#1 |
Member#: 540160
Vehicle:2019 Impreza Manual |
![]() I pressed the button that turns on the skidding tire icon on the dash with "off". But when I spin the tires, I get an identical pop-up in another part of the dash with the same icon. Anyway to completely turn off traction/stability control?
#2 |
Member#: 477540
MAIC
Vehicle:2015 WRX Premium WRB |
![]() Check if your owner's manual instructs how to turn it off completely. Owner's manuals can be surprisenly helpful sometimes.
Not sure about your '19 Imprezza, but in my '15 WRX I hold the traction control button as it cycles through trac mode, until it sayf off, then I release the button. |
#3 |
Member#: 428511
Vehicle:2016 STI |
![]() usually traction control and stability control are two different things controlled by the same button.
I can't remember how my STI worked but my other two cars that have it both need you to push and hold that button. Initially just one turns off, but if you hold it down after a few seconds the 2nd one will turn off also |
#4 |
Member#: 180111
MAIC
Vehicle:* 2004.114.3 STi Aspen White |
![]() What is this magic you speak of???
#5 |
Member#: 540789
![]() In my 2015 WRX,to deactivate traction control, you press the button without holding it down. The skiddy mark will come up on the dash with another light in green that reads Trac Mode. This mode is like 90% traction control off. The second mode of turning it off is by holding it down for 5 seconds. In this mode it turns the traction control COMPLETELY off and you won't hear any brakes dragging while doing skids. I hope this helps.
Last edited by ShermSMASH; 04-11-2025 at 12:06 AM. Reason: Forgot to specify my car type |
