Welcome to the North American Subaru Impreza Owners Club Monday June 23, 2025
Old 12-10-2001, 04:28 PM   #1
BrysImpreza
Member#: 3102
2018 Mazda CX-5
Storm Trooper White
Default Is there a big difference between a 97' L and 99 RS suspension?
I wanna know if putting a stock 1999 Impreza RS suspension on my 1997 Impreza L is worth bothering with?
Is there a big difference in spring rate, struts and overall ride?
Thanx!
Bry.
BrysImpreza is offline   Reply With Quote
Old 12-10-2001, 05:18 PM   #2
m750
Member#: 2278
8Sti | 07 allez
White | Comp
they will fit, and yes there is a difference.
AO
m750 is offline   Reply With Quote
Old 12-10-2001, 06:39 PM   #3
cardin555
Member#: 9972
2007 Jetta
grey
There is a difference, but not much. You didn't say how many miles on the RS suspension? If yours is worn out, you may notice a greater difference.
cardin555 is offline   Reply With Quote
Old 12-10-2001, 06:58 PM   #4
BrysImpreza
Member#: 3102
2018 Mazda CX-5
Storm Trooper White
Thanx for the input, but I think I'm gonna go all out and actually spend some cash, get some KYB AGX's and some Ground Control Coilovers, the sure fire way to make a difference
Bry.
Old 12-11-2001, 12:32 AM   #5
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
The Ver.5 Struts although not adjustable, are much more superior to the AGX's. (Cheaper too)
I would go with a custom spring rate of 180 in the back and around 210 or 200 in the front. The savings you made on the the struts can go towards calling up GC and get your stuff customized.
WRXwannbe is offline   Reply With Quote
Old 12-11-2001, 12:46 AM   #6
MPREZYA
SCIC
Member#: 85
Eli you do realize the v5 strut doubled in price as of recently. Sugar even tried to organize another group buy at the old price and she had no luck.
Go with the KYB/AGX and Ground Control (I was one of the first to get them) they work great and cover the same adjustability range of the DMS but not as fine tuneable. It's the best "poor man's" coilover money can buy just don't get a spring rate higher than 300f/250r or 315f(only available in 9" length)/275r. You will lose almost all adjustability of the shock to match the spring rate leaving you to drive around daily with the shocks set to 3f/8r like alot of people had to. I went with 275f/225r 8" springs (you could try 250f/200r) and for daily driving I run the shocks at 2f/4r (any lower and the car gets jittery from the springs being to stiff).
Rich
MPREZYA is offline   Reply With Quote
Old 12-11-2001, 12:59 AM   #7
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Rich I did not know, Sumimasen desita
Yea, listen to rich.
Is there a big difference between Rota's Gunmetal and steel grey? kenny08 Tire & Wheel 2 03-30-2005 03:37 AM
Is there a real difference between VF30 and VF34? Trevor723 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 07-14-2004 08:57 PM
Is there any big difference between Unichips? Schleppy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-28-2002 02:50 PM
Is there a big difference between the Vishnu Stage 1 & 2? ChrisWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-24-2002 11:05 AM
Would there be a big difference between using Mobil 1 and Castrol Syntec? V6 Normally Aspirated Powertrain 17 05-05-2002 06:02 PM
