Welcome to the North American Subaru Impreza Owners Club Tuesday July 14, 2020
Old 04-12-2020, 10:05 PM   #1
TuFnGood4U
Member#: 348705
2016 WRX
Dark Gray
Default IAG vs Killer B windage tray
I am going to be changing the oil pick up tube on my vehicle and I see there are a couple options for a replacement windage tray also. I am between the iag and killer b. I know they are both very reputable companies just wondering if anyone has had any negative issues with either. The iag has some rubber (Viton) flappers my concern is one coming out and clogging pickup. Any experience would be greatly appreciated.
TuFnGood4U is offline   Reply With Quote
Old 04-12-2020, 11:09 PM   #2
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
killerb it is then..
murrdogg24 is online now   Reply With Quote
Old 04-13-2020, 08:11 AM   #3
Jefe159
Member#: 486182
2011 STI
Gray
I think the IAG tray is pretty new. Killer B has been around for a long time and has a great reputation.
Jefe159 is offline   Reply With Quote
Old 04-13-2020, 10:05 AM   #4
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
We're here to answer any questions you may have
I can say from our testing many years ago... there is a reason why we don't use valves or elaborate baffles. A lot of this data was from a 3 Subaru team that ran 24hr endurance events on the Nürburgring logging sustained +1.6Gs around the carousel where they would have to 'let-off' to prevent oil pressure drops.
Some history on the valves that few know... They were developed by BMW for the M8. In that sump (that they were designed for) they were used on vertical baffle surfaces to keep oil at the sump pickup. The flappers never hung open or required replacement in this orientation. They only opened when loaded from one direction (are you reading between the lines here?). Prodrive was contracted by Subaru to support their WRC Rally efforts back in the 90s. They had issues with oil control on some of the WRC Northeaster European stages that contained LOTS for jumps; many in a row on some stages. So Prodrive modified an OEM pan and made a 'baffle plate' adding horizontal baffles with the BMW flapper valves installed. Under 0 Gs (as in going over a jump) the valves closed keeping oil in the sump. It also reduced aeration as far less oil sloshed back into the crankshaft. These valves were replaced as part of regular teardown and rebuilds (3-5 stages typically). Eventually (I think it was ~2011) Subaru and Prodrive ended their relationship. Cosworth picked up some of the track support, and in the process started marketing some of the racing products to more mainstream markets. This is where it gets messy, as you see other companies start to carry the same or similar products. Now RCM's has baffles that look like the Cosworth unit (originally Prodrive), and other companies have their own spin-off products.
Old 04-13-2020, 12:20 PM   #5
firebane
Member#: 508031
I think the key is a lot of stuff comes from the racing world and like you said these engines get tore down quite often.
When you take that out of the scenario and your just driving typical street cars just do what you need to ensure the health and longevity.
Don't think most of us are taking whoops on a daily basis and getting some sick air
firebane is offline   Reply With Quote
Old 04-14-2020, 03:22 PM   #6
fengrr
Member#: 169160
08 STI
Thanks for the info. I am planning on purchasing the killer B pickup and baffle soon.
I was thinking of waiting to do the oil pan at the later point, perhaps at the same time as an aftermarket oil cooler. Right now the car isn't seeing track use but I plan on autocrossing the car at least.
fengrr is offline   Reply With Quote
Old 04-13-2020, 12:34 PM   #7
Waddlz
Member#: 395275
2012 STi
I went with Killer-B oil pickup, pan and wind-age tray and I can say the fit and finish has been spectacular. Their oil pan is so sexy, its almost sad nobody is going to see it haha.
this is on my 2012 STi that is semi track/weekend road car making 460/460 on a rotated EFR 7163. I seen RCM and IAG have their own, but I was also concerned with the viton flaps. RCM has been very popular across the pond, but I like to support American businesses and Killer-B has answered all of my stupid questions about various EJ issues over the years with tact and professionalism, so I really appreciate them.
Waddlz is offline   Reply With Quote
Old 04-14-2020, 01:24 AM   #8
wrx43v3r
Member#: 331119
I'm aware of one key difference between KillerB and IAG. IAG won't get into this thread and spread there propaganda, and tell you why their product is better. KillerB will do just that. Search this forum and see how many times they've done it, and the squabbles they've had with another fabricator/vendor.
wrx43v3r is offline   Reply With Quote
Old 04-14-2020, 09:52 AM   #9
JarHarms
Member#: 138994
2006 WRX, 6MT, 5x114
TMIC, FP blue, ELH
Never felt that those rubber door baffles would provide a long service life. That was way back where there were only 1 or maybe 2 sources for the rubber door type. Most users are not doing frequent engine tear downs. I take service life into consideration as the solid part is a the conservative choice. Plus it has improvement over the OEM baffle. If one "needs" more oil sump control than these provide then they are serious users and likely looking into dry sump territiry.
"Propaganda" or not, the logic holds up. Not directing this at one person but more so a general thought. ALL of these companies have a motivation to sell parts. That is a basic function of a product company, followed up by marketing said products. And if you think that other company does not operate in similar manners...then good luck to you. I use parts from both companies based on their functionality.
JarHarms is offline   Reply With Quote
Old 04-19-2020, 09:33 AM   #10
Foo_Blyat
Member#: 93750
Lol. I'm pretty sure they search their own name a few times a day and make sure to post in every single thread that mentions KillerB. I liked them at first, bought two sets of pans, trays and pickups, but eventually just got sick of their tactics and prices. You'd think after having their 8 inches in the Subaru community for 15 years they'd finally pull a few out and give a price break but they just keep hammering away and come out with $500 AOS' .
Foo_Blyat is offline   Reply With Quote
Old 04-20-2020, 11:25 AM   #11
carlos.danger
Member#: 363268
2015 WRX STi
Please provide the link to your $250 AOS. I'll buy two.
carlos.danger is offline   Reply With Quote
Old 04-14-2020, 02:37 PM   #12
T-37
Member#: 175624
0304 WRX WRX
SY WRB
I've been using the Killer B tray and pickup (with a 2.5L oil pan) since 2013. Stock longblock EJ205, 280ish whp, it's been autoxed every summer since and sees the limiter frequently. The engine is still happy.
Old 04-14-2020, 06:22 PM   #13
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks for using our products!
Of course, that's why we're here. If you have any questions in the mean time, please don't hesitate to reach out to us.
With your application, I would hold off on an oil cooler. You'll loose some temperature with our pan alone. One of our shop cars at 760whp I used to auto-x regularly and never say temps near high enough to need an oil cooler. If anything, I'd spend extra time idling to make sure oil got up to temp. I do recommend an oil temp gauge as an important feedback tool for knowing when oil at ideal operating temperature. More often than not, oiling related issues are due to high load at low oil temp; takes ~2X as long to get oil up to temp compared to coolant.
Old 04-15-2020, 05:54 PM   #14
JSR84
Member#: 469585
I need to add an Oil temp sensor... I tend to watch my idle oil pressure to judge when the temperature is in the operating range. Not ideal, I know.
Regardless, another happy KillerB tray and pickup customer here.
JSR84 is offline   Reply With Quote
Old 04-16-2020, 07:33 PM   #15
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
It's not as accurate, but generally (assuming normal-ish build specs) your oil is at temperature when idle pressure is in the 20-30psi range?
Thank you sir!
Old 04-17-2020, 02:02 AM   #16
JSR84
Member#: 469585
Thank you sir!
Yeah 22ish psi at idle (10 40), it's an IAG build, I'm told the mains are a bit big. I pay good attention to my oil pressure so I can generally tell when it's cold warm or hot. Or even when AVCS has yet to activate after a reflash. But still, I should get a temperature sensor.
Old 04-17-2020, 01:29 PM   #17
Waddlz
Member#: 395275
2012 STi
my oil pressure gauge is not accurate at all.
I will see 13-15 psi at the front galley, and 60 psi above 3000 RPMs.
I hooked up a mechanical and got 30 psi idle, and 75 psi above 2500 RPMs
11mm oil pump, 15w-50 Mobil 1 2012 STi with built motor(Unknown clearances, I put it together myself without measuring anything)
Old 04-17-2020, 02:15 PM   #18
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
What gauge you have? With the electric gauges it's common for sensors to malfunction and wires to have a bad connection. But a mechanical gauge can fail also.
spoolinsti05 is offline   Reply With Quote
Old 04-17-2020, 02:29 PM   #19
Waddlz
Member#: 395275
2012 STi
Revel VLS.
I originally had a Defi but the sensor crapped out after 3 years and the sensor itself is $160 from Defi, so i wanted to try the Revel since it has a digital output.
My old Defi read 20 psi idle from the rear galley, 70 psi above 3000 RPMs. this is all warm oil pressure obviously.
I swapped the Revel to the front per Killer-B recommendation, but I'm likely just going to go back to my Defi since it actually read sort of close to what the mechanical does.
Old 04-18-2020, 01:20 AM   #20
TuFnGood4U
Member#: 348705
2016 WRX
Dark Gray
Went with the IAG pickup and Killer B tray. Spoke with my tuner and he advised away from the pickup as he has seen defects that would have caused engine failure.
Side note; make your own thread about your questions don’t jack others threads.
Old 04-18-2020, 03:36 AM   #21
fengrr
Member#: 169160
08 STI
Went with the IAG pickup and Killer B tray. Spoke with my tuner and he advised away from the pickup as he has seen defects that would have caused engine failure...
What defects exactly?
Old 04-18-2020, 03:48 AM   #22
TuFnGood4U
Member#: 348705
2016 WRX
Dark Gray
He didn’t give a specific but he has built a good amount of engines and is known nationwide and I trust his advise.
Old 04-18-2020, 03:50 AM   #23
fengrr
Member#: 169160
08 STI
Could you find out? Would be helpful if your tuner shared why. Also, who is your tuner?
Old 04-18-2020, 10:34 PM   #24
BlueSTI4Me
Member#: 34361
04.7 STI
WRB IG @got2boostit2
Without specifics as Judge Judy says hearsay, don't even mention it AT ALL. Moving on........
BlueSTI4Me is offline   Reply With Quote
Old 04-19-2020, 03:58 AM   #25
TuFnGood4U
Member#: 348705
2016 WRX
Dark Gray
If my tuner would like to discuss this with them that is on them. As I stated I trust their advise. He doesn’t seem to have brand loyalty. Take your own advise and move on.
