09-22-2018, 10:55 AM | #1 |
Member#: 474556
South East
TN: 96 Impreza L AWD, 230k, $2100
Putting my (RUST FREE) automatic impreza up for sale. Have put a lot of work into this car and I hate to sell it but I'm trying to get a manual coupe.
Lebanon, TN 230,000 miles $2100 Pros: - Clean title, not rebuilt - Timing belt/water pump are good - 4EAT shifts great, no slips - All windows work (crank) - A/C and heat work great - New control arm bushings - New KYB struts all around - New inner/outer tie rods & boot - Superpro steering rack bushings - Put a cone filter on it for sound (still have stock airbox) - Spark plugs and wires - WRX rear sway bar - Fog lights - 98-01 hood/grille/headlights - WRX wheels w/falken all seasons (not the snowflakes pictured) - New JVC speakers all around - New wheel bearing - 03 OBS driver's seat (I have the stock seat) - Oil changed every 3k w/Havoline semi-synth - New pads and rotors, just flushed/bled the brakes too - Changed diff fluid - Has never overheated, coolant is nice and clean and doesn't leak - Interior is in pretty good condition for the miles, couple little rattles - No exhaust leaks Cons: - Rear drums are warped - Squeak from front left brake, still trying to figure that out - Lifter tick when cold - Has diff whine around 50mph, has done this ever since I've owned it. - Torque bind (one of the previous owners must have ran mismatched tires) - Leaks a little oil. Have to add some once between oil changes usually - Passenger fender and driver side quarter panel dented - Spots where paint has chipped off, clear coat is pretty much gone above the gas door
