06-20-2014, 07:16 AM | #126 |
Member#: 90539
South East
Vehicle:My BOV goes COVFEFE! |
Seems like it would be the reverse but maybe there is another factor with the oils that isn't being considered. Either that or a bad batch of 15/40
06-20-2014, 09:31 AM | #127 |
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
^ highly improbable. Unless some one put the wrong oil in?
06-20-2014, 08:01 PM | #128 |
Member#: 90539
South East
Maybe someone should offer to pay for him to run the 15/40 again for a short time, just to verify? Unless someone else added the oil and used 0/20 I'm not sure how he could have mistaken the oil used.
I never run shell, quaker state, royal purple, etc. I've used castrol and valvoline since my first vehicle and never have had a spun bearing or low pressure issues. Those two brands seem to have had good quality control over my driving life. |
06-26-2014, 09:48 AM | #129 |
Member#: 128022
Vehicle:2015 Mustang GT Black |
06-26-2014, 06:24 PM | #130 |
Member#: 204421
All too often people ignore the suction pressure as a function of final oil pressure. This is due to the location of our oil pump reliefs and where they get their reference pressure.
What oil pressure does with different oils will depend on what is causing the low or high pressure in the first place. If the clearances are large, then using thinner oil would increase flow through them with a fixed supply flow resulting in lower pressure. If the oil pressure was low due to a weak relief spring, the thicker oil would cause the relief to lift sooner due to increased suction forces (more negative pressure/vacuum). Lifting thicker and heavier oil from an oil pan creates a lower pressure at the reference point of the relief. |
06-26-2014, 07:55 PM | #131 |
Member#: 90539
South East
/\ Great point, there almost always another variable that people miss or ignore.
06-30-2014, 04:54 PM | #132 |
Member#: 387773
Glad I found this...bought a 12mm oil pump for my EJ257 rebuild....
08-03-2014, 03:51 PM | #133 |
Member#: 303525
SCIC
Vehicle:'05 LGT Ltd 5EAT Atlantic Blue Pearl |
09-02-2014, 02:54 AM | #134 |
Member#: 75414
RMIC
Vehicle:2004 STi Its the Blue one |
Since this thread is filled with about all the oiling info you will need I have another question. When you add a large oil cooler with -10 hose does that play a role oil pump size.
Sent from my iPhone using NASIOC |
09-02-2014, 06:21 AM | #135 |
Member#: 198281
No. From the setups we've done and recommended, the pressure drop is typically very very small if it's even gauge measurable at all. Use high quality products and you'll be fine. Also, when you add an aftermarket cooler, remove the OEM cooler. This will help you gain back some losses, and also free up a bit of cooling system capacity.
09-03-2014, 04:03 PM | #136 |
Member#: 75414
RMIC
So what tools are you guys using to port and polish your oil pumps
