Welcome to the North American Subaru Impreza Owners Club Wednesday March 22, 2023
Old 11-18-2001, 07:34 PM   #26
PDG
Member#: 11049
02 WRX, BLACK WAG
Somewhere around stage 4
oh, don't get me wrong, lead + auto = bad things. I was more speaking of the oxyigation of the fuel.
We can run super leaded fuels on the motorbikes cuz we strip em down and rebuild them regularly (I guess you could do the same with a car, but defnitely not as easy.)
PDG
btw--retail for VP Fuel MR-1 is about $25/gallon.
PDG is offline   Reply With Quote
Old 11-18-2001, 07:38 PM   #27
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Lead for oxygenation? Pull the other one. People use leaded fuels because it is cheap and there is a myth surrounding it that says it performs best.
What fuel do F1 cars run currently? It used to be an 86% or so toluene mixture (with an inert fluid for the other 14%). Some minor additives because pain thinner tends to remove oil from engine parts, but definitely no lead.
Ben
Edit: To clarify, lead as an additive is cheap in comparison to other additives with similar or higher performance, not compared to pump gas.
bsquare is offline   Reply With Quote
Old 11-18-2001, 07:42 PM   #28
z&cobb
Member#: 12344
2002 2JC
blue
Default MMT 104 Octane
Originally posted by L8Apex
You WILL get better times if you use race gas. Try it, I have used VP in N/A cars and forced induction and have seen gains in all of them. Try and run with 4 gal. of VP C10 or better yet C12 and nothing else. The VP gas WILL lower exhaust gas temps, it WILL allow higher boost and timing. The stuff costs $7 a gallon but it works, its the best fuel (gasoline) u can buy.
The sure thing in this thread is if you have removed the stock catalysts, replaced them with one large cat and a good cat back system, and added a bigger intercooler with a higher scoop, and added an adjustable boost controller, you can make your own high octane gasoline by buying an octane booster which contains MMT. Make sure it says it has MMT in it, that's for-real stuff on the level of the old tetraethyl lead. Making the octane to suit the boost will save you big bucks when boosting to 300HP. Otherwise set the boost low and use 87 octane for 200 HP. If you get sub-par gas for some reason it is nice to turn the boost down. WRX's with the stock computer will be happy with this thoughtfulness.
z&cobb is offline   Reply With Quote
Old 11-18-2001, 07:48 PM   #29
PDG
Member#: 11049
02 WRX, BLACK WAG
no no no, you're missing my point.
I'm not saying leaded fuel is oxginated, I was just simply saying that the 'power' fuel I use for race bikes happened to be leaded, but it was also highly oxyginated--two things that are not really related to each other (well, maybe in some magical chemical world I know nothing about).
The specs for the MR-1 fuel I use:
Specific Gravity: 0.740 @ 60°F
Lead, g/L: 4g/gal
Color: Clear
Research Octane: 104
Motor Octane: 90
Oxygen: 2.55
Distillation:
10% evap @ 124°F
50% evap @ 180°F
90% evap @ 222°F
E.P. @ 254°F
Production: San Antonio, Texas USA
Availability: Sealed Drums, Pails
MR-1 was designed for AMA 4 stroke competition Dyno tests have shown .5% to 4% more power over our competitors. MR-1's higher octane value helps resists detonation while allowing easier tuning.
Old 11-18-2001, 07:58 PM   #30
bsquare
Member#: 1911
2000 Impreza 2.5RS
z&cobb:
Let's be clear: TEL is a mediocre octane boosted, certainly matched or exceeded in performance by ethanol. I am extremely suspicious of MMT, particularly since ethanol can be manufactured so cheaply and is known not to pollute at all. The main reason for the continuing development of petroleum and heavy metal based octane boosters is money, and the main reason people think they work better than ethanol and other safe additives is marketing.
PDG:
I'd be interested in a performance comparison between that gas and gas forumlated using ethanol or xylene (and friends).
Race gas - can stock ECU take any advantage? mmiller2002 Newbies & FAQs 8 04-30-2009 02:04 PM
Race Gas in a stock wrx harrison88 Newbies & FAQs 12 09-30-2007 10:07 AM
18G + race gas, 23psi + stock tranny & clutch= KCRex Proven Power Bragging 19 04-09-2005 04:01 PM
('93-'01) High octane gas in stock WRX. THEMUSH Impreza Forum 31 10-30-2001 09:26 PM
Where to get race gas in phoenix? KEVINL South West Impreza Club Forum -- SWIC 3 04-20-2001 10:57 PM
