Welcome to the North American Subaru Impreza Owners Club Friday May 14, 2021
Old 07-16-2003, 09:40 AM   #1
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
Default 245/45R16 Victos on 16x7 Rota Slipstreams?
Will this work? It'd be a nice lightweight racing setup!!
ScreaminFast is offline   Reply With Quote
Old 07-16-2003, 09:45 AM   #2
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
OR, I could get rota 17x7.5 subzeros, and stick the 245s on there....
Old 07-17-2003, 09:16 AM   #3
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
I don't see why not, you'd only a half inch under the min recommended rim width. Although, I would suggest the 16x8" volk gram light, contact Nino's Auto, he's offered them fairly cheap before. Or you could get the es-tarmac's like I have......17x9"...yum.
Kevin
Red Rocket is offline   Reply With Quote
Old 07-17-2003, 01:25 PM   #4
omahasubaru
Member#: 1594
1999 2.5 RS
2002 Legacy
That's a lot of tire for a 7" wide wheel. I would strongly suggest you don't do this.
omahasubaru is offline   Reply With Quote
Old 07-17-2003, 08:15 PM   #5
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
Kevin
whats the es-tarmac's weight? price? hehe
Old 07-18-2003, 10:48 AM   #6
[email protected]
Tire Rack Moderator
Member#: 1215
ext. 4362
I would hate to be the person to has to mount a 245/45-16 R-Compound tire on a 7" wheel because even with all of the modern equipment it won't be anywhere close to easy or reasonable .... I doubt many people could even get them on the wheel
Old 07-18-2003, 04:27 PM   #7
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
Default Luke: Custom K1's
Luke,
A guy I met at my last autocross told me that he got custom made Kosei K1's 16x9. Can you guys get an custom, lightweight, wide 16" rims?
Old 07-18-2003, 06:36 PM   #8
boxerT
Member#: 16311
2004 STi
WR Blue
It will work. Years ago when the Ford Probe GT was a hot car in GS, everyone was running 245/45/16 BF Goodrich R1 on 16x7" OEM wheels. This will not be easy to do for the tire shop, but if you ask for the best tech, he will get it done.
boxerT is offline   Reply With Quote
Old 07-20-2003, 11:43 PM   #9
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
Luke?
Old 07-21-2003, 01:58 AM   #10
Kostamojen
Member#: 2272
2019 Macan 4cyl
1993 Impreza FWD WRX swap
It wont work.
I have 225/50/16's on Rota Slipstreams and I think its a tad too big. 245/45's would be impossible.
Here are some pics if you dont believe me: http://community.webshots.com/album/70429949mJoXEZ
Old 07-21-2003, 08:44 AM   #11
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
Well, I'm definitely not worried about 225s, because I'm running Kumho MX's on stock wheels right now for my racing tires....but i'd like to have a bit more rubber...
Old 07-21-2003, 11:14 AM   #12
[email protected]
Tire Rack Moderator
Member#: 1215
ext. 4362
Default Re: Luke: Custom K1's
Originally posted by ScreaminFast
Luke,
all they reallywere was custome machine to the needed bolt pattern .... not completely custom made ..... we do have K1's in blanks that we machine for certain applications ... here is a list of all sizes and offsets avaialbe even though most do not have the needed brake clearance for a WRX
15X7 BLANKS ET17
15X7 BLANKS ET27
15X7 BLANKS ET38
15X7 BLANKS ET45
15X8 BLANKS ET12
15X8 BLANKS ET22
16X7.5 BLANK ET12
16X7.5 BLANK ET22
16X7.5 BLANK ET32
16X7.5 BLANK ET43
16X8.5 BLANK ET17
16X8.5 BLANK ET27
16X8.5 BLANK ET37
17X7.5 BLANK ET35
as you can see ... not Subi friendly offsets
Old 07-21-2003, 10:41 PM   #13
Zuffy
Member#: 35268
2004 WRX Stg2 & with
added PDX goodness
Noooooooooo, why does Kosei discriminate Subies. I was thinking of 17x7.5 Koseis painted gold, but I guess that's not possible without spacers, ugh.
Cue the monkey
Zuffy is offline   Reply With Quote
Old 07-21-2003, 11:36 PM   #14
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Errr you wouldn't want spacers, those wheels would already stick out with the low offsets. I run 245/45/16 V700s but on 16x8 wheels. The tires look big for those rims, I can't imagine running them on a 7" wide rim.
Old 07-22-2003, 12:14 AM   #15
OKRS25
Member#: 36533
2005 STi
DWX I would like to see your wheels. What kind are they and what offset are you running, and how bad is your rubbing?
OKRS25 is offline   Reply With Quote
Old 07-22-2003, 09:39 AM   #16
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
Default Re: Re: Luke: Custom K1's
15X7 BLANKS ET17
15X7 BLANKS ET27
15X7 BLANKS ET38
15X7 BLANKS ET45
15X8 BLANKS ET12
15X8 BLANKS ET22
16X7.5 BLANK ET12
16X7.5 BLANK ET22
16X7.5 BLANK ET32
16X7.5 BLANK ET43
16X8.5 BLANK ET17
16X8.5 BLANK ET27
16X8.5 BLANK ET37
17X7.5 BLANK ET35
How about the 16x8.5 with 37 offset? Is it true that as the wheel gets wider you can lower the offset? I thought I read that somewhere on here. Also, whats the price on the k1's? Anyways, are there any other options for me to run a 245? Any other wheels available that won't break the bank, and aren't 50 million pounds heavier than stock?
Old 07-22-2003, 10:00 AM   #17
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
They are 16x8 Volk Gram Lights from Nino. They are 45 offset which is what you would want on a wheel of that width on a Subaru. Right now I'm using STI-RA takeoff struts/springs and I have no rubbing anywhere. I also have used DMS50s with them, and those required using a 5mm spacer on all 4 corners to combat rubbing on the lower spring perch. 225 tires on 17x7.5 +48 Rota Attacks also rub on the DMS50s, but I only have to use a 2mm spacer.
Old 07-22-2003, 03:25 PM   #18
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
those sound like a good option, dwx. I'm also looking at the 5Zigen FN01R-C, 17x8, 5x100, +48, 16lbs, which should easily be able to fit 245/45/zr17, or i may try to squeeze 255/40zr17s on there....not to mention they are only 180/wheel...which isn't all that bad....any suggestions?
Old 07-23-2003, 03:01 PM   #19
Draken
Member#: 16
1968 Saab
Sonett II V4
Default 245 on 16x7 just fine
They fit just fine. I've run 245/45-16 Kumho Victo 700 on the front of my '99 2.5RS for a couple years for autocross use. They mounted quite easily at the local Big O tire store. Kumho also had no trouble switching them around at various ProSolos and nationals last year.
Here is a pic of them mounted on car:
and
It is fairly standard practice to mount wide R compound tires on narrow wheels for stock autocross. People have regularly mounted 225/45-15 Hoosiers on stock 15x6 Integra Type R wheels, and the top 1st gen CRX guys are running 225/45-13 Hoosiers on 13x5 wheels. The 245 on 16x7 wheels is fairly tame.
Chris H.
Draken is offline   Reply With Quote
WTB: 1 16x7 Rota Slipstream dawrxisdashyet Private 'Wanted' Classifieds 0 01-12-2009 03:45 PM
NJ: 16x7 Rota Slipstream with Falken tires IMPREZive 02 WRX Tri-State Area Private Classifieds 4 01-10-2009 02:17 PM
I NEED 16x6.5 or 16x7 ROTA SLIPSTREAMS ! HELP ! Subaru WRX04 Private 'Wanted' Classifieds 1 03-17-2007 08:22 PM
FS: 16x7 Rota Slipstreams (flat black) Rocketcar SCIC Private Classifieds 6 09-21-2006 12:50 PM
FS local buyers 16x7 Rota Slipstreams w/ 225/50-16 Toyo T1-S TubeDriver Private 'For Sale' Classifieds 10 02-17-2005 10:04 PM
