Welcome to the North American Subaru Impreza Owners Club Tuesday January 15, 2019
Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 10-02-2018, 09:35 PM   #1
nathan.d.kim
Member Sales Rating: (8)
Member#: 157161
2007 OBP STI
black
Default [VA] 2007 Subaru Impreza WRX STI, OBP, 76k miles
Torn about selling this car, but I've had it for 11 years now. Looking to downsize to one daily driven car. Miles will go up slightly until the car is sold since I drive it about three times a month. A little over 76k miles on the chassis, 33k on the Rallispec shortblock, 22k on FP 71HTA turbo, 16k on clutch and flywheel.
Asking price is $23,999 or best offer. Stock silver BBS wheels may be included depending on the final price. Current wheels are gold Rota Torque 17x9 wrapped in Continental Extreme Contact DWs.
Maintenance tracker available upon request. Passed NJ and VA emissions tests without problems. Passed VA annual inspection. No CELs. No issues. Tastefully modded, perfect balance of performance and reliability. One-owner, adult-driven, non-smoker. Super clean. Test drives can be scheduled for serious buyers with proof of funds/finance.
Will keep it if I can't find a buyer. "It's cheaper to keep her."
RECENT MAINTENANCE ITEMS
Spark plugs changed at 65k miles
Compression test by AndrewTech at 72k miles (135-135-135-135)
New front O2 sensor (AF sensor) at 73k miles
New rear O2 sensor at 73k miles
New Denso MAF at 73k miles
New knock sensor at 73k miles
New Battery (Duracell AGM) at 75k miles
Subaru Extra-S and LSD fluids at 75k miles
Alternator replaced at 76k miles
FULL MOD LIST
Engine, Fueling, Drivetrain:
Cobb Accessport V3
IAG custom tune on current setup
Rallispec Street Spec Short Block (Wiseco stock-sized pistons)
ARP head studs
2008 OEM oil pump (11-mm)
Grimmspeed EBCS
Omni 4-Bar MAP sensor
KST Tech 73-mm
Perrin reinforced turbo inlet
Forced Performance 71HTA turbo
Process West TMIC
Cobb XLE bypass valve
IAG Air Oil Separator
Killer B 2-bolt ELH
Grimmspeed 45-mm EWG uppipe, 2-bolt
Turbosmart Hypergate-45 EWG
Cobb catted downpipe
Invidia Q300 catback exhaust
Walbro 255 fuel pump
Injector Dynamics 1000-cc injectors
NGK One-Step Colder spark plugs
Killer-B oil pickup tube
Competition Clutch lightened flywheel
Exedy Stage 1 clutch (15803HD)
Beatrush transmission mount
Group-N motor mounts
Kartboy shifter bushings
Kartboy rear differential bushings
Gates Racing Kevlar timing, AC, and alternator belts
Suspension and Braking:
Feal fixed-perch struts
RCE Black springs
Subaru Group-N top hats
RCE sway bars (front and rear)
Kartboy endlinks
Stoptech SS brake lines
Ferodo DS2000 brake pads
Centric Premium rotors
Miscellaneous:
3M clear bra
Opticoat Pro
Window tinting
Kenwood DDX6019 w/ Sirius Adapter
ATI gauge pod
Defi-Link Controller
Defi gauges (boost, oil pressure, EGT)
Rally Armor mudflaps
Smoked headlights
Morimoto H11 HID bulb upgrade
Hella Supertone horns with Perrin bracket
Rota Torque gold wheels, 17x9
Continental ExtremeContact DW tires
BBS stock silver wheels
JDM 04-05 tail lights
JDM hazard lights
Dash paint to replicate S204 look
Rhino Liner lip coating
Killer B Alternator Cover
Flex Innovations grounding wire kit (intake, alternator, battery)
Fluids Used:
Amsoil 0W-40 motor oil (every 2,500 to 3,000 miles)
Motul brake fluid
Subaru OEM coolant with conditioner
Subaru Extra-S transmission fluid
Subaru LSD fluid
Valvoline DEX/MERC ATF (power steering)
Most recent dyno sheet from IAG (JR) with ELH. 350 whp at 5800 rpm // 340 wtq at 3800 rpm.
Prior dyno sheet from EFI Logics (Mikey) with stock headers. 345 whp at 6445 rpm // 354 wtq at 3800 rpm.
Butt dyno says the current tune has more top-end power, but different dynos, conditions, configurations.
nathan.d.kim is offline   Reply With Quote
Old 10-07-2018, 07:38 PM   #2
nathan.d.kim
Member#: 157161
2007 OBP STI
black
Purchased an AutoCheck report that shows 1-owner, no accidents, no issues.
(Lots of state registrations and renewals though since I moved a lot for my job.)
Title in hand. Ready to go! Great weekend car or daily driver.
Old 10-08-2018, 11:45 AM   #3
A-man07
Member Sales Rating: (11)
Member#: 271525
7/2 STi/WRX wagon
SWP/AW
Good luck man, hope you get full ask but sorry to see an original owner sell.
Will be a great buy for someone.
Adam
A-man07 is offline   Reply With Quote
Old 10-08-2018, 01:19 PM   #4
iitsnancy
Member#: 492458
Nice car
iitsnancy is offline   Reply With Quote
Old 10-08-2018, 11:27 PM   #5
nathan.d.kim
Member#: 157161
2007 OBP STI
black
Thanks, guys.
Adam - I bought a stock rear strut from you back in 2010 when one of mine was blown. The bottom nut sheared off. Still remember how well you packed that thing and shipped quickly!
Who knows? I will keep it if no one buys it and just explain to the wife no one wants it. Maybe I'll just keep modding - TGVs, fuel rails, E85, and speed density would be good next steps. (Like staying top mount and stock location turbo.)
Old 10-13-2018, 10:32 PM   #6
nathan.d.kim
Member#: 157161
2007 OBP STI
black
Weekend bump.
Old 10-23-2018, 02:09 AM   #7
nathan.d.kim
Member#: 157161
2007 OBP STI
black
Hmm - Getting second thoughts again on selling the car. I know I'm going to regret it if I do sell it.
Looking at the mod list, if I am looking to eek out some more power with a retune, what would you guys recommend as next upgrade paths?
TGV deletes?
Bigger turbo? (Prefer to keep stock location for better spool and low/mid-range.)
Fuel rails and bigger pump?
E85 tune?
Alcohol injection?
