Welcome to the North American Subaru Impreza Owners Club Monday August 20, 2018
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Old 07-12-2018, 04:12 PM   #1
TH motorsports
Vendor Sales Rating: (84)
Member#: 145643
95 Impreza L-ish
Blueish Green
Default **thm Fluidampr Clearance**
Found in our returns closet, brand new, opened, but never installed.
325 Shipped
Fluidampr Engine Dampers are designed to control destructive vibrations which are transfered thru the crankshaft.
Each time the air/fuel mixture inside a cylinder is ignited, the combustion that occurs creates a torque spike that is applied to the crankshaft through the piston and rod. This torque spike is so severe that it not only turns the crankshaft, it actually twists the crankshaft ahead of its normal rotation and then the crankshaft rebounds. This twisting action is known as torsional vibration. When these torque spikes and forces get into phase with the natural frequency, critical torsional harmonic vibrations occur and can be seriously destructive to the bearings and the crankshaft. Dampers are designed to control those destructive vibrations.
Critical harmonic vibrations occur numerous times in a engine’s operating range. Stock rubber and elastomer-type dampers are frequency sensitive “tuned absorbers”, and work at only one critical frequency. In the case of a stock rubber damper, it is tuned for a factory engine’s critical harmonic vibrations. If you change the mass of pistons, rods, or the crankshaft, you change the natural frequency of the crankshaft assembly; therefore, the stock damper is no longer tuned to the new frequency of vibration, and you may be headed for early failure of expensive engine components. Dampers also create heat while they work, and rubber is a poor dissipator of heat. This heat and the exposure to the elements deteriorates rubber, causing it to crack and change durometer, which then leads to inertia ring slippage, damper failure, uncontrolled torsional vibration, and costly engine parts breakage.
__________________
Will@THMotorsports.com
800 959 0145 ext 7028
TH motorsports is offline   Reply With Quote
Old 07-12-2018, 08:33 PM   #2
Mr T-wrx
Member#: 469053
325 Shipped
Is it part number 571101 (fits 2015+ WRX)?
If it is, please PM me.
Thank you
Mr T-wrx is offline   Reply With Quote
Old 07-18-2018, 10:40 AM   #3
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
Bumpity bump. I have EJ and FA overstock. Let's get them out of here.
__________________
Old 07-23-2018, 02:00 PM   #4
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
Bump!
__________________
Old 08-03-2018, 03:25 PM   #5
violentleaf
Member#: 432126
2015 WRX
Galaxy Blue
FA Still available?
violentleaf is offline   Reply With Quote
