Welcome to the North American Subaru Impreza Owners Club Tuesday October 16, 2018
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 09-18-2018, 01:18 AM   #2452
JL Cheech
Member#: 408867
2015 WRX
Originally Posted by X49 View Post
You're running pretty rich. Only by about 0.2AFR though most of the rev range, but at one point your AFRs are touching 10.14. It's pretty safe, but you might end up fouling plugs or something, and you're leaving some power on the table. You can fix your MAF scaling with a tune. Some aftermarket intakes don't exactly have a fixed filter location, and this can cause MAF calibration issues, so you could try to adjust it a bit to see if it makes you run a little leaner.
Thanks for taking a look. From what I've read the Cobb OTS Tunes are usually on the rich side. How do they compare with the stock WRX tune from the factory?
JL Cheech is offline   Reply With Quote
Old 09-22-2018, 08:40 PM   #2453
dusty_sombero
Member#: 420856
2015 WRX
Catback exhaust, TGV delete, EGR unplugged, EBCS
93 octane with 5 gallons e85 (this is a track tune that Ron did for me)
https://datazap.me/u/dustysombrero/l...=0&data=3-9-24
The car feels ridiculously fast. I'd appreciate if some of the regulars on here would take a look at the log and let me know their thoughts. Thanks, guys.
dusty_sombero is offline   Reply With Quote
Old 09-23-2018, 09:06 AM   #2454
Straight6
Member#: 419593
Damn that looks like it is a blast to drive! I saw that Ron just picked up a 2015 WRX to play with. I think good things are on the horizon. Now I just need a E85 station closer to my house. My body is ready.
Straight6 is offline   Reply With Quote
Old 09-23-2018, 10:25 AM   #2455
DustySombrero
Member#: 463297
2015 WRX
It’s so much faster than my 93 octane tune. I couldn’t believe the difference that 5 gallons of e85 makes. When I first got tuned by Ron on 93 we were battling high rev knock from the get go. He eventually got it cleared up, but this time around with the e85 in the tank, there was no knock and each revision just got faster and faster until the final one in the log I posted above. The thing rips.
Eric, you mind taking a look at my track log?
DustySombrero is offline   Reply With Quote
Old 09-23-2018, 12:55 PM   #2456
That_Boosted_Life
Member#: 422693
2016 WRX Premium
Lapis Blue Pearl
e55 final from mikey botti. Two logs in the link below. What's everyone think?
E55 Final Datalog
That_Boosted_Life is offline   Reply With Quote
Old 09-23-2018, 07:07 PM   #2457
Straight6
Member#: 419593
You guys seriously need to stop posting flex fuel logs...
Old 09-24-2018, 01:40 PM   #2458
whiplash willy
Member#: 424843
2016 WRX Limited 6MT
ISM
We can't see a whole lot in that log, but you've got knock. It's as simple as that. If you want to get rid of it you either need to use higher octane fuel, or you need to get an Accessport and maybe a custom tune either through a protuner or with the Accesstuner software. If this DAM reduction is only recent, it's probably just due to a bad tank of fuel.
In my experience, these engines are pretty knock-prone at 1.0-1.3g/rev on the stock tune. You'd be in this load range a lot cruising up hills. Lower gears and higher revs while climbing hills may result in less knock and DAM reduction. DAM reduction reduces timing more at high loads than at low loads, so you're likely very safe in terms of high load knock (the damaging kind). The learning is happening at low-moderate loads, and your engine is then protected from knock at high loads because of the reduced DAM. The downside of this is that you sacrifice quite a bit of power with a lower DAM. Buy an Accessport. You won't regret it. Even with an OTS map, you should get less knock than stock.
Edit: It seems you've used 92 from two different stations. Does it have 10% ethanol? These engines run better with some ethanol. Do you have access to even higher octane? A DAM as low as 0.18 on 92 octane is pretty odd. If you put some race gas in and still have a lot of DAM reduction, you might be looking at a bad knock sensor, though it's pretty unlikely.
Thanks for taking a look and your response. It makes alot of sense, and is very helpful! I was out last week, so I haven't done alot of testing, but after seeing your post, I started monitoring load alot more, and alot of my driving to and from work is cruising at around 1.0g/rev, and that is typically when I am seeing my DAM drop. I kept my revs higher and it didn't drop as bad. I am thinking that nothing is wrong, and it is a combination of the hills I drive every day, how I am driving them, and the problems you mentioned with knock on the stock tune in that range.
The 2 stations I used, both have 10% ethanol, and 92 is the best I have access to. I am thinking of altering my driving on those hills (higher revs) and see how things improve. I am also looking into getting an Access Port, and will hopefully have one in the not too distant future! Your post really helped me out, and makes me feel much better about what I am seeing. Thanks again!
whiplash willy is offline   Reply With Quote
Old 09-28-2018, 08:06 PM   #2459
dooglaz
Member#: 491897
2018 WRX
2018 WRX
CNT catless j pipe
Magnaflow competition catback
Stock intake/Cobb Intake
Cobb Stage 2 OTS 93 oct
Wasn't liking how the car was running on the cobb intake. Seemed a choppy when in boost at WOT. Ended up putting the stock intake back on.
Logs were created with the default markers set on the AP. I don't believe it includes command fueling.
3rd gear pull
Cobb intake:
https://datazap.me/u/dooglazgmailcom...g=0&data=16-18
Stock intake:
dooglaz is offline   Reply With Quote
Old 10-01-2018, 03:48 PM   #2460
ChrisKwan
Member#: 100290
2018 Subaru WRX
Crystal White Pearl
I am posting on behalf of a friend. Can you guys look at this log. He got a e-tune done by a well known tuner in Canada and after one map rev the tuner is calling this as final.
2018 WRX - MT
Cobb Catted TBE
Grimmspeed TMIC
Grimmspeed EBCS
Grimmspeed Intake and Box
TGV and EGR Deletes
KillerB Charge Pipe
Shell 91 - Canada
e-tune
https://datazap.me/u/drunknmnkee/sep...og=0&data=6-18
ChrisKwan is offline   Reply With Quote
Old 10-01-2018, 05:02 PM   #2461
vlad11591
Member#: 295970
2018 WRX
ISM
2018 WRX - MT
Cobb Catted TBE
Grimmspeed TMIC
Grimmspeed EBCS
TGV and EGR Deletes
KillerB Charge Pipe
Shell 91 - Canada
e-tune
https://datazap.me/u/drunknmnkee/sep...=1-2-6-8-18-20
Why is target boost so low? Am I missing something?
vlad11591 is online now   Reply With Quote
Old 10-01-2018, 05:44 PM   #2462
tegxsi
Member#: 446029
Probably because it's really cold and intake temp compensations are reducing the boost target.
tegxsi is offline   Reply With Quote
Old 10-01-2018, 06:00 PM   #2463
ChrisKwan
Member#: 100290
2018 Subaru WRX
Crystal White Pearl
We asked why he set the boost so low and his answer was to keep it conservative for winter and that he will revisit the tune in the summer.... Is this always the case? Dose everyone in Canada run a winter low boost map and a summer high boost map?
Old 10-01-2018, 06:23 PM   #2464
GlarryHoodDIT
Member#: 460907
2016 WRX
Only people whose tuner doesn't understand how to properly use temperature compensations.
One revision and the tuner calls it final. That should speak for itself. Looks like he gave you the most conservative tune possible because he didn't want to take the time to do the job properly.
Tell your buddy to find someone who gives a **** and have his car properly tuned.
GlarryHoodDIT is offline   Reply With Quote
Old 10-01-2018, 08:46 PM   #2465
jnorwooddds2004
Member#: 472308
2015 WRX
Red
Yes. That.
I can speak for Mike Botti. There are def. others reputable as well.
jnorwooddds2004 is offline   Reply With Quote
Old 10-02-2018, 09:46 AM   #2466
ChrisKwan
Member#: 100290
2018 Subaru WRX
Crystal White Pearl
I mean the car feels good and it pulls hard. But even with the target boost set low, you guys have any comments on the log/tune?
We weren't sure if these big name american tuners like PhatBotti and BrenTuning tune us Canadian vehicles, with our poor quality fuel and our large temperature swings from +40c to -40c.
Old 10-02-2018, 10:46 AM   #2467
simpleJ
Member#: 391748
2015 WRX CWP (sold)
2019 STi CWP
Get a bren tune if you can.
It is possible to have a car finished in very few revisions.
And the tuner may be “dumbing down” the explanation on cold weather boost for the general consumer so I wouldn’t say any of this is wrong.
Also look at the creep he’s getting. That means the tuner is being super conservative here in the cold. That may be what he means
simpleJ is offline   Reply With Quote
Old 10-02-2018, 10:23 PM   #2468
Nevr2fast
Member#: 415524
Bren has tuned my 2015, I live in Quebec. I had absolutely no problem with tune in winter. I have just traded for a 2019... I have a hard time waiting to tune again... so much difference in drivability.
Nevr2fast is offline   Reply With Quote
