Brakes & Suspension Forum sponsored by The Tire Rack |
06-10-2003, 04:11 AM | #1 |
Member#: 22899
Vehicle:01 GM6 i think BRP |
Recommended camber?
OK I just ordered KYB GR2s for my GC impreza.
I currently have an eibach pro-kit on the stock struts, but will likely be getting H&R sport springs to put on the GR2s. The H&Rs should lower the car 1.5 in the rear and 1.8 in the front. My questions are: What should the camber be set at in the front and rear to prolong tire life without compromising any handling or throwing me into oversteer? I am fairly knowledgable with the basics of suspension, but this camber and castor stuff still confuses me a little. actually, i don't even know what castor is, does it matter to me at this point? Also, is there anywhere that I can find good instuction on how to adjust camber bolts to the correct settings? And where can I go to get a good set of bolts for the rear? Thanks, Greg
06-10-2003, 01:00 PM | #2 | |
Sammo Hung
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
Re: Recommended camber?
for my taste. looks like / \ instead of | |. so my alignment for camber -0.5 fronts and -0.7 rears. but after I get teins going to -0.2 fronts and -0.5 rears. I also have cusco front camber plates for autox and alk's caster, the angle the strut is from pure vertical. more / the better the turn. the alk's change caster to help turn in. but the camber plates give a solid feel to steering. seen from the side of your car. camber, the tilt of the wheel as seen from front or rear. negative / \, postive \ /, zero | |. I autox and plan for a few track days. cusco sway bars all around 21mm front & 22-24mm rear version 2 front sub-brace. all on stock stuts and eibach pro-kit springs. cusco front camber plates too. the car handles as tight as my past porsches without the high price tag. it goes where I want it to go. close as neutral with springs. saving for coilovers. my few cents Ben Jax Mod Squad |
Recommend a cheap, decent Camber/Caster Gauge | REX8 | Motorsports | 1 | 09-13-2006 10:40 PM |
Which camber kits does everyone recommend? | SpeedWagon41 | Brakes, Steering & Suspension | 7 | 07-04-2006 10:55 AM |
Recommended vendor? Noltec camber/caster (RACE) | SgWRX | Brakes, Steering & Suspension | 6 | 05-07-2005 03:38 AM |
Tom, Scooby South, Templar, Biggly, etc. - Recommend me rear camber setting. | thrdeye | South East Region Forum | 18 | 01-09-2005 08:55 PM |
Recommend front camber plates for my GC RS | GQ | Brakes, Steering & Suspension | 3 | 07-15-2004 08:51 AM |
