Welcome to the North American Subaru Impreza Owners Club Wednesday December 12, 2018
Old 09-28-2017, 11:17 PM   #1
Tim McCreary
Member#: 348782
Default 2008 Impreza 2.5i in a 2006 Legacy 2.5i SE?
Can anyone give me some direction. I have a 2009 Impreza 2.5i drivetrain and was thinking of buying a 2006 Legacy with a blown motor with a good body nearby. I am assuming that the short block is interchangeable with no problems. The motor is toast and the heads may be bad.
My questions are:
Can I use the Impreza heads with the Legacy intake and ECU? I know they are different, but donít know the specifics. They are I-AVLS heads. Is there any sensors or wiring that needs done for the heads? I think the 2006 has I-AVLS heads from what I can find also.
Can I use the Impreza intake if I use the Impreza ECU? I assume this may not work with the legacy transmission. I wonder if the pinout on the plugs are the same.
Can I use the Impreza transmission using the ECU and AutoECU? What pitfalls will I run into?
Any help is appreciated.
Thanks,
Tim
Tim McCreary is offline   Reply With Quote
Old 09-28-2017, 11:21 PM   #2
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
I made a thread on how to use the 08-12? Legacy sohc engine in the 06-07 impreza sohc cars, may be the same thing as yours. I'd link it but the other times people have ignored so just search my threads.
2slofouru is offline   Reply With Quote
