05-09-2016, 07:00 PM | #76 | |
Member#: 328399
NWIC
Vehicle:2012 WRX Limited OBP |
RR Logger locking up during WOT pulls
I had a similar issue and it was corrected by switch to a usb cord with chokes. Haven't experienced any freezing since swapping the new usb cable
04-02-2017, 08:17 AM | #77 |
Member#: 110078
Vehicle:02 Bugeye JDM STi OBP BLACK |
Double post.
04-02-2017, 08:22 AM | #78 |
Member#: 110078
I was also having the same problem, once above 4,000 rpm romraider would freeze. I have a Tactrix 1.3 cable, installed 9 chokes on the cable. 3 chokes at each end about 1" from each other and 3 more along the length of the cable. Also, 1 choke on each side of the car wires just behind the obd2 port. Working perfectly now. Thanks to all who contributed here and the good people at Tactrix.
02-17-2018, 10:47 AM | #79 |
Member#: 256956
Vehicle:2005 Forester xt Obsidian Black |
Another revival-
I would like to add that I've had this problem on my 2005 Forester XT 4eat. This problem remained consistent with; 1.Cobb Accessport V2 and V3. 2.Romraider plugged in to my laptop via open port 2.0 3.BTSSM via Bluetooth to nexus 7 through OBDlink MX and BTSSM adapter. (Awesome by the way) Problem remains consistent with a lockup and automatically restarts the monitors with the datalog ending as the load increase. These repairs were consistent with each test; 1. replaced the obd connector per the request of Cobb - no fix 2. installed a single ferrite choke with wire wrap in place - no fix. 3. installed two ferrite chokes, one at Accessport end and one at OBD end - no fix I will remove the electrical tape and add a couple more chokes and reply back. I feel oddly optimistic, thanks for sharing everyone! |
02-17-2018, 11:01 AM | #80 |
Member#: 328399
NWIC
Have you checked the grounds? Given vehicle age they may be weakened ,corroded, or broken
RR Logger not showing FBKC on 2011 STI | mapleleaf | Open Source Reflashes | 5 | 09-20-2011 02:36 PM |
RomRaider logger locking up constantly after LC-1 install | Tronner | Open Source Reflashes | 7 | 07-05-2010 03:38 AM |
clutch pedal sucks to the floor during wot pulls | wopdeeze | Transmission (AT/MT) & Driveline | 4 | 05-14-2009 05:10 PM |
Shifter pulls to the right during WOT | cheese tits | Transmission (AT/MT) & Driveline | 1 | 12-18-2005 08:19 PM |
Why does WOT pull less than 99% WOT? | IggDawg | Normally Aspirated Powertrain | 8 | 10-27-2002 07:24 PM |
