Welcome to the North American Subaru Impreza Owners Club Saturday October 20, 2018
Old 09-30-2004, 02:15 AM   #151
SaabTuner
Member#: 67608
Oops, missed the oXygenates:
Oxygenates
Published octane values vary a lot because the rating conditions are
significantly different to standard conditions, for example the API Project
45 numbers used above for the hydrocarbons, reported in 1957, gave MTBE
blending RON as 148 and MON as 146, however that was partly based on the
lead response, whereas today we use MTBE in place of lead.
methanol 133 : 105 : 65 : 0.796 : 385
ethanol 129 : 102 : 78 : 0.794 : 365
iso propyl alcohol 118 : 98 : 82 : 0.790 : 399
methyl tertiary butyl ether 116 : 103 : 55 : 0.745 :
ethyl tertiary butyl ether 118 : 102 : 72 : 0.745 :
tertiary amyl methyl ether 111 : 98 : 86 : 0.776 :
There ya go.
Adrian~
SaabTuner is offline   Reply With Quote
Old 09-30-2004, 08:10 AM   #152
salisburyv
Member#: 41863
2015 STI
Crystal Black Silica
he said the torco race fuel concentrate has no toulene...not gasoline...
salisburyv is offline   Reply With Quote
Old 09-30-2004, 03:04 PM   #153
SaabTuner
Member#: 67608
"He also told me that Torco's race fuels don't contain any Toluene."
Torco doesn't just make "Accellerator" which is the octane booster, they also make various grades of race fuel. Some of which I'm sure contain Toluene and/or other Aromatics.
Adrian~
Old 09-30-2004, 08:18 PM   #154
pyrex
Member#: 45757
2005 WRX STi
CGM/Silver
I asked specifically if their racing gas contained Toluene. He told me that all Torco racing fuels contain no Toluene.
pyrex is offline   Reply With Quote
Old 10-11-2004, 06:33 PM   #155
casualsurfer
Member#: 60773
2004 WRX
No toulene? What about Xylene?
casualsurfer is offline   Reply With Quote
Old 06-01-2005, 01:31 PM   #156
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
For those mixing Toluene:
http://forums.nasioc.com/forums/showthread.php?t=780608
Interesting to see that the blending value of Toluene is right around 102-103, not 114 or 117 as often (even by me) quoted.
Jeff
PDXTuning is offline   Reply With Quote
Old 06-02-2005, 09:33 AM   #157
AntiochCali
Member#: 30185
2003 320 whp
on a heatbreaker dyno
Originally Posted by Kenneth2000
Just an update ...
I've now been using the Torco Unleaded version for 10,500 miles in my STi ...
It is still working great ... and I have yet to see one side affect ...
I will continue to use it on a daily basis.
http://www.need4speedpower.com/torco.html
Is your car tuned, or are you just adding it for safety factor?
If it is tuned to what Octane?
A real test would be to tune your car for 100 octane and continue to just add Torco to a tank of 91 - If it knocks, then you know you don't have 100.
What I really want is 94 so maybe I will tune my car for 94 and then add torco to a tank of 91 - if there is no knock I would be VERY happy.
AntiochCali is offline   Reply With Quote
Old 02-11-2006, 08:43 PM   #158
bcblues
Member#: 17256
18 Outback
on the road....
Revival.
bcblues is offline   Reply With Quote
Old 02-12-2006, 02:02 AM   #159
flycaster
Member#: 60142
2011 WRX
Grey
Well I'll be dipped in ....
Thanks for reposting that as I didn't catch it the first time around - that "fuel calculator" link is now in the trash.
flycaster is offline   Reply With Quote
Old 02-12-2006, 07:16 AM   #160
ka mano
Member#: 78022
PdxT built 2.5L 6sp
30R.82, 274/276, H2O+meth
Default nice tunes, very smooth!
Last summer I was running a stage IV rex with an 18g and got a set of UTEC maps from Mick and Tim at PdxTuning. Here are a couple of dyno plots with the only variable being the addition of Torco, 1 oz to 1 gal of 92.
The first plot is 92 + WI (100% H2O)... 21 psi, 11.8:1 AFR, 24 degrees of timing at redline:
ka mano is offline   Reply With Quote
Old 02-12-2006, 02:53 PM   #161
ka mano
Member#: 78022
PdxT built 2.5L 6sp
The next plot is 92 + WI + Torco... 21 psi, 11.8:1 AFR, 25 degrees of timing at redline:
With 1 oz of Torco added to 1 gal of 92, that's an increase of ~10 whp and ~11 ft. lbs. of wtq.
Old 02-12-2006, 03:45 PM   #162
TexRex2002
Member#: 36303
06 Evo IX
1 oz of torco??? like one shotglass full?
you mean 32 oz right? One can?
TexRex2002 is offline   Reply With Quote
Old 02-12-2006, 04:01 PM   #163
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Originally Posted by ka mano
...With 1 oz of Torco added to 1 gal of 92... .
...or 15 oz added to 15 gallons. Roughly half a bottle per tank.
Old 02-12-2006, 04:51 PM   #164
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
^^^ Could you have gotten more out of it, or was it a safe tune? Also, by running water injection, could this be altering the benefits you might see if you were just running the 1 oz torco / 1 gal 92 octane mix straight without the water injection? Just curious.
What would be the cons of running 1 gal of meth per tank of regular 93 octane gas? If bad for my fuel system, could I add one oz of klotz per gall of meth to alleviate that problem? Seems like the meth would be better than the torco...
I'm very interested in the torco if it will yield enough octane/power since it is more convenient than mixing fuels. However, if it's only going to yield 10whp, it's not worth my trouble - except maybe for precautionary reasons if I'm afraid of detonation (as opposed to making power).
SilverSurfer04STi is offline   Reply With Quote
Old 02-12-2006, 06:26 PM   #165
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Default quothe the race fuel, "Nevermore."
It was a safe tune. Notice I was using and tuning for half the recommended quantity of Torco. Next month my new 2.5L / GT30R.82 / stage 2 cams set-up will be tuned using 2 oz of Torco to 1 gal. of 92.
WI and Torco reduce detonation in different ways. Last summer we didn't tune for Torco without WI. WI alone had allowed for an increase of ~12 whp and ~12 ft lbs of wtq. Then on top of that, Torco added the points I noted above. I didn't spend the dough on maps I wasn't going to use, but if Torco's effect is specific to a particular band of temperatures like some other additives, then it would have some type of interaction with water. Each will have its own role to play, though, in a high performance situation.
Water injection fights det by cooling the cylinder walls, something tuners will try to accomplish otherwise by dumping extra fuel in to absorb heat. Water absorbs heat 7 times better than gasoline, significantly decreasing EGTs and/or allowing for a higher power tune.
Torco's not saying exactly what their product does, but it is intervening at a different level.
The octane of the fuel has to do with the mix of its hydrocarbons and the complexity of their molecular bonding. Higher octane fuels have more of the hydrocarbons that have the stronger primary C-H bonds able to withstand higher pressure and heat.
During combustion, unburned hydrocarbons with weaker C-H bonds are more likely to break down into gases that will ignite on their own accord under the increasing pressure from the piston's upstroke. The pressure waves from those unwanted ignitions not only are premature, retarding normal piston function, but they compete with the pressure wave created by the proper flame front and add to absolute cylinder pressure. Don't want that to come knock, knock, knocking on your combustion chamber door.
Additives like toulene actually increase octane while others like lead help conteract the effects of lower octanes. Water is just about lowering temps and doesn't otherwise interact with the pathways of molecular decomposition.
Old 02-12-2006, 08:07 PM   #166
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
Thanks for the info ka mano. So to answer my first question, you could definitely have gotten more power out of the tune, especially if you would have added 2 oz of torco for every 1 gallon of 92 octane fuel.
Can anybody answer my second question - that is:
After reading this thread in it's entirety, it sounds like adding methanol would be a "linear" increase in octane, so I could basically do a straight average. So, 14 gallons of 93 octane + 1 gallon of methanol (I've heard meth has an octane as high as 130) would yield me something like this: 14 * 93 + 130 = 1432 / 15 = ~95.5 octane. If this is correct, it actually sounds like torco would be more beneficial, unless I were to up the amount of methanol of course...
Old 02-13-2006, 03:15 AM   #167
SaabTuner
Member#: 67608
Actually, not that it matters, but that's subject to pretty intense debate. NASA has a lot of good, albeit old, evidence pointing to the source of detonation being locaed behind the advancing flamefront. This is a good example: http://naca.larc.nasa.gov/digidoc/re...ACA-TR-912.PDF
-Adrian
Old 02-13-2006, 03:58 AM   #168
ka mano
Member#: 78022
PdxT built 2.5L 6sp
You're right, I could have been clearer that not all auto-ignition needs to be 'premature.' 'Unburned' is really neutral to the postion of the flame front. The main point about octane is that higher octane fuels contain more of the hydrocarbons which are less likely to decompose and succumb to the unpredicted combustion that causes pressure spikes beyond tolerances, irregularities across cylinders, and the oscillations that come with erratic and competing pressure waves.
Thanks for the interesting article! You might like this one:
Wartime Report
Old 02-15-2006, 11:14 PM   #169
bcblues
Member#: 17256
18 Outback
on the road....
Well, I've ordered a 5 gallon jug, along with a couple bottles of GTA. So I will see first hand if the stuff works or not. If it doesn't, I wonder if it tastes like cheap tequilla?
Old 02-15-2006, 11:49 PM   #170
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Ways it [Torco] might work:
1. give you a smoother ride
2. give you a margin of safety against knock
3. give your tuner the chance to exploit that margin of safety with a more aggressive tune
I wouldn't expect much of a butt-dyno effect [from Torco] w/o being retuned.
Old 02-16-2006, 08:01 AM   #171
VetteVert
Member#: 5961
2005 STi
CGM
Coincidence or not, my old WRX ran 1mph greater trap speeds and got better gas mileage when running GTA. It is just a pain to put in...sticky as all get out.
VV
VetteVert is offline   Reply With Quote
Old 02-16-2006, 11:39 PM   #172
bcblues
Member#: 17256
18 Outback
on the road....
I plan to premix the GTA and Torco in one of these 1 liter bottles:
Old 02-17-2006, 04:41 PM   #173
keyser_soze
Member#: 57445
FYI for central texas people MZM Performance now stocks Torco just swing buy and pick some up! No more dispensing and you bring in a container and smelling like feul etc...these are sealed and ready to go
keyser_soze is offline   Reply With Quote
Old 02-25-2006, 05:28 PM   #174
jenner
Member#: 22905
2003 BMW M5
Sterling Grey
Guys I am a bit confused on how Torco and Toluene/Xylene work to make real power.
I understand they are able to up the octane rating several numbers(not points) but there is more to "race gas" than just high octane. Sure Torco and Toluene/Xylene added to regular gas will decrease knock by raising the octane number, but from what I know about race gas it's more than just octane rating which in this case octane = Antiknock Index (R+M)/2.
There is also RON (Research Octane) and MON (Motor Octane) as well as increased oxygen %.
Sunoco GT100 Race gas has a octane of 100, a RON of 105 and a MON of 95 for example. It also has 3.5% oxygen. The high oxygen content has a supercharging effect, since 3.5% oxygen is the equivalent to about 17% more air. Different fuels can actually alter horsepower 5-to-10 percent or more. Race gas will help make additional horsepower besides increasing the headroom for knock and allowing timing advances.
That said I understand how Toluene/Xylene raise the Antiknock Index (R+M)/2 in 20-30% mixtures which is usually several gallons.
What I don't understand is how only 32oz(0.25 gallons) added to 10 gallons of 93 octane can raise it to 104 octane. Think about it LOGICALLY how can a TINY little bit of ANYTHING raise 10 gallons of 93 to 10? It just doesn't compute. The octane rating alone would have to be somewhere around 500-550!!
I also think without the other contents that real race gas has in it, all it is doing is rasing the Antiknock Index (R+M)/2 and only providing some power by timing advances or allowing the boost to be turned up a bit. It doesn't provide the additional hp that true race gas adds.
I'd love to learn more about Torco, what octane rating it is and how it works because it would cut my Sunoco GTPlus(104 octane) race gas bill in half!
jenner is offline   Reply With Quote
Old 02-26-2006, 07:18 AM   #175
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
jenner, it is a chemical (mmt) which buffers the combustion process, just like tetraethyl lead in leaded gas. as a result the octane does not linearly scale when added to gasoline as it does when adding aromatics.
mmt DOES work to raise the octane significantly. if you can retune your engine to take advantage of that, you WILL make more power.
is it a true race gas? no... but it is damned close and FAR more conventient.
Torco race fuel concentrate dwaynesti Vancouver Impreza Club Forum -- VIC 0 06-29-2007 06:33 PM
FS: Half Case Torco Mach-1 Unleaded Race fuel concentrate godai Accessories & Misc 4 09-21-2006 09:54 AM
Torco Race Fuel Concentrate in Phx? AaronB South West Impreza Club Forum -- SWIC 25 04-18-2006 11:26 PM
Oil analysis after 3k of using Torco Race Fuel Concentrate The Deliverator Service & Maintenance 8 05-19-2005 12:51 PM
NY: 4.5 gallons of Torco Race Fuel Concentrate The Deliverator Private 'For Sale' Classifieds 2 09-13-2004 12:55 PM
