Welcome to the North American Subaru Impreza Owners Club Monday January 21, 2019
Old 03-15-2011, 03:20 PM   #1
imprezaL2345
Member#: 108188
1993 Impreza L 1.8T
Lotus Storm Titanium
Default dunlop star spec tire pressure ?
Just ordered a set of 225/45-17 star specs, autox coming up on Sunday. What would you guys recommend I set the tire pressures to?
08 wrx, epic egr springs, ~1.3 neg camber, its going to be in the 50s
Before I was in stock class on re92s and bumped up the pressures to f40/r38, but for some reason I don't think ill need to go that high on these. I want more oversteer so rear pressure higher than front?
imprezaL2345 is offline   Reply With Quote
Old 03-15-2011, 04:58 PM   #2
Rez1138
Member#: 211569
03 WRX Wagon VF36
WRB Blobeye conversion
I had decent luck with running my star specs- exact size as yours too- around 36-38 in the front and about 44 in the rear to help with rotation. My car had terrible understeer and the higher rear psi made a difference for the better. I've done some other things to help the understeer so I may not run that high in the rear this season. I'll know more after the first event in 2 weeks.
Rez1138 is offline   Reply With Quote
Old 03-15-2011, 09:08 PM   #3
StXReX117
Member#: 193289
2003 Impreza WRX
MBP Stage 2
I would agree try 36-38 in front and in back try high pressure but if that doesn't work try dropping it way down to like 30 if needed repressiveness will be lost so it might not be the best idea.
StXReX117 is offline   Reply With Quote
Old 03-16-2011, 12:33 AM   #4
imprezaL2345
Member#: 108188
1993 Impreza L 1.8T
awesome, thanks for the input guys! any more opinions would be appreciated as well
north NJ.08 wrx rims & Dunlop star spec tires ChrisNJ69 Wheels/Tires 5 03-02-2011 11:17 PM
FS : 08 wrx wheels with new dunlop star spec tires ChrisNJ69 Tri-State Area Private Classifieds 7 11-15-2010 01:10 AM
FS/FT : 08 wrx wheels with dunlop star spec tires ChrisNJ69 Wheels/Tires 4 11-05-2010 12:00 PM
FS: Dunlop Direzza Z1 Star Spec Tires 4 x 235/40/18 alcoolaid VIC Private Classifieds 17 03-28-2009 08:35 AM
