12-04-2013, 05:59 PM | #1 |
Member#: 142559
RMIC
Vehicle:'05 Forester XTi Broyotas:4runner & Tacoma |
Designing and Building my own strut "Lift Spacers"
I decided that I didn't want to spend $200-$300 for a subtle solutions lift kit. I'd rather just make my own.
Got my degree in design engineering tech. 7 years ago and currently work as a mechanical design/drafter for a medical device company. I spend my day designing/reverse engineering/drawing fixtures, tools, products etc. etc. I figured I could put my skills to use for car parts. With the onset of winter, I decided that I wanted a little more ground clearance this year without sacrificing the stiffness of aftermarket springs. I didn't want to have to replace the tophate bolts either, so I wanted to just go with a .5" spacer. I removed a front and rear tophat for measurements, and got my needed dims with a caliper and ruler: Then I use AutoCAD as sort of a "digital sketchpad" to easily and quickly layout the outline: Then, I print a 1:1 outline, carefully trim it out with a razor, and then place it on the tophat to test fitment: Fits good, time to move forward: Save the outline in AutoCAD, then import it with Solidworks: Extrude: Done, ready to send the 3D file to the machine shop: Currently waiting for our in-house machine shop to make these, I will update with pics when that happens. BTW, if you have ideas you want put into 3D, PM me a sketch and I'll do it when I have down time.
12-04-2013, 06:00 PM | #2 |
Member#: 142559
RMIC
reserved for pics.
12-04-2013, 06:11 PM | #3 |
Member#: 140712
SCIC
Vehicle:2008 WRX STI White |
hmm, lift spacers. hmmmmm
i would make the inside hole smaller, so it just touches the inside radius of the center. as it will give more surface area and be stronger. also, double check your measurements as normally max size you can fit is 3/8" spacers |
12-04-2013, 06:16 PM | #4 |
Member#: 142559
RMIC
Yeah, I would go smaller but there are 3 grooves that protrude up and would cause the spacer to not sit flat, I guess I could mill out a little pocket for them to sit in. It's not costing me anything so I don't care if it doesn't work the first time. 3/8 you say? I will definitely check that.
12-04-2013, 06:18 PM | #5 |
Member#: 140712
SCIC
not mine, but jackonson rally (i dont make alu ones) but you can see the size difference and the cut out for the groove.
12-04-2013, 06:28 PM | #6 |
Member#: 142559
RMIC
12-04-2013, 06:33 PM | #7 |
Member#: 22035
SCIC
Vehicle:2014 Brocoma DCab 71 FJ40, 13 DRZ400SM |
yea, grove for sure, or why bother even making the hole smaller (ie the subtle ones) the whole idea is to have more surface area on the mating parts.
12-07-2013, 02:41 AM | #8 |
Member#: 329712
Vehicle:2005 Sti Aspen White |
Wow. Very nice!
12-07-2013, 04:01 PM | #9 |
Member#: 34924
SCIC
Vehicle:03 WRX Wagon 81 Scirocco S |
12-08-2013, 12:39 AM | #10 |
Member#: 22035
SCIC
wont doing that put more preload on the springs? causing them to ride stiffer?
12-08-2013, 03:22 PM | #11 |
Member#: 34924
SCIC
No, preload does not change spring rate. The only way to change spring rate is to physically change the spring. Changing preload on a suspension only changes sag from it unloaded to loaded height.
12-12-2013, 10:37 AM | #12 |
Member#: 142559
RMIC
that's a pretty cool idea!
I should be getting these machined next week, our machinist has been pretty busy. I'll post pics of it installed. |
12-18-2013, 10:07 PM | #13 |
Member#: 64289
Vehicle:2004 wrx wagon wrb |
If it's a progressive spring, preload can compress that initial x distance of travel, making the ride feel stiffer. Non progressive springs, no problem. Just throwing that out there.
01-23-2014, 01:01 PM | #14 |
Member#: 42460
Survey says?
01-30-2014, 11:09 AM | #15 |
Member#: 142559
RMIC
Well, machinist got too busy to build these, so I decided to take a simpler route. I ended up making a washer type spacer (similar to the TIC, Scooby921 spacer) to sit on top of the strut post, right underneath the top hat. I went' .40" on the rears, and .28" on the front. I also put my stock struts with Epic springs back on.
I love it! rides good, little squeaky but I don't give a dam, it's wintermode. BEFORE AFTER |
08-05-2018, 12:38 PM | #16 |
Member#: 327176
08-08-2018, 12:16 PM | #17 |
Member#: 428511
Vehicle:2016 STI |
