Welcome to the North American Subaru Impreza Owners Club Thursday May 6, 2021
Old 08-28-2019, 08:27 PM   #1
Deadeye22
Member#: 479539
Default Arashi GRF TD06SL2 20G Ball bearing
I recently upgraded to this turbo so I thought I would share some of my findings.
Stock Car: 2018 STi AU Spec 220WHP
Stage 2: Processwest intake, RCM EL headers, Catted down pipe, 3 port - 273WHP
Current: Arashi TD06SL 20G BB, ID1000's, Turbosmart FPR, DW65C - 321WHP @ 20PSI
All power runs on same dyno.
This turbo spools like the stock car but laggy compared to stage 2 setup about 500rpm slower to make same boost but makes power all the way to the redline.
The only issue that I have had is slight boost creep that could be result of the wastegate preload being set incorrectly out the factory, will play around with it and see what happens otherwise I will port the wastegate port.
Hope this helps you
Deadeye22 is offline   Reply With Quote
Old 12-15-2020, 11:35 PM   #2
lowbee
Member#: 254317
2011 STi
Found this thread, it would be great if you can post a dyno and tell us how's the Arashi holding up.
lowbee is offline   Reply With Quote
Old 12-19-2020, 06:42 PM   #3
JDMRosa04
Member#: 504206
Good results
JDMRosa04 is offline   Reply With Quote
