Welcome to the North American Subaru Impreza Owners Club Saturday January 18, 2020
Old 11-12-2007, 03:21 AM   #1
simprezl25
Member#: 71647
2002 Bug iD
Default hesitation at full boost
hi guys i recently installed my turbo that i got rebuild at deadbolt and i also took off the straight pipe n1 catback and installed a stock sti catback.
i drove around for 200 miles since u have to break in the turbo. today i went wot after a proper warm up and it started hesitating and bogging. sounded like misfires but my check wasnt flashing.
i got it tuned by turboxs and then i had it tuned with the n1 catback.
is it because of the restrictive sti catback that its making my car do this?
i cant figure this out
simprezl25 is offline   Reply With Quote
Old 11-12-2007, 04:17 AM   #2
icslowmo
Member#: 114667
00/5 Silver STi RS
FAT 40R kit w/ FMIC
Need more info on car. Mod list??? And do you mean stock STI cat back???
icslowmo is offline   Reply With Quote
Old 11-12-2007, 04:27 AM   #3
simprezl25
Member#: 71647
2002 Bug iD
yes stock sti catback
mod list td05 big 16g
utec
tial 38 ewg steup
ultimate racing up pipe
hks dp
ssautochrome fmic
oil catch can
knN intake
19psi 307whp 277 trq
Old 11-12-2007, 04:34 AM   #4
icslowmo
Member#: 114667
00/5 Silver STi RS
FAT 40R kit w/ FMIC
Why was the turbo in need of a re-build?? Most likly yes it's because of the Sti cat-back. Try taking cat-back off and run with no exhaust to see if problem goes away
Old 11-12-2007, 01:11 PM   #5
simprezl25
Member#: 71647
2002 Bug iD
had to get it rebuilt because of end to end haft play
*****update*****
i replaced the sti catback with the n1 straight pipe catback.
but as i was disconnecting the sti a couple drops of coolant hit the ground. i made sure it wasnt water/steam.
where could this coolant be coming from?
Old 11-12-2007, 10:40 PM   #6
simprezl25
Member#: 71647
2002 Bug iD
bump for my problem please help
Old 11-12-2007, 11:10 PM   #7
04subyrex
Member#: 144873
2004 WRX evoIII/meth
66 Mustang 408w
I have the same problem but i got a check engine light....It was saying cylinder 2 misfire. So i checked the plug and it was cracked. Maybe check your plugs...
04subyrex is offline   Reply With Quote
Old 11-12-2007, 11:13 PM   #8
simprezl25
Member#: 71647
2002 Bug iD
i have misfires in all four aswell...
Old 11-13-2007, 11:20 PM   #9
simprezl25
Member#: 71647
2002 Bug iD
found the problem! turns out that the sti catback was really restrictive with my tune (utec) so i put the n1 catback on and there is zero hesitation.
turns out that a simple catback switch does make a big difference.
Weird noise at full boost Johnny5 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 03-07-2016 08:22 PM
hesitating when full boost g-unit555 Legacy Forum 3 08-10-2008 02:44 AM
Whine at Full Boost-Boost Control line was cut. Bundyboyz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 07-26-2005 09:29 AM
Door ajar light comes on at full boost! snvin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 08-27-2004 03:56 PM
engine dies at full boost Andy V Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 05-31-2004 01:47 PM
