Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2020
Old 05-17-2020, 10:41 PM   #1
Turo310
Member#: 514157
Default 2011 sti
Hello nasioc I have an 2011 sti tuned with bolt ons nothing major but Anyone have an idea why car hesitates when I accelerate On any gear. When I hit boost car doesn’t go full power starts to sputter thanks in advance guys
Turo310 is offline   Reply With Quote
Old 05-17-2020, 11:50 PM   #2
Haevn
Member#: 495950
you check spark plugs?
Haevn is offline   Reply With Quote
Old 05-18-2020, 03:14 AM   #3
Turo310
Member#: 514157
I was hoping that could be it taking it to the shop this week, but wouldn’t I have problems with the vehicle to start?
Old 05-18-2020, 12:10 PM   #4
Jedi03
Member#: 491095
2009 STi Blue
not always...when they get worn the gap expands and its not noticeable until more air if flowing eg boost or wot...so it basically blows the spark out...also dont boost under 3k as that is basically lugging the engine and is very bad for an EJ motor...also (what happens to me once in a while lol) check couplers between the IC, turbo and block...my IC to TB likes to blow off at high pressure and driving till i can stop is similar if i hit the throttle to hard
Jedi03 is offline   Reply With Quote
Old 05-18-2020, 12:11 PM   #5
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
The first and easiest thing i would check is for boost/vacuum leaks. It sound more like a air leak if there is no cel.
BlackFighter is offline   Reply With Quote
Old 05-18-2020, 06:40 PM   #6
Haevn
Member#: 495950
when i had my tmic i had a leak at the coupler from tb to ic and it drove fine until you hit boost then it could cut off like your hitting fuel cut. all because of the coupler was not on all the way lol
Old 05-21-2020, 10:13 AM   #7
Turo310
Member#: 514157
Thanks guys im going to change the spark plugs and from there we’ll see 🙌🏽
Old 05-21-2020, 10:42 AM   #8
BlackFighter
Member#: 193940
2004 WRX STI Black
Im 99% sure its a boost leak. Spark plugs will not cause such a hesitation
Old 05-24-2020, 03:54 PM   #9
Turo310
Member#: 514157
How do I fix that sir?
Old 05-22-2020, 06:07 AM   #10
bp05obxt
Member#: 459799
Compression test
bp05obxt is offline   Reply With Quote
Old 05-25-2020, 10:22 AM   #11
BlackFighter
Member#: 193940
2004 WRX STI Black
I usually type up a whole story how to do thing to help people, sorry to be lazy but just read over these links and if you have any questions after your done and still need help, i can try to help. Do you know where your TMIC and turbo meet? Start there. Then making sure everything is tight and and has no holes. Just follow the the air getting sucked in to your intake filter all the way to the turbo.
https://mechanicbase.com/engine/boos...mptoms-causes/
If you don't want to use the way in the videos then just do a visual/audio test with your eyes and ears. First try to understand what a boost leak is first. After you understand what a boost leak and how it acts on your car, it will make sense and much easier to look for one.
Old 05-25-2020, 03:52 PM   #12
Blackfin
Member#: 361325
2010 STi
Dark Gray Metallic
One of the easiest things to check for sputtering/misfiring when you get into boost is the coils. Higher cylinder pressure under boost increases the voltage required to jump the gap in the cylinder. If your coils are damaged by corrosion (e.g.) and aren't able to produce that higher voltage, you'll get a misfire as boost builds. This happened to mine and the coil in question looked like this:
https://i.imgur.com/tPzC3M1.jpg
https://i.imgur.com/HLHUjOL.jpg
You may have some other issue but this is pretty easy "low hanging fruit" to check -- easier even than plugs.
Blackfin is offline   Reply With Quote
