Welcome to the North American Subaru Impreza Owners Club Tuesday June 17, 2025
Old 03-04-2025, 12:01 PM   #1
zkhennings
Member#: 393895
2002 Impreza WRX
Default The most r******* rust repair you have ever seen
Warning: Do not do this, I did not realize the extent of my rust until it was too late.
Car: 2002 WRX
Miles: 330,000
Total # Engine Rebuilds: 3
Total # Engine Replacements: 3
Total # Transmission Replacements: 1
Value of car: $1500?
For the rust repair, I have only spent about $400 on materials.
It has taken about 150 hours so far.
Goal: To have a winter vehicle for going to the mountains/dirt bike tow rig that I can get 5+ more years out of. I have been working on it, modifying, and tuning it for 11 years. Mechanically in excellent shape. Just rusty. But I love my WRX. This is a love story.
Just prior to beginning all this rust repair.
Oh I will just chuck these new rear quarters on and patch the rocker panels
Start digging...
Yikes.
zkhennings is offline   Reply With Quote
Old 03-04-2025, 12:56 PM   #2
Gixhost
Member#: 180111
* 2004.114.3 STi
So glad you're posting this. It is truly a reality for vehicles that are driven and used. Especially so in regions prone to accelerating rust. This reminds me of the recent Subie Sanctuary rust wars videos. I love watching them tackle rusty Subaru issues. GL! I'll be following.
Gixhost is offline   Reply With Quote
Old 03-04-2025, 01:26 PM   #3
zkhennings
Member#: 393895
2002 Impreza WRX
Let's find some good metal.
Ok, the plan:
Old 03-04-2025, 01:30 PM   #4
zkhennings
Member#: 393895
2002 Impreza WRX
Gotta fix a few spots before welding in the 3"x3" tubing.
Making spacer plates to tie the tubing to the chassis, these took forever to make ensuring that the tubing was in there perfectly level in all directions and square to the chassis.
Old 03-04-2025, 02:24 PM   #5
zkhennings
Member#: 393895
2002 Impreza WRX
Test fit complete on one side, time to get everything dialed in and symmetrical.
This is going to be fun to repair...
Removed test fit pieces, and removed all the original extra bracketry that tied to inner rocker panel, and cleaned everything up for final welding.
Phosphoric acid jelly to kill any light rust, and spot up front to repair on passenger's side before the tubing prevents access.
Little spot in the back
Old 03-04-2025, 02:30 PM   #6
zkhennings
Member#: 393895
2002 Impreza WRX
Brackets tacked in in final locations.
Fits perfectly.
Final bracket to fabricate, since both up front spots were repaired, they needed special geometry parts.
Starting final welding after everything checks out.
Final test fit on passenger's side after brackets fully welded to chassis.
Tubing was then prepped and epoxy primed in all the areas that will be hard to paint once installed. Tubing was then welded in. Note the stitch welding to the inner outer rocker you can see below the doors.
First time the car has been on jack stands on the rocker panels in three years.
Old 03-04-2025, 02:32 PM   #7
Jack
Add Lightness
Member#: 13699
2021 Building
It Better
This is great work to see you doing. If you don't already know about the Youtube channel Yorkshire Car Restoration, it will give you hope. They do work on cars that look 10 times as bad as yours, sometimes similar mundane, regular cars. Lots of E30 3 series (non M) and the like. They do just like you, cutting out the bad metal, fabricating new and welding in. It's a lot of work but with the cost of new cars, it's almost always worth keeping a car going these days.
Old 03-04-2025, 02:53 PM   #8
zkhennings
Member#: 393895
2002 Impreza WRX
Thanks, I will have to check them out!
Old 03-04-2025, 03:14 PM   #9
Gixhost
Member#: 180111
* 2004.114.3 STi
I thought I was going to have to wait to see more. Incredible work!
Old 03-04-2025, 10:45 PM   #10
cmiovino
Member#: 134005
2004 WRX Premium
I'm kinda here with my 2004 WRX. Had it since 2012. Love it. Rockers are rusty as hell. I've "patched" them with fiberglass bondo and some backing metal. It's been holding for years, but I've been wanting to get it fully redone. Just thinking of removing the side skirts scares me.
... this has me rethinking things.
Old 03-05-2025, 07:12 AM   #11
zkhennings
Member#: 393895
2002 Impreza WRX
Check up in the rear wheel wells, there is a wall in the inner fender up near the top where it always rusts out and then lets water get into the rockers and the strut towers and the rear quarter panels. How bad your hole is there is a good indication of how bad it will be internally. I repaired my rust spots several times over the years welding in new metal. I never got the chance to really properly fix the hole in the inner fender I am referring to, I fiberglassed it shut a few times but it never held long term.
Here’s a link to an early repair on this car, I have done some extensive repair several times but never documented it.
https://forums.nasioc.com/forums/sho....php?t=2747055
Old 03-05-2025, 01:53 PM   #12
Jedi03
Member#: 491095
2009 STi Blue
i appreciate that you are not only keeping a good car on the road but keeping it safe...i see to many deathtraps on those mechanical nightmare videos...
Jedi03 is offline   Reply With Quote
Old 03-05-2025, 08:34 PM   #13
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Like,
Old 03-11-2025, 09:17 PM   #14
zkhennings
Member#: 393895
2002 Impreza WRX
Thanks guys, I am picking the car up tomorrow, hopefully doesn't break down after not really being driven for a year.
Old 03-13-2025, 07:08 AM   #15
zkhennings
Member#: 393895
2002 Impreza WRX
She's home, made it the 2.5 hour drive without any problems. Was a little rough for the first 45 minutes after not being driven for over a year, but the brakes wore back in, and the engine smoothed out a lot. Here are some pics I snapped of the repairs painted and seam sealed.
I picked a warm dry week to drive it home to avoid salt and water getting sprayed everywhere, however when I drove past Worcester I hit a massive snow squall. The picture does not do it justice, I could not see at all for about a 10 mile stretch.
Old 03-14-2025, 06:51 PM   #16
Gixhost
Member#: 180111
* 2004.114.3 STi
Awesome glad you made the drive!
Old 04-13-2025, 05:04 PM   #17
Dan4451
Member#: 377694
2002 full 207v7 swap
I need to do this to my 2002. Nice job patching this up.
Dan4451 is offline   Reply With Quote
Old 04-25-2025, 02:30 PM   #18
500_19B
Member#: 524021
2021 STI
2002 WRX, 2023 Crosstrek
Excellent work! I have a bit of an idea what you went through, as I spent last summer welding in 16 square feet of sheet metal to my brother-in-law's 1997 Buick Regal, which also had completely disintegrated rockers. I ended up forming repair parts with a sheet metal brake (in the driveway) and it worked OK, but I really like your approach of using the strong HSS tube.
A very well conceived and executed job. Looking forward to seeing the evolution.
500_19B is offline   Reply With Quote
