Welcome to the North American Subaru Impreza Owners Club Thursday March 4, 2021
Old 05-19-2003, 03:28 AM   #1
buymeasti
Member#: 24091
Angry Blue Smoke when letting off full boost???
So I went on a drive today with some friends and the person behind me said he saw bursts of blue smoke out my tailpipe when I let off boost.
...Thx in advance...
buymeasti is offline   Reply With Quote
Old 05-19-2003, 12:03 PM   #2
tekfoc
Member#: 21392
2016 C63S AMG MB
Iridium /MB C300 4MATIC
sorry to tell you but sounds like you have a bad turbo your burning oil thats why you see blue smoke
tekfoc is offline   Reply With Quote
Old 05-19-2003, 12:08 PM   #3
mlambert
Member#: 13831
If its just when you lift the throttle then it could be something that a simple catch can could fix. Id check for oil in the intercooler and then leak-down and compression tests, just to be safe.
mlambert is offline   Reply With Quote
Old 05-19-2003, 12:32 PM   #4
Austin
Member#: 7089
2016 STi
Ditto.
I wouldn't worry too much right now. Just keep an eye on it.
Austin is offline   Reply With Quote
Old 05-19-2003, 01:14 PM   #5
buymeasti
Member#: 24091
Thanks for all the help guys, I'm not too worried about it at this point, but at less than 15K miles it pisses me off, especially considering that I dont abuse the car at all.
So help me understand why I could have oil in the IC, and from my understanding the catch can would remove this oil? Would a slightly high oil level contribute to this?
Is this a normal occurrence? Do all people witness this when pushing hard, and it just gets collected by the cats, so the catless people actually observe it? Or is this definitely abnormal in our WRX's?
Old 05-19-2003, 01:35 PM   #6
cnk
Member#: 10757
2013 BRZ Limited 6MT
Oil in the intercooler is usually from the PCV or crank case vents. It's more commonly known as oil blow-by and can occur when you are driving "enthusiastically". The oil catch can routes the lines for the crank case vents and PCV to a catch can that contains a baffle to remove the oil from the air. The air is then vented back to the intake track.
Having too much oil in the car could also cause your problem as it's not a good thing to have too much, hence the Full mark on the dip stick. You could try to siphon some out if you truly are over, or just let it burn off if it's not too much extra.
Almost everyone I know has a little oil film in their intercooler and piping. As for the cats catching it. . .maybe, but then you really wouldn't want that since they could get clogged and cause more backpressure. It's normal for there to be oil in the intake track from oil blow-by, but not for it to be visible from the exhaust.
Calvin
cnk is offline   Reply With Quote
Old 05-19-2003, 01:44 PM   #7
buymeasti
Member#: 24091
I think I was 1-2 MM over the full mark on the dipstick, Im usually very careful about the oil levels except this last change I was too much in a rush to add, check, add, check if you know what I mean...
Im hoping a little too much oil and catless caused the smoke, altho I agree that nobody should see blue out the tailpipe. I know lots of turbo entusiasts that have blow by issues but like you said, never enough to see thru the tailpipe...
As for the cats, Im not suggesting that its a good thing but I was just wondering if a little blow-by is normal and just hidden by the cats (I was behind a fellow WRX with cats, he was pushing the same as me, has twice the miles, but no smoke).
Thanks for the suggestion on the catch can, maybe I'll look into it...although it seems like something that alleviates symptoms and not the problem overall.
I guess at this point there's enough oil in the IC to justify cleaning it...
Old 05-19-2003, 04:23 PM   #8
joeyvaz
Member#: 33300
2003 WRX
Midnight Black
I had a similar problem, except that the blue smoke was present at idle. Turned out to be a blown turbo, which I had replaced under warranty. Hope you have better luck than I did, but better that it happen now than after your warranty expires.
later,
Joe
joeyvaz is offline   Reply With Quote
Old 05-19-2003, 04:36 PM   #9
wrxs4me
Member#: 34011
2002 wrx
black
Depending on his dealer and whether he swaps his stock parts back on, his warranty may have already expired since he has an uppipe and catless turboback.
wrxs4me is offline   Reply With Quote
Old 05-19-2003, 05:14 PM   #10
buymeasti
Member#: 24091
later,
Joe
Thanks,
Im chalking this up to silgtly high levels of oil, which is now corrected. If the problem persists with "normal" oil levels then I'll pursue further tests.
Old 05-19-2003, 05:28 PM   #11
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Originally posted by buymeasti
Thanks,
Heheh... ironically... I get oil burn when I'm under light loads, and none at all under boost. Gotta love total seal rings.
They are such a pain to seat
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Car shakes violently when letting off gas at 5k rpms? Help... ImportVenom Transmission (AT/MT) & Driveline 9 10-21-2011 07:16 AM
Smoke out bov when let off gas????? EklipzGSXkid Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 23 08-05-2008 01:38 AM
blue smoke when idleing for a while!! rufracer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-30-2007 11:56 PM
Blue smoke when under boost Zuffy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-04-2007 11:37 PM
wierd noise when letting off acceleration, sounds like tranny is grinding or somethin ASpec818 Transmission (AT/MT) & Driveline 3 12-29-2003 10:23 PM
