Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Old 08-14-2003, 04:38 AM   #1
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Default Just finished installing Link Wire-in- HELP
For some reason my Laptop will not see the link. I have the key on and I verified the link was getting power.
I checked to make sure I had the correct com port and tried 2400 and 9600 baud
Any ideas? All wiring appears correct and it primes the fuel pump when I turn the key to on.
I also tried starting it and it did not start, I assume because there is no map on the link yet.
Drac9 is offline   Reply With Quote
Old 08-14-2003, 01:18 PM   #2
Drac9
Member#: 9861
Anyone?
Old 08-14-2003, 05:40 PM   #3
seven881
Member#: 8828
01 BRP 2.2T Hybrid
08 Tundra
The only thing I can say is try another laptop. I had problems with older ones and I coudn't get a signal through to the computer.
seven881 is offline   Reply With Quote
Old 08-14-2003, 06:35 PM   #4
Drac9
Member#: 9861
I'm gunna try another laptop and another serial cable tonight.
I'm not sure if my cable is a serial cable or not. It looks like a serial cable, but it might be pinned differently.
The requirements for it are just that it has power and the serial link is plugged in, right? It should see it if those are met? Am I missing anything else?
Old 08-14-2003, 08:26 PM   #5
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
what OS system are you running? on my laptop i had a serial port and was running windows xp and i couldnt connect, then i reinstalled windows 98 and it connected no problems, check and see if there are com port errors, or if you have something else trying to use that same port so they are conflicting, thats all i can think of.
Ben
PHATsuby is offline   Reply With Quote
Old 08-14-2003, 09:18 PM   #6
Drac9
Member#: 9861
It's windows 98. I do Microsoft Helpdesk for a living, so I'm fairly confident that everything is configured correctly on the laptop. Unforutnately I can't find my loopback plugs right now to test the port. This laptop only has windows 98 and the PClink software on it. Nothing else. Thanks for the suggestions though, keep them coming. Also, am I correct tha tthe link just needs power and ground to connect via serial link?
Old 08-15-2003, 12:33 AM   #7
DoctorNick
Member#: 7022
2001 Forester
Arcadia green
have you tried another serial cable? I know hndatch627 was having a problem connecting to my link because of his serial cable.
DoctorNick is offline   Reply With Quote
Old 08-15-2003, 01:23 AM   #8
Drac9
Member#: 9861
That's the plan for this weekend. If it still doesn't work I'll go from there. I was too tired after soldering 40+ wires last night and pushing the car out my driveway into a parking spot afterwards to screwwith it too much at 1am.
Old 08-15-2003, 12:48 PM   #9
Drac9
Member#: 9861
Checked the pins on my cable last night. I dont know what this cable is, but it's not a serial cable. I think it will work fine once i get a serial cable. Thanks guys.
It's just after 3am and I just finished installing the TiC rear diff race bushings prototypeWRX Texas Impreza Club Forum -- TXIC 14 02-02-2007 08:02 PM
Link LEMV4 Wire-in help ishmeal Subaru Conversions 0 09-17-2004 09:43 AM
Just finished installing indiglo gauges.. GregBolby General Forum Archive 0 04-03-2001 04:06 PM
I just finished installing my 6 speed trans and auto headlights/and washers ARG General Forum Archive 5 08-23-2000 08:32 PM
Just finished Installing My Whiteline BugBomb General Forum Archive 6 07-21-2000 12:12 PM
