Welcome to the North American Subaru Impreza Owners Club Saturday September 22, 2018
Old 08-23-2017, 01:23 PM   #1
Chad04STI
Member#: 473280
2004 Impreza STI
Default v8 ej207 in a 2004 Impreza STI
I just bought the long block to replace my blown ej257, I am looking to use the FULL 207 and I already know about the throttle by wire vs electronic, and cam senors. Am i able to grab the cam sensors off of the 257 heads? and what other problems will come up in this swap? Looking for people that have done this swap or are informed on the subject to respond. Not hate.
Update: I have a shop that is willing to do the swap still want to know what problems they will run into.
Engine purchased - https://www.jspecauto.com/engine_det...-and-down-pipe
Chad04STI is offline   Reply With Quote
Old 08-25-2017, 04:43 PM   #2
Seahawk
Member#: 71665
1994 Impreza
Version 8 is drive by cable, not DBW. No need to swap cam sensors or any sensors. Downpipe will need to be lengthened to meet your midpipe. Upstream O2 sensor will need to be relocated to behind the turbo in the downpipe.
Wiring should be straight forward since your harness already is wired for AVCS if I remember right.
Tons of info in the EJ207 owners thread in the 2.0L engine subforum.
Seahawk is offline   Reply With Quote
Old 08-28-2017, 02:45 PM   #3
Chad04STI
Member#: 473280
2004 Impreza STI
Thank you!
Old 09-06-2017, 12:56 AM   #4
shopwizard
Member#: 386578
Chad04STI How did the swap go? Were there any other goodies that the shop required for the install?
I just lost a piston skirt in my '04 WRX and really want to do this same swap.
thanks
shopwizard is offline   Reply With Quote
Old 09-06-2017, 11:47 AM   #5
Chad04STI
Member#: 473280
2004 Impreza STI
I'd say our swaps are completely different and to really do your research on your ecu, wiring harness, throttle body, and the version of ej207 that would fit best into your car and that it should be a lot easier than my experience because the 04 sti USDM isn't very similar to the 04 wrx in those areas!
Old 09-07-2017, 01:33 PM   #6
Seahawk
Member#: 71665
1994 Impreza
thanks
Swap would be about the same but you would either need to run 2 sets of 4 shielded wires for AVCS or run 1 set and repin the TGV wires for the AVCS.
Old 09-07-2017, 05:06 PM   #7
H_wells3000
Member#: 322035
USDM VS JDM CAMS HAVE DIFFERENT AVCS pickups and signals (up to version 9)
If you want to run your usdm ECU. You will have to put in your usdm cams and cam sensors. Putting your usdm sensors in jdm heads will require a little massaging to be spaced from the cam appropriately.
If you want to run all the jdm stuff the way its assembled. you must also run the v8 JDM ecu and sort the wiring out.
you need to research running a 32bit ecu with a jdm motor. most of those ej207 threads are swapping 2.0 wrx's and its a different can of worms vs your 04 sti.
H_wells3000 is offline   Reply With Quote
Old 09-11-2017, 02:17 PM   #8
Chad04STI
Member#: 473280
2004 Impreza STI
How we made the swap work: First we made an adapter plate for throttle body and drilled the cam sensors, as well as custom down-pipe to meet my mid pipe and pulled some wiring from the 257. If you have any questions on what additional parts or the process for the swap just ask and I'll post a thread but long story short I threw an additional $1,600 in supporting parts.
