Welcome to the North American Subaru Impreza Owners Club Wednesday January 23, 2019
Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 10-03-2018, 10:27 PM   #1
Xechs
Member Sales Rating: (1)
Member#: 7251
2018 Outback 3.6R
Grey
Default MD: 2002 WRX, 246,xxx, $3500 OBO - SOLD
2002 WRX WRB
$3,500 OBO
246,xxx miles
Manual
One owner
Exterior:
STI hoodscoop (new this year to replace the peeling pain stock one, which is included)
Headlights replaced about 2 years ago with new OEM units
Prodrive P7 wheels in gold, Continental extreme contact tires with plenty of life left on them
Stock wheels included
Engine:
PWR TMIC
Vishnu UD pulley
Remanufactured WRX alternator from a newer model year that has higher output (100A)
Perrin fuel rails
Perrin turbo inlet hose
Silcon intercooler hose kit
Silcon ancillary hose kit
Silcon radiator hose kit
Vishnu uppipe
Maddad down and mid pipes
Bosal twin tip exhaust
Kartboy exhaust hangers
Coolant tank that's on the top of the motor was replaced this year with the new plastic unit
Replaced battery cables last year due to the terminals clamps no longer being able to be tightened enough.
Oil changed every 3000 miles with mobile one
Suspension/brakes:
JDM S202 RA Spec C suspension
Stoptech rotors and pads (replaced about 4 months ago)
Rebuilt emergency brake drums
Interior:
Kartboy short shifter
Momo shift knob
Defi gauge pod
Defi Link
Defi 60mm EGT (metric)
Defi 60mm boost (metric)
defi 60mm oil pressure (metric)
Kenwood excelon KDC-859 head unit w/sirius-xm aentenna
Infinity speakers
Dual 10" infinity subwoofers
Audiobahn amp
Interior is in great shape for the age/mileage of the car, only issue is cracks in the center arm rest.
Misc:
Replaced rusted out front subframe with a good condition used unit (no rust)
Major service history:
I have all the service documents.
Motor partially rebuilt at 140K when the head gasket started to leak, decided to put in a new stock block (old block was fine), valves were adjusted
170K replaced piston due to cracked piston ring, issue was caused by a failing UTEC, replaced timing belt, pulleys and water pump at this time also. Utec came off at this point and have been running stock ECU since.
Most recent service was 105K equivalent service (new water pump, timing belt, timing belt pulleys, etc)performed by Andrewtech at 245,xxx
Major service work was performed either at Andrewtech or at Stohlman Subaru in Herndon by Dan when he worked there (he formerly worked for andrewtech).
Current issues:
Suspension could probably deal with being replaced.
Power steering pump may be starting to go.
Very minor oil leak above the oil filter, common for o-ring to get cracked, actually have the part just haven't replaced it.
Front speakers rattle.
Since the car was new there is a weird issue filling up with gas where the fuel pump will keep "popping" if you hold it all the way open, you need to hold it about halfway and it will fill up. The dealer wanted to drop the tank to try to resolve the issue way back when it was under warranty, but it was my only car so I never got around to doing it and just got used to it.
Passenger side front door lock does not lock/unlock with power door locks.
PM if interested or want more info/pics.
Xechs is offline   Reply With Quote
Old 10-05-2018, 11:28 PM   #2
Xechs
Member#: 7251
2018 Outback 3.6R
Grey
Bump for the weekend.
Old 10-06-2018, 08:34 PM   #3
EnterSandman
Member#: 321215
Do you have pictures of the newer subframe that was installed? Thanks
EnterSandman is offline   Reply With Quote
Old 10-07-2018, 05:13 PM   #4
Xechs
Member#: 7251
2018 Outback 3.6R
Grey
As requested:
Old 10-09-2018, 09:45 PM   #5
Xechs
Member#: 7251
2018 Outback 3.6R
Grey
Bump for the new week.
Old 10-13-2018, 03:23 PM   #6
Xechs
Member#: 7251
2018 Outback 3.6R
Grey
Price drop, $3500 OBO.
Old 10-14-2018, 01:55 PM   #7
04fpgreensti
Member Sales Rating: (8)
Member#: 151655
2012 STI Limited
Great deal!! Good luck with sale!
04fpgreensti is offline   Reply With Quote
Old 10-16-2018, 08:38 PM   #8
Xechs
Member#: 7251
2018 Outback 3.6R
Grey
Mid week bump.
Old 10-16-2018, 09:23 PM   #9
sxotty
Member Sales Rating: (2)
Member#: 95600
2003 WRX wagon
Good luck, I always liked the blue black upholstery on that era.
sxotty is offline   Reply With Quote
Old 10-20-2018, 01:13 AM   #10
Xechs
Member#: 7251
2018 Outback 3.6R
Grey
Weekend bump
Old 10-21-2018, 01:51 AM   #11
spectra
Member Sales Rating: (13)
Member#: 15763
2015 WRX
Most of your image links are broken. Do you have a link to all the images?
spectra is offline   Reply With Quote
Old 10-21-2018, 05:24 PM   #12
jweida
Member#: 492896
Those headlights look great. Would you mind sharing where you got them and the cost?
jweida is offline   Reply With Quote
Old 10-21-2018, 07:01 PM   #13
Xechs
Member#: 7251
2018 Outback 3.6R
Grey
Spectra, they all display for me? I checked the permissions for the album on imgur and it's set to public. A direct link to the album is http://breetai42.imgur.com.
jweida I ordered a new set of OEM lights from heritage subaru, they are about $230/each, link for them is https://www.subarupartsdepot.com/v-2...amp-components. Before ordering new OEM lights i looked for other aftermarket options, they were either crappy ebay lights or $1000+ EDM projectors. So I just went with OEM.
Old 10-24-2018, 11:12 PM   #14
Xechs
Member#: 7251
2018 Outback 3.6R
Grey
Wednesday bump.
Old 10-26-2018, 01:27 PM   #15
Poden
Member#: 487220
still available?
Poden is offline   Reply With Quote
Old 10-26-2018, 11:37 PM   #16
Xechs
Member#: 7251
2018 Outback 3.6R
Grey
Yes, this is still for sale.
Old 10-27-2018, 07:39 PM   #17
jweida
Member#: 492896
Thanks for the info! Your pics all showed up for me.
Old 10-27-2018, 07:55 PM   #18
sub_sifu
Member#: 301690
2002 Wrx
Looks like a 100k mile car, what a steal of a deal. Good luck selling.
sub_sifu is offline   Reply With Quote
