#1 |
Member#: 37678
SCIC
![]() my car overheated a couple weeks ago. Took it to my mechanic, and the gasket was blown, radiator too.
I had received the TSB, and added the stop-leak since. My mechanic asked me what the brown gunk was in the radiator, if someone had added something to the fluid, and I told him I had added the stop-leak based on the TSB. He rolled his eyes, but didn't say anything. Anyway, it cost me $2500 to do the heads, radiator, timing belt, etc. Now I just saw that some people have gotten SOA to pay for head repairs because of the head gasket/coolant issue. What do you guys think? I'm definitely an affected car, but do you think they'll go for a reimbursement? I'm pissed, the head gasket shouldn't need conditioner, nor should the gasket and radiator blow at 90K. |
#2 |
Member#: 90347
AKIC
Vehicle:2013 BRZ & Imp 2.5RS Yamaha FZ8 |
![]() Well the TSB WWP-99 requires SOA additive which is not a brown gunk. Did you buy and add the stop leak from a Subaru dealership?
Plus the WWP-99 is a recall, extended to certain subaru model years only and has to be performed at a dealership to be reigstered for the extended coverage. Do you know for a fact the WWP-99 applies to your vehicle? And yes if the recall was done but the fluid was flushed and no SOA additive put back in, or something else put in. SOA can say no on the repairs. So... we need details. ![]() |
#3 |
Member#: 127247
MAIC
Vehicle:2015 Impreza DGM |
![]() i work at a subaru dealer and the wwp-99 does not apply to turbocharged engines (not sure what kind of car you have). even still instead of placing your own stop leak in there, you should have taken it to the dealer to check for any recalls or technical service bulletins to address the issue. although your car isnt involved with the wwp-99 subaru may have repaired it for little or no cost to you on a good-faith bases. its all case dependent. i doubt they will do anything now that it been repaired outside of a subaru facility and there was stop leak in the coolant
![]() also recalls and tsb have to be addressed the dealer. you cannot do your own repairs and expect it to be warranteed. and as far as gaskets and radiators if youve never had the coolant flushed or performed regular servicing on the car it is possible that can be a result. im not saying that you havent but lack of maintenance, heat and time are the 3 killers of parts on a car in that order! Last edited by akaGeneyus; 08-25-2008 at 01:55 PM. |
#4 |
Member#: 1847
Tri-State
Vehicle:Team Broken: V6 GF rallyarmor.com |
![]() Recall, not TSB they are two different things.
Did you buy Subaru Coolant Conditioner from a Subaru Dealer or did you go to the auto parts store and buy stop-leak? The Recall covered EXTERNAL head gasket leaks. If you had an internal leak, this would not have been covered by the recall. Has your car ever been to a Subaru dealer for maintanence? 90k miles, you have to take ownership of the car at some point. How long have you owned the car? Since new? If so if your car was involved in the recall you would have recieved a letter? Did you register your car on mysubaru.com, they would also send you emails reminding you about the recall. Did you look on NASIOC, that recall has countless threads posted. This is what happens when your take your vehicle to an independent who donesnt know about Subaru's or their common issues. |
#5 | |||||
Member#: 37678
SCIC
![]() Quote:
Take ownership of the car? No, Subaru should 'take ownership' of their mistakes. First, they ****ed with me over 6 visits about my clutch shudder, which was a known issue, then capitulated when I wouldn't go away; now, they engineer a problem head gasket/head/coolant compatibility issue, and give me a hard time because I didn't know to take it to my non-existant dealer for repair. I maintain it better than Santa Monica Subaru ever would have. Quote:
#6 |
Member#: 90347
AKIC
![]() I don't think you addressed my question of if you used SOA's stop leak or another brand. It has to be SOA and THEY have to be the one putting it in so they can register that with SOA. And they only do that if your VIN has the WWP-99 applied to it.
PM me the last 8 of your VIN and I can run it on SOA net (we dealer guys have this access) and we can see if it applies to you. |
#7 | |
Member#: 37678
SCIC
![]() Quote:
2G804743. Thanks, man. |
#8 |
Member#: 90347
AKIC
![]() well your good to June 2009 on the coverage or 100k. Which I think your under. You also have WVD-14 recall open on your.
Only guess is that they saw something in there that isn't Subaru. However external leaks with WWP-99 (which shows completed on subaru net) should have been covered. The brown gunk might have been their only reason. Shows either contaminated or poorly serviced coolant system. $2500 sounds kinda high. Even with a timing belt, the average job should only need cost $1300-1700. What did they do to the heads? If you haven't called SOA yet. I'd suggest it and see what they think. The dealership may not have even contacted them. |
#9 |
Member#: 63616
South East
Vehicle:1996 Volvo 850 Turbo with mods :) |
![]() I don't think that Subaru is going to help out on this one for a number of reasons.
1. The repairs were not made at a Subaru dealership with Subaru parts. SOmetimes this is not an issue, but major repairs like this seeking reimbursement should be done at a dealer. Subaru has no way to guarantee the repairs or parts and cannot assume they were even done correctly or if they were needed at all. (some independent shops sell you stuff you don't need..sad, but true) 2. You knew you had the WWP99, therefore it is your responsibilty to read the letter you were given, have the repair performed (which you said you did) and know that the warranty on the head gaskets is extended until 100K miles. 3. It's possible that the blown head gasket was a result of the radiator blowing and the engine over heating. This is not covered by the recall because it is resulting damage from the radiator. Again, Subaru has no way to know this. 4. Subaru conditioner is reddish in color and unless the cooling system was really dirty and lacked maintenance, it shouldn't be brown. The conditioner hardly changes the color of the coolant when the coolant is maintained properly. You are correct in saying that Subaru cannot mandate where maintenance on your vehicle is performed, but when it comes to a major repair, possibly covered by the warranty extension, they do have a say. They cannot deny you coverage for oil changes or maintenances done elsewhere, but they can deny to pay for a repair they might have otherwised covered, because you had it done somewhere else. Also, building a good repor with the dealer goes a long way. I have seen Subaru cover head gaskets on vehicles with 120K miles....Why? because they are paying back a customer for being loyal. Also, Subaru has taken responsibilty for this 'design flaw' and made amends to correct it. They cannot hold everyone by the hand and tell them that when their car overheats to take it to the dealer so they will cover it under warranty. That is the customer's responsibilty. You say a radiator shouldn't blow at 90K miles...I have seen some blow alot sooner. A radiator can blow out from something coming up in the road and putting a hole in it. 90K miles is not too early for a radiator to go out. If you really want Subaru to assist with the repairs, be prepared to have the maintenance records for the cooling system with the conditioner added handy to fax to them. Without them you don't have a chance. |
#10 | ||||||
Member#: 37678
SCIC
![]() Quote:
![]() Quote:
The gunk was reddish brown. Brownish red. Whatever. Quote:
2) Rep with the dealer? Sure, if I over pay by 100-300% or more for their ****ty service every time I need an oil change, they're going to fudge the paperwork. I'm not interested, nor should it be required, that I forge a relationship like that. Maybe I should buy the dealer recommended RE92's, too, for $180 a pop, because 'my suspension was designed around these tires, and my car won't perform at its optimum without them'. Yeah, right. Go search for 'Santa Monica Subaru' here, and you'll uderstand. Then drop the dealer leg-humping. Quote:
![]() ![]() Quote:
![]() Between the clutch shudder debacle, the chronic CEL (SM Subaru: "don't worry about it unless it's blinking", "we didn't find anything", "it's normal", "Just drive it until it's blinking"), and now this, I'm getting sick of dealing with Subarus ****ty service. |
#11 |
Member#: 127247
MAIC
![]() ^^spoken like a true subaru service advisor^^
which dealer you work @? |
#12 |
Member#: 127247
MAIC
![]() OP what kind of car do you have??? 2.5rs, or impreza outback sport? i know it says 2002 impreza but can you clarify?
nvm....checked your post history you have a TS Last edited by akaGeneyus; 08-26-2008 at 12:08 PM. Reason: update |
#13 |
Member#: 127247
MAIC
![]() OWNER NOTIFICATION LETTER
Subaru of America, Inc. Subaru Plaza P.O. Box 6000 Cherry Hill, NJ 08034-6000 www.subaru.com Service Program WWP-99 February 2004 Dear Subaru Owner: This letter is sent to you in the interest of continued customer satisfaction. As a precautionary measure, SUBARU OF AMERICA, INC. is recommending that a special conditioner be added to the engine cooling system of certain 1999 through 2002 model year Subaru vehicles equipped with 2.5 liter engines. This recommendation, which applies to your Subaru vehicle, is made to prevent a possible external coolant leak at your vehicle's engine cylinder head gaskets. BACKGROUND INFORMATION Your vehicle's engine cooling system contains liquid coolant/anti-freeze. Over time, it is possible for small external coolant leaks to develop at the engine cylinder head gaskets. This is the result of normal expansion and contraction of engine components caused by the heating and cooling of these parts. To prevent coolant leaks from developing or to correct existing leaks at the head gaskets, a special Subaru Cooling System Conditioner should be added to your vehicle's cooling system. WHAT YOU SHOULD DO You should contact your Subaru Dealer as soon as possible for an appointment to have the Subaru Cooling System Conditioner added at no cost to you. The approximate time to perform this operation is 15 minutes. However, it may be necessary to leave your vehicle the full day of your scheduled appointment to allow your dealer flexibility in scheduling. Please present this letter to your Subaru Dealer at the time this repair procedure is performed. FUTURE MAINTENANCE In the future, it will be necessary to add Genuine Subaru Cooling System Conditioner to your vehicle's cooling system whenever the engine coolant is replaced. The recommended service interval for coolant replacement can be found in your Warranty and Maintenance Booklet under the heading "Schedule of Inspection and Maintenance Services". As a reminder, we have included an update page that should be added to your Owner's Manual and Warranty and Maintenance Booklet. We ask you to keep in mind that replacement of fluids (including Subaru Cooling System Conditioner) during inspection and maintenance services is not covered under warranty. Bulletin Number:WWP-99; Date: 02/2004 Page 9 WARRANTY EXTENSION If you have this Service Program repair performed promptly, Subaru will extend coverage under the Subaru Limited Warranty on your vehicle for cylinder head gasket external coolant leaks to a period of 8 years or 100,000 miles, whichever occurs first. Warranty coverage begins on the date the vehicle was delivered to the first retail purchaser. If the vehicle was used as a demonstrator or company vehicle before being sold at retail, warranty coverage begins on the date the vehicle was first placed in such service. As a further condition for this extended warranty coverage to apply, you must have Genuine Subaru Cooling System Conditioner added to your vehicle at any subsequent cooling system services at the interval specified in the Warranty and Maintenance Booklet under the heading "Schedule of Inspection and Maintenance Services". Resulting damage caused by a lack of maintenance or low coolant level will not be covered. CHANGED YOUR ADDRESS OR SOLD YOUR SUBARU? If you have moved or sold your vehicle, please complete the enclosed prepaid postcard and mail it to us. IF YOU HAVE PREVIOUSLY PAID FOR A RELATED REPAIR In the event that you have already paid an authorized Subaru Dealer for repairs to remedy an external coolant leak in an engine cylinder head gasket at less than 100,000 miles and your Subaru's cooling system has been properly maintained, you may be entitled to reimbursement for the head gasket replacement costs. Any reimbursement by Subaru will be based on our suggested retail parts pricing and suggested labor time multiplied by the dealer's hourly labor rate at the time of repair. Because Subaru Dealers are independently owned and operated, Subaru of America has no control over the actual charges. The actual repair cost may be higher or lower than the rate used by Subaru of America to calculate reimbursement. If lower, reimbursement will be limited to the amount you actually paid. Please send the original service repair order, which has complete information including the name of the repair facility, date of repair, mileage at the time of repair, complete vehicle identification number (17 digits), and your name, with correct mailing address and telephone number to the address listed below. Subaru of America, Inc. Customer Dealer Service Department Attention: Service Program WWP-99 P.O. Box 6000 Cherry Hill, NJ 08034-6000 Please send original receipts only and retain a photocopy for your records. Please be assured that we will attempt to process your reimbursement request as quickly as possible, but may take up to 120 days for this process to be completed. Last edited by akaGeneyus; 08-26-2008 at 12:36 PM. |
#14 |
Member#: 127247
MAIC
![]() The highlighted areas above will be the defining factors in this case. if you recieved this letter (mailed in 2004) which sounds like you did the recall would need to have been addressed at that time. the place doing the repairs needed to be an authorized subaru dealer and it needed to be for external leaks only!! plus it states to update your address with subaru whenever you change so you can be sent TSBs and recalls. the car should have been taken into a dealer to have the conditioner placed into the system. thats listed under the what you should do section
hope this helps and BTW i did read up on that santa monica dealer seems as if there was more bad than good coming from that place GOOD LUCK! Last edited by akaGeneyus; 08-26-2008 at 12:40 PM. |
#15 |
Member#: 37678
SCIC
![]() Yeah, thanks aka!
#16 | |
Member#: 63616
South East
![]() Can you elaborate on this a little?
#17 |
Member#: 37678
SCIC
#18 | |
Member#: 63616
South East
![]() Quote:
Subaru cooling systems are not supposed to be 'flushed'. THey are only to be drained and refilled. A coolant flush machine is not to be used because other coolants mix in the machine and can cause a chemical reaction. This is probably why you had the 'reddish brown' fluid in the cooling system. And before you go saying Subaru is the only one that requires this, check out Suzuki or Honda that requires a special coolant that if mixed with other coolants will turn to gel. Hopefully Jiffy Lube is not your regular mechanic. Second, you say that dealerships are expensive, but you have seen 2 quotes on here, from dealerships, that are cheaper than what you paid. Plus, if you had taken it to the dealer you wouldn't be paying for anything anyway. If your mechanic is 'so good and trustworthy', then he would have known about this issue and would have sent you to the dealer. Like you stated, this is a known issue so everyone should know about it. And when Mavrick mentioned not spending a dime at the dealership, he didn't mean buying the car...he meant taking it in to service to people that are trained to work on your vehicle and know the service bulletins and TSB's and how to properly repair something. And if they don't they have someone to answer to.....Subaru. Everyday advisors like me see people take their vehicle somewhere else to save a buck and end up spending more to correct the problem someone else created. Okay, we get that the dealers in your area weren't the greatest and they closed up shop...Why do you think that is? Because Subaru cracked down on them and I bet if you go there now you would see a big difference. But, for some reason, you have a vendetta against dealerships and nothing anyone can say will change your mind...for now. Until that one problem happens and they need to 'save' your vehicle. Something funny to watch.... http://www.youtube.com/watch?v=LTJjqr0QbIk Hope you didn't take your car to one of those Jiffy Lubes |
#19 | |
Member#: 10309
NWIC
Vehicle:'02 OBS 2-tone! White |
![]() Quote:
OP: I agree with a lot of what you've posted. However, you did make one big mistake, which was not to let a Subaru dealer have a look at it, either initially or once you got the diagnosis (but before the work was done). The reason is this: you're essentially asking for a problem to be covered under warranty. In order to get that, you've got to give Subaru (i.e. one of their authorized dealership service depts) a chance to fix it themselves, not just hand them a bill. I'm not sure if you have a Subaru Gold Plus extended warranty, but that covers towing to the *nearest Subaru dealership* in case you have a breakdown. It wouldn't have hurt anything to have your trusted mechanic hold onto the car for another day before starting work while you contacted Subaru to find out about any warranty coverage. Not knowing about possible warranty coverage is one of the potential drawbacks of using non-dealership service while not keeping full track of recall/campaign notices yourself. |
#20 | ||||
Member#: 37678
SCIC
![]() Quote:
http://forums.nasioc.com/forums/show...ighlight=herky And no one said anything here, either: http://forums.nasioc.com/forums/show...hlight=%242500 Quote:
![]() It isn't rocket science or magic. ANY qualified mechanic can take care of a Subaru, especially a head job. Conversely, there's a good reason there's overwhelming negativity toward dealers, and not just Subaru. They tend to be scamming bull**** artists, and my whole area is case in point, maybe yours is unusual. I had direct experience with SM Subaru ****ing me over and feeding me bull****. It's not a vendetta, I'm not sitting outsidewith a sniper rifle; it's a simple logical response to being ****ed with. As for Mavericks comment, the more I think about it, and your response above, the more it pisses me off. I spent $13k on a Subaru because I thought it to be a well engineered, reliable vehicle, which suited my needs. I bought my car 200 miles away, in San Diego. So should I be loyal to their service dept? SM service dept (hold on, let me apply the Vaseline, AHHHH, BABY)? Or maybe I could bring my loyalty your way? Your thinking is flawed; by your criteria, if I buy new, I should receive better service than if I buy used, as I spent more money and show more loyalty and trust. What if I do all service at SM Subaru for years, religiously, then move to your neighborhood, and my head gasket blows? I've shown you NO loyalty, so I'll expect crappy service in return. Jesus ****ing Christ. As if I need to EARN the TRUST of the DEALER! BwaahaahaaGAG. At least we know you like Koolaid. As much as you'd love to make it my fault, and pick apart my after-action report, critique my post-apocalypse performance, the fact is IF Subaru hadn't designed faulty head gaskets, and IF they hadn't only affixed a band-aid solution, I don't believe my car would've been in the shop, or there'd be anything to talk about here. |
#21 | ||
Member#: 17355
![]() According to Subaru bulletin 09-47-07:
#22 | ||
Floresbian
Moderator Member#: 470
South East
Vehicle:2000 Legacy B4 RSK 2020 Canyon Denali Diesel |
![]() Quote:
![]() http://www.knbc.com/news/8881193/detail.html Quote:
Maintanance of you vehicle is your responsibility, not Subaru's. If something you (or your mechanic[s]) did, or forgot to do caused a failure it's on you. Those who follow Subaru's maintenance guidelines and use genuine parts have many less failures than those that don't. As for the head gaskets, improper coolant type, improper flush machines, improper fluid change intervals can all compromise any head gasket. I your case (from what you've written) I'd bet that the failure was caused by overheating the car due to the failed radiator. Aluminum engines from any manufacturer do not handle overheating well, the majority will have head gasket problems at the same time or shortly after. Failures from overheating are not covered by the extended warranty. |
#23 | |
Member#: 63616
South East
![]() Quote:
There are 6 dealerships within a 30 mile radius of Santa Monica Subaru....maybe more closer to you depending on your zip code |
#24 | |
Member#: 37678
SCIC
![]() Quote:
Yeah. Last edited by poison; 08-26-2008 at 05:40 PM. |
#25 |
Member#: 90347
AKIC
![]() Funny how people never want to spend a dime at a dealership but want everything for free from them anyway. Not all dealerships are evil. I know and believe the one I work at isn't. We actually get a lot of "can you fix this?" issues other repair shops caused or could not solve.
I still think $2500 for headgasket work is to high. what exactly did your tech do again? Oddly enough in todays market, most dealerships are average/the same prices as most shops. Sure some dealerships can't do a darn thing right but that doesn't mean they all are. I could bet money confidently that if a SOA repair facility did your services, had your records and you brought this in to them to fix... it would have been for free. |
TSB wwp-99 and my car | poison | Off-Topic | 2 | 08-23-2008 08:02 PM |
sum photos of Solbergs 03 WRC car and my car OMGXORZ | kingleh | Member's Car Gallery | 42 | 06-01-2005 04:20 PM |
My Latest Mod and my car turns 100K today! | Firewire | Vancouver Impreza Club Forum -- VIC | 2 | 04-12-2005 11:10 PM |
i think my exhaust and my car hate me (constant exhaust leak help!) | Supaboom | Mid Atlantic Impreza Club -- MAIC | 0 | 06-19-2004 06:41 PM |
pictures of my motor installed and my car | STEALTH-WRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 29 | 05-21-2003 12:08 AM |
