Welcome to the North American Subaru Impreza Owners Club Friday January 21, 2022
Old 09-07-2021, 10:54 AM   #1
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
Default Nuts and Bolts for Lift Spacers
I'm going to use lift spacers to raise my 09 FXT a bit on STI takeoffs. I think it's a bit too low and sags. Plan is to raise 1/4" in front and 3/4" in rear. I will also have strut/shock tower braces so I plan on using longer bolts to replace the tophat studs.
I know there are lift spacers offered that are threaded, some fancy enough where the HDPE is molded to have nuts pressed in. They are a bit pricey for me.
For those that use nuts and bolts to replace the tophat studs and use non-threaded lift spacers, is it not a pain in the butt? I'd imagine you would have to keep the bolts from falling out of the tophats as you install them to the chassis. And even when you can get nuts on the bolts, now you have to prevent the bolts from spinning as you tighten the nuts. Almost seems like a 2-man job especially for the rear.
Am I missing something? Or is this what I have to deal with if I get non-threaded lift spacers that are more economical? I'm currently looking into Paranoid Fabrications.
Here's a pic of my FXT and it's current ride height:
REX_WGN is offline   Reply With Quote
Old 09-09-2021, 06:42 PM   #2
thesmokingman
Member#: 17751
Nah, it's easy. Just drill out your spacer to accommodate the nut, ie. the three bolts. Use lock nuts obviously!
Doh, was gonna post some links but the deferrer is breaking them.
thesmokingman is offline   Reply With Quote
Old 09-09-2021, 08:52 PM   #3
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
Thanks, I figured as much. Thanks for confirming. Sometimes you overthink things. It seemed a little more obvious after a night's rest.
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
