Brakes & Suspension Forum sponsored by The Tire Rack |
06-24-2001, 04:11 PM | #1 |
Miss You Mom
Oct 1940 - Feb 2008 Super Moderator Member#: 809
NESIC
Vehicle:2000 2.5 RS, '14 For 92 5MT SVX |
RS ---> WRX Brake Rotor Conversion Mods Page Up, Part #'s Included
Spent a bit of time with another IClubber fitting the larger WRX rotors to the RS. Have the mods page up, right here http://www.northursalia.com/m.../wrxbrake.html for your approval . Questions and comments are welcome, and I'll try to answer anything I can (but read the page first, then ask your questions, as most of them will be answered there).
Brian AIM: captaindamorgan ICQ: 84483950 http://ravensblade.cjb.net Come See The Magic World Inside the Abandoned Refrigerator!
06-24-2001, 05:38 PM | #2 |
Member#: 1964
RMIC
Vehicle:2012 Fit Sport 5MT Orange Burst |
I've done this to my 93 Legacy Touring Wagon.
It's really very, very easy and the brake power is incredible. http://www.xmission.com/~dac/library/brakes.htm |
06-24-2001, 05:47 PM | #3 |
Member#: 1393
I was wondering, can you just switch over bigger rotors without changing the calipers, or do you have to change them too... I have a 95 L with crap brakes, and I want to switch to larger rotors, but I'm not sure if it'll work...?
-Josh |
06-24-2001, 06:05 PM | #4 |
Miss You Mom
NESIC
ImprezaL, the RS calipers are larger than those of the 95L I believe, so you would have to change the calipers as well if that is the case. If not, you are only changing the bracket for the caliper- the stock caliper remains.
Brian AIM: captaindamorgan ICQ: 84483950 http://www.northursalia.com Conjunction Junction, what's your function? |
06-24-2001, 06:08 PM | #5 |
Miss You Mom
NESIC
ImprezaL, I just checked one of my parts books, and it would indeed appear that you would have to change out the calipers as well .
Brian AIM: captaindamorgan ICQ: 84483950 http://www.northursalia.com You and the Captain make it happen! |
06-24-2001, 06:47 PM | #6 |
Techno Sapien
Moderator Member#: 449
Vehicle:2019 Impreza Sport Lithium Red |
Brian,
If you are using the same size RS brake pads then the swept surface the same as the stock rotor no? Other than a larger heatsink will you get any better stopping power? Maybe I'm confused, I'm not that big on brake knowledge. Does having a larger heat sink outweigh the increase in unsprung weight? Peaty |
06-24-2001, 07:03 PM | #7 |
Member#: 1346
Yeah, I thought the only reason to up the rotor size was if you were getting heavy-duty fade.
06-24-2001, 07:15 PM | #8 |
Techno Sapien
I thought you went bigger to enable larger rotors and pads, increasing the swept surface giving quicker stops. Brakes convert foward energy to heat and having a bigger pad/rotor setup would make more heat over a larger surface area.
06-24-2001, 08:13 PM | #9 |
Member#: 456
NWIC
Vehicle:2008 Forester XT Steel Gray Metallic |
Increasing the rotor diameter increases mechanical advantage -- I did the math some time ago and came up with 8% or something. There is also an increase in swept area, but the real change comes from moving the pad further away from the axle.
Glenn |
06-24-2001, 08:47 PM | #10 |
Miss You Mom
NESIC
Wow, you go away for a bit and the thread explodes . Thank you for the much more succint answer than I could have given Mr. Wallace .
06-24-2001, 08:53 PM | #11 |
Techno Sapien
I see so the pad now travels a further distance around the rotor because he radious has increased, got it.
Peaty |
06-24-2001, 09:17 PM | #12 |
Member#: 689
NESIC
Vehicle:2005 Outback 2.5 XT Champagne Gold Opal |
Brian, I did some math:
Stock RS rotors are 10.7" diameter: Area = Pi*r^2 = 3.14 * (10.7/2)^2 = 90 sq. in. WRX rotors are 11.4" diameter: Area = 3.14 * (11.4/2)^2 = 102 sq. in. (102 - 90)/90 = 13.3% That means the WRX rotors are only 13.3% larger, not "20% larger". I haven't done the math for the swept area, however. And I assume that's where the "20%" figure came from. Swept area by itself does not affect braking ability. But it does help with resistance to fade. Perhaps it should be touted as "20% more resistance to fade"? Or perhaps more than that even, since the rotors are thicker as well. Assuming the same rotor material, calipers, brake pad dimensions and pad material, only the effective rotor radius affects the difference in braking ability. I haven't measured the pads myself, but I'll highly simplify things and assume that effective rotor radius is in the center of the brake pad, and that the pad is about 2" tall. Then we get approximately (10.4-9.7)/9.7=7% improvement in braking ability. Hardly the 20% quoted above! BTW, good job with pics that are nearly impossible to photograph. -WaC Wayne Community Science Police |
06-24-2001, 09:22 PM | #13 |
Miss You Mom
NESIC
Eh, I go with what I'm told . Thanks for the hard numbers Wayne... I'll update things. I believe Mr. Harvey has a set of stock front rotors for you or Edwin to wreck on the track . Thanks for the kudos too... the hardest thing to get a picture of is where the caliper bracket meets those pins; I think my crude diagram gives the idea, but I'm going to try and take better pictures of that area using my car in the near future.
Brian AIM: captaindamorgan ICQ: 84483950 http://www.northursalia.com Conjunction Junction, what's your function? Last edited by North Ursalia; 06-24-2001 at 09:24 PM. |
06-24-2001, 09:25 PM | #14 |
Member#: 10
NESIC
Vehicle:2005 Legacy Gt wagon Garnet red pearl |
WaC if you would like next weekend i will bring the brakes up to your place if you would like to take any sample or reading or something... also i want to give you the crossdrilled rotors to see if you can make them crack in Montreal..
06-24-2001, 09:30 PM | #15 |
Techno Sapien
Brian,
If you get your hands on a stock set and the WRX ones it would be cool if you could weigh them on the scale. I'm curious to know the diff. |
06-05-2002, 07:12 PM | #16 |
Member#: 11778
Vehicle:1980 VWRabbit Diesel w/AAZ Swap |
yea what is the wieght diff between RS and WRX rotors?
06-05-2002, 07:56 PM | #17 |
Member#: 4414
Vehicle:2002 WRX Sedan Midnight Black |
Umm, yeah, back from the dead...
WRX rotors are about 14 pounds. I assume RS rotors are about 1.5, maybe 2 pounds lighter. |
RS -> WRX Brake swap beware! | DDMan | Brakes, Steering & Suspension | 25 | 03-17-2010 12:01 PM |
Another RS -> WRX brake conversion question | Rabidbyte | Brakes, Steering & Suspension | 1 | 05-05-2004 04:11 PM |
RS--> WRX front brake conversion- small questions | Concillian | Brakes, Steering & Suspension | 8 | 08-27-2003 04:48 PM |
FS Local: RS -> WRX brake swap parts. | DDMan | Bay Area Impreza Club Forum -- BAIC | 5 | 07-23-2003 04:19 PM |
RS to WRX brake rotor swap parts | Bob O | Mid Atlantic Impreza Club -- MAIC | 13 | 02-03-2003 09:28 AM |
