous and made my own boost controller. After hitting the fuel cut off or boost cut off (not sure what to call it) I decided to put the hoses back to use the stock boost controller. I seemed to misplace the "T" that i needed, so i just bought a typical 3/16" T. That made me get boost at around .5 or .05 MPA.
I remembered reading that the factory tee had a restrictor built in. So what i did was buy a 3/16" restrictor and install it between the compressor, and the "T". That made boost ridiculously unstable. It seemed as if it were about to hit cut off, then it would back down do .5 mpa.
That scared me, so i decided to look thouroghly for the stock T. I found it, connected it back up, and i got a max boost of .5 mpa. I thought that i may have installed it incorrectly, so i flipped the T around and connected it. Still no dice. I replaced all the hoses with some 3/16" vaccum hose that i bought at the local autozone to see if maybe a hose was broken, still no dice.
I even went and tee'd off the BOV line, and connected that to the T, while capping off the turbo compressor connector.
what do you guys think? Is my car just in this so called "limp mode" and just have to reset the ECU or did i fry the stock solenoid? Any help or thoughts would be greatly appreciated. If not, i guess i'm going to have to put back the MBC i made, and just watch out for that PTFB...and wait untill i can afford a EBC. Thanks
-Jack
brazymstrp is offline   Reply With Quote
Old 10-22-2002, 03:00 AM   #2
khart2
Member#: 26601
2002 wrx
I had a MBC on my car for about 6 months then went back to stock and had the same problem, never did figure it out. I had sold the MBC I had so I went out and got a GFB MBC from Vivid Racing for $50 until I had the money for an EBC.
khart2 is offline   Reply With Quote
Old 10-22-2002, 03:31 AM   #3
jlevy
Member#: 15696
2015 WRX 6 speed
do you still have the small brass restrictor in the hose that comes off the compressor?
jlevy is offline   Reply With Quote
Old 10-22-2002, 04:01 AM   #4
khart2
Member#: 26601
2002 wrx
I originally reinstalled all the stock stuff the way it was, but have since tossed it all because it didn't work anyhow. I now have a Blitz Dual SBC Spec-S EBC which works great.
Old 10-22-2002, 07:47 AM   #5
VetteVert
Member#: 5961
2005 STi
CGM
Ditto. Go back to all stock hoses, and make sure the hose with the small brass restrictor inside the hose goes from the compressor outlet to the factory Tee. Squeeze the hose to find the restrictor. This seems to be the problem 90% of the time.
VV
VetteVert is offline   Reply With Quote
Old 10-22-2002, 01:48 PM   #6
brazymstrp
Member#: 18860
2002 WRX Wagon
WR Blue
man, i didn't even know that the hose had the restrictor, i always thought it was the T itself. Hmm, maybe i'll go pass by the dealer and go see if they have the part. Man, do I feel stupid for throwing away the hose. Or hey, maybe one of you guys would be willing to sell me your hose . Just a thought. Thanks for the help guys. At least now I know what's wrong. Thanks again
-jack
Old 11-30-2004, 05:26 AM   #7
17cTSi
Member#: 60256
i am germany right now and have the same damn problem, how would i go about getting another line with a restrictor. Becaust the german dealer mechanic is satisfiedd with telling my gauge just is reading wrong. Does anybdy have a part number.
17cTSi is offline   Reply With Quote
Old 11-30-2004, 02:14 PM   #8
Russ77
Member#: 69369
http://www.subaruparts.com/diag/?mod...category=073-1
and
http://www.subaruparts.com/diag/?mod...category=081-1
these links should get you all the part numbers you need to put everything back to stock.
Russ77 is offline   Reply With Quote
did i fry my turbo? Just installed EWG... felixk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 07-19-2009 12:30 PM
Is my Stock Boost Controller Dead? Seimfeld Newbies & FAQs 1 10-02-2007 10:42 PM
did i fry my coil pack? rswrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-31-2007 11:59 PM
help re-installing my stock boost controller on 02 wrx ants wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-03-2004 03:10 PM
Did I fry my pads? driggity Brakes, Steering & Suspension 12 11-20-2003 07:49 AM
