09-16-2009, 12:31 PM | #176 |
Member#: 215814
Vehicle:2010 Tundra Red |
i reacently changed the oil on my newly purchased 04 wrx wagon either i stripped it or the previous owner did but the threads on the oil pan where the drain bolt is loacated are stripped. now my car leaks oil past the bolt any advice or tips short of changing pan
09-16-2009, 01:25 PM | #177 | |
Member#: 216135
Vehicle:2011 |
09-17-2009, 08:58 AM | #178 |
Sufficient for Sharky
Member#: 55173
Vehicle:with paddles. |
How much longer until we get automatic oil level sensors to replace our dipsticks? I always get back in my car thinking, "I probably read that wrong." Flame away.
09-17-2009, 10:58 AM | #179 |
Member#: 56183
South East
screw that, just give us a maintenance light honda has it for the civics and they also have a oil life left guage
10-25-2009, 04:44 PM | #180 |
Member#: 211630
Vehicle:2009 Bone Stock STI SSM |
What oil should i use. I'm switching to synthetic.
10-25-2009, 04:48 PM | #181 |
Member#: 183529
Vehicle:i wanna help teh haters ... love life ... |
1st post sir, 1st paragraph as wel
What is the best oil? Simply put, there is no best oil. While I stand by my premise that there is no best oil, I will offer recommendations as to what I have found are the "best oils": Synthetic: Mobil Delvac 1 or Lubrication Engineers 8530 MONOLEC Regular: Pennzoil or Havoline Synthetic/Regular Blend: Motorcraft |
10-25-2009, 07:19 PM | #182 | |
Member#: 56183
South East
10-25-2009, 08:38 PM | #183 |
Member#: 25859
South East
Vehicle:1965 MGB yellow 2008 Black Miata |
10-25-2009, 10:46 PM | #184 |
Member#: 56183
South East
if you can find the shell rotella t6 (new formula) that should be even better.. anyone seen this new stuff on shelves yet?
10-27-2009, 05:09 PM | #185 |
Member#: 219892
RMIC
Vehicle:AP1 S2K Life Now 17' PRD WRX CVT (Sold) |
My car is nearing the 98,000 mark...should I put high Milage in? I'm currently running full synthetic...
10-27-2009, 07:55 PM | #186 |
Member#: 51876
SCIC
Vehicle:2004 Impreza WRX Sdn WR Blue Pearl |
I've been using Mobil 1 10W-30 High Mileage on my car for awhile now. I'm at 122,000 miles on my 2004 WRX. If I'm going to go to the track, I'll put 10W-40 High Mileage in.
It seems to work well for me. :shrug: |
11-04-2009, 11:14 AM | #187 |
Member#: 15948
Vehicle:2001 2.5RS 317awhp-277ft./lb |
Can someone put in a sticky the NEW filter we should be using and for each different motor.
I have a 2003 jdm ej205 - what filter should I be using?! I am so stumped with all of these various filters! |
11-09-2009, 05:07 AM | #188 |
Member#: 132400
Vehicle:2006 WRX |
some say check your oil level when your motor is cold and others say check it at the pump when your oil is warm? does it really matter? i check mine on a cold engine and just make sure the oil is at the correct level
11-09-2009, 05:20 PM | #189 |
Member#: 32993
AKIC
Vehicle:vf39 Best trap 110 Best ET 12.51 Dale tuned |
12-30-2009, 04:37 PM | #190 |
Member#: 195061
NWIC
Vehicle:1997 ¯\_(ツ) Green |
Anyone know if Castrol Syntech High Mileage 10-40 is any good?
Also any hear if the napa brand oil filters are any good. I was in looking and they had a cut away of the crappy FRAM oil filters and then a cut away of the napa oil filter and the napa one looked pretty dang good. The napa one is a little bit bigger then OEM and the filter element looks good. Just wondering if anyone has hear any good or bad about the oil i mentioned or the filter |
12-30-2009, 04:57 PM | #191 |
Member#: 767
Vehicle:04 FXT 20 OB Onyx XT |
I believe you are referring to Castrol GTX High Mileage as there is no Syntec HM. If you want a good HM oil, go with Valvoline Max Life Synthetic or Synthetic Blend. I run the blend in my '00 RS and '99 Outback. No comment on the filter as I only run OEM or Purolator.
-Dennis |
12-30-2009, 07:03 PM | #192 |
Member#: 195061
NWIC
Yeah it is the high mileage kind.
12-30-2009, 08:15 PM | #193 | |
Member#: 2133
Vehicle:2005 STi WRB/Gold 2005 S4 Avant |
12-30-2009, 09:03 PM | #194 |
Member#: 21038
South East
Vehicle:05 STi CGM 08 WRX 5D SSM |
If I understand it correctly they bypass valve is just for if/when the filter doesn't flow enough, will that happen with a clean filter or one that is changed regularly?
12-30-2009, 09:37 PM | #195 |
Member#: 216135
Vehicle:2011 |
A brand new filter....particularly one with a 10-12 psi bypass pressure like the WIX speced for the WRXes...is going to open up the bypass valve during a cold start and flow a large percentage of the oil for a few seconds completely unfiltered. Under certain WOT conditions, it may open up a bit as well....again even on a completely clean filter. Suby oil pumps can flow up to 12 gpm with a 85psi relief pressure.....hence the necessity for high bypass pressure filters.
By the way, only the higher end Napa filters (gold, etc) are made by WIX. The base model is not if I'm not mistaken. |
12-31-2009, 08:56 PM | #196 | |
Member#: 21038
South East
12-31-2009, 09:01 PM | #197 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
12-31-2009, 09:23 PM | #198 |
Member#: 21038
South East
12-31-2009, 09:59 PM | #199 | ||
Member#: 16200
A friend with a bugeye wrx tried it as it was CHEAP at wallyworld and had similar results and has continued to use it over the last year or so. |
01-05-2010, 11:20 PM | #200 |
Member#: 202667
South East
Vehicle:2007 STi OBP on Gold |
Scanned over this FAQ a few times and did some searches but Im still kind of confused when it comes to the oil weights. Could someone please explain to me what the numbers mean when referring to say 10W-30 or 5W-30? The only time that the weights are really talked about in this FAQ is about Alaska. My dad's tried to explain it to a few times in the past but I still don't really get it. What do each of the numbers mean? What relationship do the two numbers have to each other? Sorry if this has already been talked about but seeing as how this is the Oil FAQ, I figured I'd come here for the answer. (The answer is probably somewhere in this FAQ already and this is just one of those times where I read something and just skip right over it without knowing it, so if someone points it out to me, I know, I know, Im a n00b... )
Spark Plug FAQ: Read if you want spark plug information! | Unabomber | Service & Maintenance | 744 | 10-12-2023 04:31 AM |
Tool FAQ: Read if you want information on Subaru specific tools and sundries | Unabomber | Service & Maintenance | 42 | 08-07-2022 11:49 PM |
Injector, Fuel Pump, and Fuel Rail FAQ: Read if you are thinking of upgrading! | Unabomber | Newbies & FAQs | 191 | 08-11-2020 01:08 PM |
Cooling System FAQ: Read if you want coolant information! | Unabomber | Service & Maintenance | 668 | 08-02-2020 09:09 PM |
Car Storage FAQ: Read if you are storing your car for more than 30 days | Unabomber | Newbies & FAQs | 104 | 10-10-2013 01:07 PM |
