03-13-2005, 10:34 PM | #1 |
Member#: 53129
Vehicle:17 WRX Silver |
What makes my car hard to start sometimes?
Sometimes I just drive around in a normal speed, run in to a store come out, trun the start, the thing cranks over well, but it won't start. I get this once in a while. It's been happening ever so often since I got the car, now I have stage 2 cobb and it's still the same thing. My battery is stock, but the thing cranks over very well. My car is parked in a heated garage. Has 48k on it. I crank it over the second time with the gas pedal push, then it fires up.
03-14-2005, 12:54 AM | #2 |
Member#: 57488
Vehicle:1998 GC8 EJ205 VF34 12.0@115 STi Mikey Tuned |
clogged fuel filter?
03-14-2005, 09:34 AM | #3 |
Member#: 53129
It's fairly new, about 5k back it was replaced. Wondering if something like the pcv valve may be a culprit?
03-14-2005, 10:22 AM | #4 | |
Member#: 6030
Vehicle:04 Gold FXT 07 WRB FXT Sport |
When you start the car, do you turn the key to the ON position for a second or two before starting? Or do you just turn the key straight to start?? I believe the fuel pump needs a moment to charge the line, I think I had read this here on Nasioc somewhere, you can hear it stop charging, after a second or two when the key is in the on selection. Not sure if this helps... dm |
03-14-2005, 04:07 PM | #5 |
Member#: 53129
I'll give that a try. Kinda weird though, since when my car sits for a day, it starts fine, but drive it and stop, that's when it does this.
03-14-2005, 05:12 PM | #6 |
Member#: 6030
Did you see this thread?
HARD TO START |
03-15-2005, 10:18 AM | #7 |
Member#: 53129
That thread talks about it hard to turn over. Mines turns over fine, but it just does not fire up. But I am doing the 2-3 second thing now, and I'll see if it happens again.
03-15-2005, 12:57 PM | #8 |
Member#: 6030
let us know how it works out
My car has trouble starting sometimes. 2003 WRX w/ 80k miles. | YinUCSD | Service & Maintenance | 10 | 12-30-2005 05:33 PM |
my car decided to start fighting back. | rabbitnutz | Normally Aspirated Powertrain | 8 | 02-11-2005 01:57 AM |
Damn car is stalling and hard to start sometimes! | crimedog | Service & Maintenance | 14 | 04-21-2003 01:07 PM |
Car hard to start | the spacecowboy | Normally Aspirated with bolt-on Forced Induction Powertrain | 0 | 12-20-2002 01:27 AM |
My car hates to start sometimes. Anyone else with this problem? | Eric SS | General Forum Archive | 17 | 02-09-2001 08:33 AM |
