Welcome to the North American Subaru Impreza Owners Club Friday January 28, 2022
Old 02-13-2006, 01:57 PM   #101
JoBoo
Member#: 23423
05 STi / 08 Dmax
IDP Racing Tech Monkey
Yeah thats what I would assume too. I havent put much thought into this yet, but perhaps there is some sort of non-linearity somewhere.
I guess I could set things up using the 0 deg holes and see what kind of camber I get. That would be a PITA. Im guessing it could just be the how Im measuring things, or I have a crappy camber gauge. Just checking to see what others are getting so I can narrow down what could be going on.
If others seem to be getting close to your calculations then Id say im the idiot and somethings amuck on my car or how im going about things.
JoBoo is offline   Reply With Quote
Old 02-13-2006, 02:18 PM   #102
makofoto
Member#: 25243
2006 Legacy Outback
Most people and even alignment shops are lucky to be with in 0.5 degrees of camber. You need to especially take your floor level into consideration.
makofoto is offline   Reply With Quote
Old 02-13-2006, 02:24 PM   #103
JoBoo
Member#: 23423
05 STi / 08 Dmax
Yeah, thats true. Havent measured it. I guess I was assuming that since its a poured concrete floor its pretty flat. Now that you mention it, Im not sure how good of an assumption that is.. Ill check it tonight.
Alignments for camber should be better than 0.5 degree for good alignment rack setups. camera based or Hunter ones can read +/- 0.1 so I imagine you should be good to 0.2 degree at the worst.
Old 02-13-2006, 02:28 PM   #104
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
I think what is nice about the charts is that they are a quick reference to a ballpark as to how much you are loosing vs gaining based on how exreme an angle you pick.
Mak - don't you have a smart camber gauge, or was that mundi. I'd like to pick one up and try it out this season, you could also use it in this situation.
crystalhelix is offline   Reply With Quote
Old 02-13-2006, 02:50 PM   #105
04_wrx_platinum
Member#: 40797
04 WRX
Platinum
Quick question- when you guys are modifying the plates- what are you using for the new studs?
04_wrx_platinum is offline   Reply With Quote
Old 02-13-2006, 03:45 PM   #106
JoBoo
Member#: 23423
05 STi / 08 Dmax
I just pressed them out, drilled new holes, and pressed them back in.
I used a 5/16 bit and it seems to work pretty well keeping enough interference to get a solid press fit. All these really need to do is stay in with enough metal behind the head so they dont pull through.
If with repetative insertions and removal, the stud gets loose, I think you could just epoxy them in there or worst case get a washer and it'll be fine. its not taking any tensile or compressive loads, its just holding the plate to the strut tower, and taking shear loads.
Old 02-13-2006, 11:16 PM   #107
abaxter34
Member#: 34723
fwd FTL!
ARP makes just about any fastener you could ever need, if you couldnt reuse the original ones.
abaxter34 is offline   Reply With Quote
Old 02-14-2006, 10:27 AM   #108
DMS North America
Member#: 50608
Grade 8 stainless bolts will be more than adequate. ARP is definatly a high quality part. You can also check out TRIDENT FASTNERS out of the UK.
I do not let a car go out of my shop with more than .1 degree camber varience from what the setup I am doing specifys.
.5 almost every driver I know (including my mother and girlfriend) feel that much difference. If your allignment shop can not do better than that, find a nother shop or ask them to recaliberate their machine / lift / setup.
-mark
DMS North America is offline   Reply With Quote
Old 02-14-2006, 12:28 PM   #109
JoBoo
Member#: 23423
05 STi / 08 Dmax
So I checked my floor, its really flat
so Im still wondering if others can verify CH's calculated numbers from actual alignments..
Old 03-09-2008, 11:00 PM   #110
Richard A.
Member#: 79
1999 2.5 RS
RBP
Thinking of making some custom plates and cannibalizing the bearing carrier from either my Cusco or Tein plates (long story) and stumbled across this thread.
Cusco and Tein both have a 15 space index range but the Cusco "O" is -10 to +5 and the Tein is -12 to +3. I think in pure camber adjustment each space is .2* but it's been along time and mine are rotated now.
In this configuration I'm still caster challenged but even with my camber bolt at full Positive I can get -3 or more, on unmodded plates. This is with my GC8 sitting at 13.125".
Richard A. is offline   Reply With Quote
Old 03-09-2008, 11:41 PM   #111
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
member #79 bringing a thread back from the depths..
Old 03-22-2008, 02:00 PM   #112
Mycues1982
Member#: 86995
2005 Tacoma
Great thread, I'd like to do this mod to my plates eventually. Damn I wish we had a Mill at work..
Mycues1982 is offline   Reply With Quote
Old 03-26-2008, 01:52 PM   #113
angryfist
Member#: 22760
#54 STR S2000
crazymonkeyracing
Since someone else brought this thread back...
I have a couple spare upper plates I made for the Teins when I had mine made. These are set back so you have added caster while giving you the normal camber adjustments so you can change from street to track/autox without effecting caster. They are pretty much a drop in replacement for Tein coilovers. Can be installed in about 15 minutes.
I'm clearing out my old parts now and am willing to just sell these below what it cost me to get them made. PM me for more info.
angryfist is offline   Reply With Quote
Old 03-26-2008, 09:26 PM   #114
68Cadillac
Member#: 95901
a while back I jacked up my stocker right wheels and right side camber plate when I drove over something heavy and concrete. My bad but at least I didn't wreck the car. I'll take two bent wheels and a camber plate over a bent coilover or body work any time.
Bought a used wheel off some guy. Need one more, but the least bent one's now on the rear. The shaking/shimmy has subsided significantly.
Bought some replacement camber plates off one of the local members of the Flat4. I had the slots elongated and the installation angle clocked to 55 degrees from stock. So now rather than camber plates, I have camber/castor plates. With these changes I get slightly less camber adjustment than before (-1.82 vs -2) but can now add up to 2.6 degrees of caster. "Ooooooo!", I hear you say. That castor should make up for the loss in camber.
I also had to clearance some areas on the ball joint base that I didn't anticipate would be a problem.
Here's some camber/caster plate pron:
68Cadillac is offline   Reply With Quote
Old 03-27-2008, 12:26 AM   #115
Darryn
Member#: 69370
2007 Legacy GT
I just read this entire thread, and realized that it has become more of a talk about modifying the cusco plates to gain caster than a talk of what plates are availalbe. PDE and Noltec/MRT are NOT the only plates available. In the lower price range Whiteline has plates availalbe, medium price range K-Max makes plates and in the high price range you can find HKS plates. And yes, those are all camber and caster adjustable. That said, I will mention that the Noltec/MRT and Cusco plates are both designs that sometimes warp. The PDE plates are the easiest to readjust over and over again, however, changing setting means toe, etc. is off and you should really re-align the car. The Noltec/MRT plates also have the issue of the bearing seaming to be more likely to fail then on other brands (or, maybe I was just unlucky with mine?). If I had to recommend what I though was the best design, regardless of price, Whiteline and HKS would get my recommendation. If you want to change your setting each time you autocross the car PDE is the best choice. If you want the cheapest, redrill the Cusco plates. By the way, while more caster does make the car feel quite great, I noticed that excessive adjustment through plates had a negative effect on bump-steer. So for those of you that are driving off-road or on rought roads, extra caster and more easily damaged than stock topmounts would not be a good choice for that application.
Darryn is offline   Reply With Quote
Old 03-27-2008, 12:45 AM   #116
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
A rarely discussed plate is the Eibach/SPC plate. It looks more like the Noltec comfort plates with a urethane insert to reduce NVH. I just bought a set, so I'll report back if they fail prematurely like the Noltec's were reported to do. It does have multiple bolting positions so you can angle the camber adjustment to gain caster at the same time, however, their range of adjustment in both dimensions is fairly limited.
Frank
Frank A is offline   Reply With Quote
Old 12-23-2008, 03:05 PM   #117
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
This is great stuff. I am just curious how to remove and replace the stud without denting/bending the plate. Knowing me, I would just use a vise and a BFH. Any other preferred methods?
S1MPSONS is offline   Reply With Quote
Old 12-23-2008, 03:12 PM   #118
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Super easy, big C clamp kind that threads, a socket and a flange type nut to put on the threads of the studs, use the C clamp to push the studs out, using the socket on the back to catch them.
Token-Negro is offline   Reply With Quote
Old 12-23-2008, 03:14 PM   #119
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
I get it now, thanks.
BRILLIANT!
Also found this post in the earlier pages and thought it was helpful info for hole sizing and machining techniques.
Originally Posted by mccanixx View Post
I think that would depend on the type of tire your running. R-compound or street, and the width. Wide r-compounds do not need as much camber.
If you look at mine, you'll see I picked a spot where if I went any further I'd start losing camber. I used the right on the left and the left on the right. With the plates off the car. I took an old aluminium street sign and marked the bolts, on the sign, by tapping it with a hammer. Drilled the sign so i had a template. Came to the conclusion the bolt holes needed to be rotated 3/4" from where they were. I pressed the old bolts out with a socket and vise, there splined just like a wheel stud. Found the appropriate bit, marked and drilled the plates. Pressed the studs back into there new holes. Put the plates back on the car and used a sharpie to mark the strut tower opening. I left it about a 1/16" away from the shock tower. I think I used an 1 1/2" or 1 1/4" hole saw, layed out and used a center punch and drilled the hole. Used a jig saw and a file to finish it off. I think I used a 1/4" drill for the allen head pinch bolts. Jig saw and file to finish off.
Reinstalled and marveld at my new found cambar and castor.
I use fairly narrow street tires, obviously STX.
Old 12-23-2008, 06:53 PM   #120
Butt Dyno
Street's closed, pizza boy
Member#: 17301
2016 FoST ST3
2006 Evo #17 STU
Much easier just to buy someone's already modded plates
Butt Dyno is offline   Reply With Quote
Old 12-23-2008, 08:46 PM   #121
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
know anyone with a set pre hacked for sale?
Old 02-11-2009, 09:20 AM   #122
swiftwrx1
Member#: 72352
06 E85 v-mount
wht/bronzse WFC#555
DOes anyone know if the Cusco REAR camber plates bolt up to Tien Flex for 06 STI?
thanks
swiftwrx1 is offline   Reply With Quote
Old 11-24-2021, 02:18 PM   #123
justint5387
Member#: 259697
2015 WRX
Sorry for bumping this thread, but is there a consensus on which camber plates give you the most negative camber?
justint5387 is offline   Reply With Quote
Old 11-24-2021, 02:49 PM   #124
yellowblur
Member#: 485903
2018 WRX w/PP
How much camber do you want? If its 2.5-3.0 with a VA, then I would think any of them would work. If you want serious autocross negative camber (more than 4.0) you might be able to get it with camber plates, the factory eccentric bolt and additional Whiteline or SPC camber bolts. If that doesn't work, then you would need custom camber plates. Competitive STH cars have 4+ degrees of negative camber.
yellowblur is online now   Reply With Quote
camber/castor plates and ride height abaxter34 Brakes, Steering & Suspension 20 04-08-2004 07:53 PM
camber/castor plates and toe Storm Racing Brakes, Steering & Suspension 6 04-06-2004 11:38 AM
Adjustable camber/castor plates schlong8 Brakes, Steering & Suspension 1 01-16-2004 09:03 AM
Help needed with MRT Camber/Castor plates trhoppe Brakes, Steering & Suspension 4 10-29-2002 04:53 PM
Just got my DMS camber/castor plates. Digital_Boy Brakes, Steering & Suspension 10 04-07-2001 05:56 PM
