01-21-2009, 08:29 PM | #1 |
Member#: 49979
Vehicle:11 need a 2nd STI 08 black TA STI |
Anyone interested in using this huge maf to replace the denso sensor?
I was scanning the sema reports for cool new parts and came across this:
http://www.semadigital.com/netpub/se...49&site=np2008 http://www.abacoperformance.com/ What you are looking at is a new 3.5" or 4" MAF sensor that uses multiple flow sensors on both the front and the back of the flow stabilizer veins so that it can zero-out flow reversals and has a digital stage to smooth the flow data. What I am wondering is whether anyone besides me is interesting in seeing this thing used in a 500+ whp subaru. Unfortunately they want around $450 for one. Any takers? Frank
01-21-2009, 11:14 PM | #2 |
Member#: 82148
SCIC
Vehicle:1992 Daihatsu Charade |
It sells for $390 online, which is normal for standard aftermarket MAF.
I'm wondering about the advantages over our stock unit... |
01-21-2009, 11:27 PM | #3 |
Member#: 133391
Vehicle:2004 boosted saleen white |
Why bother when blow-thru MAF setups and speed density is proven on subaru's. You have to look at all the other high horsepower subaru's on here. Have any of them used this???? (None that I have seen) So why start using it now when our cars make alot of power without having to use that.
Sounds/looks like more of a PITA than anything. And for people that run bigger diameter intakes than 4 inch which some rotated turbos do it would taper for the MAf thus hurting flow. Plus this has to be wired into the engine harness plus tuned for if any tuner can tune these on our cars. Stick with what we already know works. bank that $400 they want for that MAF |
01-22-2009, 12:20 AM | #4 |
Member#: 98961
Vehicle:2003 WRX Black |
I don't know. If we all felt that way, we wouldn't have electric lights or these horseless carriages.
I'd love to see the op install one and see how it works. |
01-22-2009, 01:30 AM | #5 |
Member#: 51684
There really isnt an advantage. The OEM maf sensor works just fine. You would also have to get a separate air temp sensor if you buy that Abaco one.
01-22-2009, 08:07 AM | #6 | |
Member#: 49979
Blow-thru maf works if you have enough pipe run before the TB. I'm using a topmount and if I do anything different, it would be a v-mount with a reversed manifold. Speed density requires a map sensor and a different ecu- again not appealing given the aftermarket ecu options that are currently available for an '08 sti. I wasn't looking for anything larger than 4". This solution does seem to be proven already on Mustangs, BMW's and Porsche's. I'm sure this wouldn't be too much effort to implement. Frank |
01-22-2009, 10:28 AM | #7 | |
Member#: 98961
I objected to Fastlane's automatic dismissal of the idea BUT, I agree with him that most people don't NEED to use a MAF like this. |
01-22-2009, 12:31 PM | #8 |
Member#: 127745
Vehicle:06 WRX 30r 6 speed 99L EJ255 6 Speed |
I would think that seperating the MAF from the IAT sensor would be a good thing, although I am sure it would be a hassle. I am actually surprised that nobody has tried to isolate the IAT sensor and place it in the intake manifold.
I would like to see what Geoff from Full Race has to say. He seems to be a proponent of pre-turbo MAFs, and I know he has mentioned adopting a larger Supra MAF for Subies. |
01-22-2009, 01:47 PM | #9 |
Member#: 98961
I haven't really gotten a good read on it but, apparently the JDM spec-c manifolds have the IAT in the manifold (a bung on the underside). I'm not 100% sure of this information. I've just seen comments about plugging the bung though. IAT in the MAF makes no sense for a turbo car. Even my Civic had the IAT in the intake runner right in front of Cylinder #1.
01-22-2009, 02:34 PM | #10 | |
Member#: 32669
SCIC
Vehicle:2007 2.34LR, EFR7670 LINK G4+ hybrid STi |
If you're not trying to constantly improve and move forward you might as well be moving in reverse because everyone else is going to pass you by. I think its ability to filter out flow reversions would be beneficial to those with big cams that are still MAF based too. |
01-22-2009, 04:04 PM | #11 |
Member#: 49979
I think it does include an IAT sensor as well.
I'm hoping an intake builder picks up on it so the g/s to V conversion can be done once as I agree that this is a mild annoyance. They would also be in charge of establishing a direct to OEM wiring adaptor similar to what this company already markets for Fords and others. Plumbing shouldn't be any worse than any 4" intake. Frank |
01-22-2009, 06:21 PM | #12 |
Member#: 98961
Yeah, you're right. They call it an ACT sensor.
I was looking at this one. http://fordfuelinjection.com/?p=29 Wondering how much work it would be to plumb this into the intake manifold proper. |
01-22-2009, 06:38 PM | #13 | |
Member#: 127745
Similar Threads | ||||
Is anyone interested in SLMP this year? | Zornorph | New England Impreza Club Forum -- NESIC | 40 | 08-10-2006 12:27 AM |
How hard is it to replace the speed sensor? | ski mobile | Transmission (AT/MT) & Driveline | 1 | 08-01-2004 01:41 PM |
Anyone interested in used 5zigen FN01-RC's? | philw007 | New England Impreza Club Forum -- NESIC | 4 | 12-07-2003 10:37 PM |
Anyone tried using a S2000 Antenna to replace the WRX's?? | View Askew | Car Audio, Video & Security | 7 | 02-23-2002 02:30 PM |
Anyone interested in used Impreza's I have a connection. | ZenDriver | Southern California Impreza Club Forum -- SCIC | 1 | 01-27-2001 06:31 AM |
