Welcome to the North American Subaru Impreza Owners Club Tuesday April 16, 2024
Mid Atlantic Impreza Club
Old 03-24-2006, 10:23 AM   #26
Xechs
Member#: 7251
2018 Outback 3.6R
Grey
I had this on my '02 WRX, in cold weather it would reak of gasoline in the cabin if you turned on the heat (started happening like 2-3 years after i bought it). You can see on the engine block if it's leaking pretty easily, should either appear "wet" or there may me a clean spot where the gas has cleaned off the dirt on the engine. I tried tightening the lines and didn't really have much luck with this, seemed to help a little bit but never went away. Since this is a TSB if you are out of warranty they won't do this for free, i think the subaru service runs between $400-$500. I just sucked it up and bought the perrin fuel rails and had them installed (you have to pull the manifold off to install them and EVERYTHING is attached to the manifold it seems). But i'm much happier now that I don't have to deal with it anymore. You may also want to check your fuel filter and connections there if you think it's comming from the driver's side.
Xechs is offline   Reply With Quote
Old 03-24-2006, 10:28 AM   #27
saint_foo
Member#: 64364
^ Yep. I'm surprised that you smelt it today and not earlier in the winter. I've smelt it in the cabin and was worried a few times until I read some threads in the technical forums.
I also thought that maybe I got some gasoline on my hands when pumping gas, touched the inside door, steering wheel, shift knob, etc. and didn't notice it at the time...but with a fresh pair of nostrils the next morning, it was noticeable. Meh.
saint_foo is offline   Reply With Quote
Old 03-24-2006, 10:45 AM   #28
Jard
Member#: 34935
Dad- Core
OG
Good info...
Time for upgrades?
Jard is offline   Reply With Quote
Old 03-24-2006, 10:46 AM   #29
ShannonO
Member#: 78041
Originally Posted by Jard
Good info...
Time for upgrades?
You gotta do what you gotta do...
ShannonO is offline   Reply With Quote
Old 03-24-2006, 10:56 AM   #30
VipersEatLotus
Member#: 21007
Originally Posted by VipersEatLotus
i have only had it bad once and then it went away...way back when i first had my car.
only happens on cold morning it seems.
some say it is the fule rails, that if you replace those you will be just fine.
http://forums.nasioc.com/forums/show...as+smell+cabin
can i have the red hazard button?
and how is this not good info? i even sent you the big as thread about it...i said the same thing he did with not so many words. asshat!!!!!!!
but "no thanks dave!!!!"
we are soooo fighting...i might not even come to your cookout!!! hmmmph
VipersEatLotus is offline   Reply With Quote
Old 03-24-2006, 10:57 AM   #31
jetwagon
Member#: 59872
2004 Impreza WRX
Lift left-outter cheak and inspect for leaks in das pooper?
Didn't you just finish installing a drivers-side flamethrower option on her car?
Oh noes your NOZ is leaking!!!
Thank you "Capt. add nothing to the thread" guy.
I see how it is.
jetwagon is offline   Reply With Quote
Old 03-24-2006, 11:00 AM   #32
BryanH
Member#: 993
I see how it is.
edit your profile and you will get less crap.
BryanH is offline   Reply With Quote
Old 03-24-2006, 11:02 AM   #33
mattpreet1
Member#: 73230
'03 Silver Bugeye
B*atch!
Yeah I smelled it in early Feburary when it was really cold. I only smelled it for about 2-3 min. (or at least got used to it) while crusin' on 66. Haven't smelled it since that morning though (knock on wood ... oh crap, everything here is plastic ... CRAP!)
mattpreet1 is offline   Reply With Quote
Old 03-24-2006, 11:15 AM   #34
Jard
Member#: 34935
Dad- Core
OG
I see how it is.
I expect nothing buy mindless dribble from those guys.
Old 03-24-2006, 11:16 AM   #35
Jard
Member#: 34935
Dad- Core
OG
He provided words that I could read right in front of me. You provided a link to another thread where I have to read and search for info.
His reply > Your reply
*whaaaaaaaaaaambulance*
Old 03-24-2006, 11:19 AM   #36
fantabulous
Member#: 57364
99 m coupe
01 z3 coupe
i had a similar situation. but it was my fuel filter out line clamp being loose. also there is a small hose on the fuel rail that goes under the intake manifold on the drivers side. the clamps were loose.
fantabulous is offline   Reply With Quote
Old 03-24-2006, 11:22 AM   #37
D_Block
Member#: 64127
2001 PY ITR, 2012 X5
on order
I believe that I was the first to say do a search n00b!!
So Dave, quit whining
Noone listens to Gurus anymore!!!
D_Block is offline   Reply With Quote
Old 03-24-2006, 11:33 AM   #38
lotusdrift
Member#: 24308
Oh, **** it
I'm gonna have a party
wait, you didn't look at the TSB as the very first option? I had too much faith I see....
don't worry dave, people never listen to me, I don't know why I try
lotusdrift is offline   Reply With Quote
Old 03-24-2006, 11:35 AM   #39
VipersEatLotus
Member#: 21007
dylan i am not talking to you till you give me my 50 bucks back or till you actually buy a car...
Old 03-24-2006, 11:51 AM   #40
D_Block
Member#: 64127
on order
I SAID IT FIRST!!! DOH!!!!
And Dave, that money was already spent on booze and dirty strippers...
Lisa Fleming, so hot or not so much? rice h8r Off-Topic 37 05-28-2007 02:19 AM
Gas smell coming from alternator and a check engine ansonb505 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-17-2007 08:38 PM
Gas smell that is not related to cold weather ImpreziveWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-08-2006 08:41 PM
I like what you've done here, and here, but not so much here...... Ripper Off-Topic 12 12-13-2003 07:21 PM
Not knowing much about engine design, I have this question. redoktober_99 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-14-2002 08:43 AM
