Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 10-22-2018, 10:50 PM   #1
turbofordkid95
Member Sales Rating: (1)
Member#: 142791
2002 wrx wagon, vf34
blue & redish 555tuned
Default (Va) 2000 Full JDM STI Swapped RS coupe
Up forsale is my 2001 2.5RS originally white but has been professionally painted ford pacific blue inside and out. it has had a bug eye dash swap along with an 07 center console and 2012 steering wheel with working radio controls.
Body has around 165,000 miles engine and cluster are at 68,000
Engine:
version 8 j207 with working AVCS open source tuned with Speed Density on a JDM ecu tune could use a little touching but runs great and strong. It has ARP2000 Headstuds, oem head gaskets, Brian Crower valve springs with titanium retainers along with a nice port and polish job and freshly lapped valves and fresh timing belt.
Has a TD06 20g with an invader up pipe and ported grimspeed manifold, a eBay special cat back with an additional resonator and a 4” turbo XS down pipe.
FMIC with custom charge pipes and Tial 50mm BOV, 3” agency power hard turbo inlet, Dw850 injectors but a set of ID1000’s are included just not installed, DW300lph fuel pump. Water meth with 5 gallon tank but not being used since not tuned for it. Also AEM eugo Wideband.
Suspension:
It has BC coilers, Full JDM 05 STI spec C suspension and crossmembers which consist of all aluminum control arms front and rear upgraded bushings, brembo’s wit stainless lines, 5x114.3 hubs, larger swayers. has 07 sit steering rack which is quick ratio and whiteline bushings. 08 STI wheels with almost new tires.
Transmission:
Has a Rare 05 JDM STI Forester 6 Speed which is similar to USDM legacy GT spec b. With the .707 6 gear which means on the high way at 80 mph you are at 2900 RPM’s Also is a viscous center diff and AP Suretrack front and rear locking differentials.. Custom short throw shifter with upgraded bushings and Exedy stage 1 organic clutch and oem flywheel with 1000 miles.
Body:
Started out as an almost rust free car any rust was sandblasted repaired with metal, epoxy primed prior to paint. Car harness is out of a bug eye and rear tail light harness and fuel pump harness was merged with it all connections are soldered and shrink wrapped. had new headlights and corner markers, the harness was also out of a wagon so has all the controls for the rear wipers just need the two wires ran from harness to wiper motor. The car was stripped to bare shell prior to paint and all wholes in fire wall were wedded up and body worked for dash swap. Whole car was also dyno Matted to make more enjoyable only added 18 pounds to car, if worried about it go on a diet.
The pink sued headliner is starting to sag.
Every thing functions as it should, power locks Key fob alarm, power windows sun roof ect. also has Genisis seats which fold up and slide forward to gain entry into back seat.
There are a bunch of little things I am missing that add up I have around 20k invested, in just parts it was fun but have a baby on the way and this baby won’t get the live it deserves.
https://photos.app.goo.gl/jNAUZN1Ln1fYYDAd9
Asking $12,500
Feel Free to text for more info, pictures and video. 774-289-3112 located in Portsmouth Va
turbofordkid95 is offline   Reply With Quote
Old 10-22-2018, 11:05 PM   #2
Legasuras05
Member#: 487021
Only once pic was available when I clicked the link. Looked clean though lol
Legasuras05 is offline   Reply With Quote
Old 10-22-2018, 11:09 PM   #3
Fyrfytr
Member#: 24815
'00 Impreza RS
Blue Ridge Pearl
Post pics in the thread or it will probably be locked.
Fyrfytr is offline   Reply With Quote
Old 10-22-2018, 11:32 PM   #4
Legasuras05
Member#: 487021
How much are you asking for it?
Old 10-23-2018, 07:38 PM   #5
turbofordkid95
Member#: 142791
I am not sure how to post an actual picture on here
Old 10-24-2018, 11:08 PM   #6
paquinbhp
Member#: 362488
2015 Impreza Sport
You need some more pictures man, looks great though.
paquinbhp is offline   Reply With Quote
