Welcome to the North American Subaru Impreza Owners Club Tuesday May 18, 2021
Old 03-02-2015, 04:57 AM   #1
tossty
Member Sales Rating: (24)
Member#: 22525
2006 Subaru WRX STI
Default Killer B Motor Sport High Flow Water Pump Housing
Well, I been looking for reviews on Killer B Motor Sport High Flow Water Pump Housing for long time but I have not find anything. If somebody have bought this part and got good results I would like to know.
This is the link from Killer B Motor Sport High Flow Water Pump Housing.
http://www.killerbmotorsport.com/ind...gsandTurbo.htm
I have installed their oil baffle and oil pickup and here are plenty reviews on this 2 parts but on the High Flow Water Pump Housing I don't find anything. I am looking into buying this part to increase the cooling capacity on my STI. I already have a Koyo radiator but thinking about better water flow to eliminate the bubbles will make it better since the OEM Water Pump Housing is kind of small on modify engines. If somebody did the installation on this and can provide results please post.
tossty is offline   Reply With Quote
Old 03-02-2015, 09:58 PM   #2
slide
Member Sales Rating: (1)
Member#: 1130
2013 STI Hatch
I have one. Make sure it comes with the new bolts. You can't use the stock ones. Also, you need to fab up or find a new hose...
slide is offline   Reply With Quote
Old 03-23-2015, 09:11 AM   #3
tossty
Member#: 22525
2006 Subaru WRX STI
Any improvement on cooling efficiency? Looking to install that on my STI to improve the cooling system, right now I have installed the Koyo radiator and Cosworth thermostat but if that will help to improve the water flow that be awesome. Supposedly according to Killer B site it will reduce the cavitation flow.
Old 03-23-2015, 11:01 AM   #4
slide
Member#: 1130
2013 STI Hatch
No idea really. I did it with a pretty major build. New everything.
I got it because The motor needed to spin pretty high under boost for a long duration and I figured it could only help.
If you get it, make sure it has the new bolts. If you're running anything but a stock radiator (even still I don't think the stock hose will fit then) prepare to spend some time hunting out a hose to connect the outlet and the radiator...
Old 03-23-2015, 11:53 AM   #5
tossty
Member#: 22525
2006 Subaru WRX STI
Ok, thank you for the information.
Old 12-27-2015, 02:18 PM   #6
leonbmx
Member Sales Rating: (50)
Member#: 82864
2005 MPS Wagon HTA35
Domtuned Stage $$$$$
So what hose did you end up using?
I am in the middle of the install, yet I can't seem to get any of the OEM hoses to fit? I'm trying to see if modifying them will work, but this shouldn't be this hard, I don't understand why they didn't provide the hose, if it turns out to be a custom one?
leonbmx is offline   Reply With Quote
Old 12-27-2015, 02:46 PM   #7
slide
Member#: 1130
2013 STI Hatch
I ended up cutting up two stock hoses and using a metal tube to link them. This would be a lot better if they would give an idea for a proper hose
Old 12-27-2015, 03:14 PM   #8
leonbmx
Member#: 82864
That's a great idea! Although it sort of reduces the advantages of having better flow, as now you are necking down the flow with that extra tube...
By the way, was your housing also more horizontal than angled down? I had to trim the fan surround in order to make the hose fit?
Old 12-27-2015, 03:55 PM   #9
slide
Member#: 1130
2013 STI Hatch
Mine is horizontal. I didn't have to trim anything but I'm using a Ron Davis radiator...
Old 12-27-2015, 03:57 PM   #10
slide
Member#: 1130
2013 STI Hatch
Old 12-27-2015, 04:03 PM   #11
leonbmx
Member#: 82864
wow! That's a good looking block!! Good to see that yours is oriented like that too.
Old 09-12-2017, 06:59 PM   #12
snwmbl
Member#: 436083
Whats the verdict on these for a race engine? They look good but do they actually improve flow?
snwmbl is offline   Reply With Quote
Old 04-21-2020, 07:51 AM   #13
KillerBMotorsport
Vendor Sales Rating: (43)
Member#: 198281
2005 WRX/STi
WRB of course
Sorry I missed this... 3 years ago
These are for high RPM applications when aeration on the suction side of the pump can occur; where RPMs are regularly going to be +6,500.
__________________
vs.
FA20 WRX Ultimate Oil Pickup, Now Available! Improving Pressure Consistency and AVCS Synchronization
KillerBMotorsport is online now   Reply With Quote
Old 02-11-2021, 11:46 AM   #14
stiaddict07
Member#: 522124
Just ran across this post. I noticed that the new one is cast aluminum and they said the hose fitment is easier.
stiaddict07 is offline   Reply With Quote
