#1 |
Member#: 159286
TXIC
Vehicle:2002 WRX Wagon,Com-C RCE wgn sprngs/Konis/H6 |
![]() If I was to try some of the 100 octane gas available at the track this weekend, would the stock ECU be able to recognize this and adjust for any better perfromance? Thanks
I'm still a newbie
#2 |
Member#: 156723
Vehicle:17 2.5i foz dgm rip wrx/rs/2.5i/foz1 |
![]() Good Q I want to know too, should prob be ok it will burn HOT though be careful... dunno if the ecu will recognize
#3 |
Member#: 198633
NESIC
Vehicle:2004 WRX Black |
![]() No. The ECU cannot sense and then add in timing to adjust for it properly.
#4 | |
Member#: 185347
Vehicle:2002 EVO3 bugeye wag EG33 Swapped 2 dr RS |
![]() Quote:
Higher the octane means the harder it is to burn,hence with race gas (cam2,Q16,etc..) you can get more power. This is because you can advance the timing,and run more boost before knock. So without a tune you are basically throwing out your money. |
#5 |
Member#: 156723
![]() is stock wrx tuned for 93?
#6 |
Member#: 104272
Vehicle:2002 WRX ClubWRX Ambassador |
![]() Stock ECU will advance timing to benefit from up to 95 octane. Any higher is a waste. And no, you won't notice a difference.
I'm assuming you live near Kennedale? |
#7 |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
![]() You could add a little to make sure you're not getting any knock and pulling timing. Ideally you would do this a few days before the track and reset your ECU to clear the FLKC table and give the car some time to bring IAM back up. Other than raising the octane a bit to clear out any knock, no it won't help.
#8 |
Member#: 185347
![]() To speedette, you would have to do an ecu reset first, even after that it most likely wouldn't make much of a difference . There is nothing on our cars that can read the octane of the fuel in the tank.
Like what eggroll said basically |
#9 |
Member#: 104272
![]() I suggest you read what I said again. Esp the last part.
EJ257 how much HP can stock crank take? | BlackMagic*Club5 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 5 | 11-30-2005 10:00 PM |
18G + race gas, 23psi + stock tranny & clutch= | KCRex | Proven Power Bragging | 19 | 04-09-2005 04:01 PM |
How much boost can stock engine take? | ZapZilla | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 01-02-2004 11:18 PM |
How much boost can stock engine take? | Lightsped | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 10-28-2002 06:33 PM |
Race gas in stock WRX | SilverSubi | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 29 | 11-18-2001 07:58 PM |
