Welcome to the North American Subaru Impreza Owners Club Tuesday June 17, 2025
Old 03-05-2003, 11:31 PM   #1
AdmireWantWillLove
Member#: 24146
2004 GTO
Default Speakers and Stock Head Unit
I am not looking for anything Fancy... just something that will sound good. I want to keep my stock head unit and NOT add an amp or anything... heres what I was thinking:
Front: 6 1/2 Infinity Kappa
Rear: 5 1/4 Infinity Kappa
Doesnt the WRX Sedan have tweeters in the doors???
Please help me out on what I should get... thanks!
AdmireWantWillLove is offline   Reply With Quote
Old 03-06-2003, 10:26 AM   #2
c_hunter
Member#: 32434
05 Outback XT 5EAT
Gold/Black
Default Here's what I did
Stock head unit.
Put in Rockford Fosgate 6.5" speakers up front, 4" in the rear. The way the car is set up, I couldn't really hear the rear speakers from the driver's seat, so I decided not to mess with putting 5.25" in the rear (since it involves a little cutting). The 4" speakers fit in the rear without any fuss, and help fill in the sound.
Mounting 6.5" speakers in the front required fabrication of a spacer ring (3/8" thick for the Rockfords). Overall, it was not a difficult install, just took some time getting everything to fit.
I also applied dynamat to the inside of the door panels, right behind the speakers. It helps quite a bit.
Compared to the stock speakers, the sound is much, much clearer. But, there was not a whole lot of bass. So, I added a factory sub under the passenger seat, and the system sounds great now. It is not real loud or a real thumper, but it's about perfect for my needs.
Down the road, I may add an amp, but I'm happy for now.
To answer your questions: yes, the Infinity speakers are good. There are several grades of Infinity speakers; skip the bottom of the line. Yes, the car comes with tweeters in the front doors. I don't think they are very good, but if you are adding a 2-way or 3-way speaker to the front doors, you will have more than enough high frequency with all those tweeters.
You could probably swap a higher quality tweeter into the door, but I don't think the placement is ideal, so it might not make a whole lot of difference. Tweeters would sound better up near the mirror trim, if you could mount and aim them properly.
Craig
c_hunter is offline   Reply With Quote
Old 03-06-2003, 10:29 AM   #3
Roo
Member#: 14931
Default Try these
I like the sound of the MB Quart setup, or the a/d/s setup.
www.mbquart.com
http://www.mainstreet-audio.com/ADS/ADS_speakers.htm
Roo is offline   Reply With Quote
Old 03-06-2003, 10:32 AM   #4
c_hunter
Member#: 32434
05 Outback XT 5EAT
Gold/Black
Default one more thing
Before adding the sub, bass was weak as I mentioned and the speakers started to distort if I turned the bass up. Probably more a function of the low power of the factory radio than anything else.
Anyhow, with the sub, I can keep the bass setting on the radio between -1 and +1, which keeps the speakers sounding clean. By upping the gain knob of the sub, I still get plenty of bass out of the subwoofer.
So, it all worked out to be a decent combination.
Craig
Old 03-06-2003, 01:57 PM   #5
Sunkist
Member#: 26387
2002 2.5 Hybrid WRX
Platinum
I got Infinity Kappas in my car right now with the factory head and they made a huge improvement but I still want better so I am getting a new head unit down the road. I have 5s in the front and 4s in the rear because I got them before I had my car and I didn't know what would fit, everyone and every site says different things so I had to guess. You should like it with just what you have.
Sunkist is offline   Reply With Quote
Old 03-10-2003, 11:40 AM   #6
itWoRX
Member#: 21305
2002 WRX Sport Wagon
WR blue
Something I think I have noticed......the factory head unit (which I still run) seems to have a "auto-loudness" that likes to interfere too much.....I cant keep the bass pounding good when I start to crank it.....I have a line level adapter feeding a single channel RF 150 that feeds a bazooka tube.....and it sounds decent and fills the low end decently, but when I start to get the volume up, the thump semms to diminish......I think the factory head units shunts the low frequencies faster that an aftermarket head unit (probably to prolong the life of the junk factory speakers).....any comments?
itWoRX is offline   Reply With Quote
Old 03-10-2003, 11:52 AM   #7
Mulder
Trust no one
Member#: 11170
13 Mini MT
15 WRX/11 CRZ
Auto-loudness is a common feature on low-power factory HUs. It makes them sound more powerful than they really are and gives the sound an artificial fullness at lower volumes. Unfortunately there is nothing you can do about it.
I replaced my HU because of this and also the poor frequency response and dynamic range in the radio section. Better speakers can only help so much when they don't have enough to work with.
wts/stock bpv and stock head unit 1_bad_subie Tri-State Area Private Classifieds 3 06-21-2008 12:06 AM
Replacement speakers for STOCK head-unit Obsessive Car Audio, Video & Security 35 02-20-2008 08:54 AM
decent speakers for stock head unit? IAMREX Car Audio, Video & Security 15 11-27-2007 11:01 AM
Stock speakers and aftermarket head unit affinity1 Car Audio, Video & Security 11 12-12-2005 04:55 PM
Bazooka tube install and stock head unit question Silky Car Audio, Video & Security 1 08-30-2002 03:40 AM
