Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2020
Old 02-21-2019, 10:09 AM   #401
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
Originally Posted by 2slofouru View Post
That would make sense only if the foofoo version remained in its original form, modding it to match the ID of the dom kit will obviously yield the same result.
Agreed.
Of course comparing before and after with without the mod could yield more information if several more data points are monitored. That could be helpful to people who want to know if the kit in general will do what they want.
That's why we're all here, right?
Obvious data we are looking for:
Each kits influence on the HVAC system.
Each kits influence on cylinder head temps.
Each kits influence on cylinder 4 EGTs.
Turpid Porpoise is offline   Reply With Quote
Old 02-21-2019, 07:44 PM   #402
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Originally Posted by Turpid Porpoise View Post
Agreed.
Some new Hondas have an interesting feature we techs can access (well maybe anyone can with the proper $$$ scanner). It's a cylinder air/fuel imbalance test and it detects an individual cylinder running leaner or richer than the others. It does this by leaning cylinders one at a time in several increments, to the point of almost missing. Then it judges and gives test results. If HONDA can do this, technically they (and other manufacturers) could actually tune the engine per cylinder to get pretty precise balanced air/fuel mixtures. They have half the equation figured out for sure, but I'm not sure whether an "auto" tuning feature that detailed is already in the software. Will ask next trip to training though. Surely other techs are wondering. This would make it way easier to keep cylinders even and mpg and power output would definitely improve.
So yeah, if Honda can do it, then so could Subaru or even aftermarket ecu companies. Haltech, where you at????
2slofouru is offline   Reply With Quote
Old 02-21-2019, 07:46 PM   #403
PDXREALTOR
Member#: 468393
2017 STI
That..... Is very cool.!
PDXREALTOR is offline   Reply With Quote
Old 02-21-2019, 07:51 PM   #404
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Exactly what I thought!! Like, why haven't they integrated this idea as an auto tune feature already??? (Unless they top secret already do, and won't tell anyone)
Just messaged the folks at Haltech. Probably won't get a reply, but who knows. Worth a try.
Old 02-22-2019, 03:05 PM   #405
1DaySTI
Member#: 422779
19 STI LIMITED
CBS
I spoke to a shop and I was told "Dom's kit works too good. You will loose heat at a red light" Not sure how true that is as I do not have the kit yet.
1DaySTI is offline   Reply With Quote
Old 02-22-2019, 03:13 PM   #406
PDXREALTOR
Member#: 468393
2017 STI
That indicates air in the system. There a couple solutions to get the last bit of air out.
I used my lisle funnel and combined a bit of info from the FSM. With the heat on high, fan on low, I very slowly reved up to 3k rpms and back (to idle). Before I stopped the bleeding process I made sure the heater worked on max temp, and hi/low fan settings at idle.
My heat is very hot in all situations.
Old 03-07-2019, 02:06 AM   #407
redrexmeister
Member#: 111692
Bergs,
do you have any thoughts as to what experiments from what was discussed above you might be able to run with your equipment and rough timing.
Not trying to rush or be inconsiderate but just would like to know what might be done to advance the case.
redrexmeister is offline   Reply With Quote
Old 03-07-2019, 07:13 AM   #408
bergs
Member#: 124376
No worries. Had a bit of travel last week and obviously didn't check in.
Test wise I agree with testing both kits, measuring HVAC and Cyl4 EGT. Curious if we are interested in Cyl2 EGT as well.
Also want to know where to attach thermocouples. My thoughts are to attach to each end of the head, one near the Cyl4 fitting and the other on the Cyl2 water jacket (in a similar location as the Cyl4 fitting).
Is there any interest in performing tests on Cyl1 and 3?
Timing wise, the car is nearly done. Figuring by the 15th it will be on the road then it's just a matter of getting through engine break-in.
Financially, I ask for help on anything beyond obtaining the kits. I am prepared to foot the bill for Dom's parts and DIY kit.
Also, Foo......I am looking for advisement on how to source the DIY fitting, etc.
bergs is offline   Reply With Quote
Old 03-07-2019, 09:07 PM   #409
nucci
Member#: 276121
I'm tearing down a running 06 STi that's been showing signs of pushing coolant, and it's looking like it was cylinder 4 that did it based on the crap in the exhaust port and cleaner spark plug. Thought this could be another data point.
It's going back together with Dom's kit installed, I've got better things to do than to try to beat the price on a $90 part with hours of my labor.
nucci is offline   Reply With Quote
Old 03-08-2019, 12:44 AM   #410
PDXREALTOR
Member#: 468393
2017 STI
Lol.
I had the same issue, but upon disassembly, I think my HG failed in between the two chambers (2/4) and it would only let loose on higher pressure pulls, 2 gear mainly. I was lifting heads for quite some time before I started blowing steam out of the pipes though. I think I was lucky.
Good luck with your build.
Old 03-08-2019, 03:20 PM   #411
dingobite
Member#: 82391
08 OBP Sti
Also about to use this part after tear down over head gasket issue going to see if the current shortblock can be saved there was alot of coolant and lead in my UOA which i read months afterwards.
The oil looked like clean oil im still not ready to test my bad luck that the bearings are ok.
dingobite is offline   Reply With Quote
Old 03-11-2019, 07:47 AM   #412
MaximNYC
Member#: 339591
2009 STI
Anyone has spare 21170AA020?
MaximNYC is offline   Reply With Quote
Old 03-11-2019, 05:55 PM   #413
bergs
Member#: 124376
Picked up the car today. Got some work to do on the driver's window then it's off to state safety inspection by the end of the week.
Once the car passes inspection, I will obtain the parts needed for testing then update again after break-in is complete.
I will be speaking with a colleague this week about the allowable temperature range for the test equipment. I believe it logs quite a bit of data and will plot a chart for each log.
Old 03-13-2019, 11:04 AM   #414
Foo_Blyat
Member#: 93750
This guy may have a few left https://www.toronto-subaru-club.com/...91#post1699291
Or do what he did and contact http://jp-carparts.com/
maybe even japanparts.com can get them too
Foo_Blyat is offline   Reply With Quote
Old 03-13-2019, 12:56 PM   #415
TheOtherAdrianG
Member#: 466686
I do!
TheOtherAdrianG is offline   Reply With Quote
Old 04-01-2019, 04:50 PM   #416
bergs
Member#: 124376
Chiming in to update and it's not all great news...
The engine has been broken in and all seems well however the car has a few issues that came up during break-in and I am working on sorting them out.
Will update again once things are sorted.
Old 04-02-2019, 06:01 PM   #417
lowbee
Member#: 254317
2011 STi
lowbee is offline   Reply With Quote
Old 04-16-2019, 02:16 AM   #418
lowbee
Member#: 254317
2011 STi
Would someone installed the DIY kit report how it is working ? Does your heater still provide as much heat to the cabin as before ? TIA
Old 04-16-2019, 11:51 AM   #419
JSR84
Member#: 469585
I took HVAC temperature readings before and after installing Dom's kit using an infrared thermometer taking readings off the center vents. This was done with the engine at idle and the coolant between 185 and 190 after running the fans on high for 2 minutes. I did this 3 days in a row for both pre and post install. I found an 8 degree reduction on average which works to about 5%. More importantly I didn't "feel" any difference in the operation of the system.
I wouldn't call these numbers 100% accurate... There were still a few variable that could have affected the results.
JSR84 is offline   Reply With Quote
Old 04-16-2019, 03:06 PM   #420
dingobite
Member#: 82391
08 OBP Sti
I didnt feel a difference i commute home at 5am when its around 40 degrees or lower bundled in UA thermal underwear i always need some type of heat going for my nose, nasal passage just leak 24/7 even worse in the cold air.
Cabin is usually toasty if i want it that way before i get home on my 20 minute drive home.
I did notice the coolant temp hovers around 181 more often normal would be 188-191 in my 11 year old subaru.
Old 04-16-2019, 03:52 PM   #421
lowbee
Member#: 254317
2011 STi
Originally Posted by dingobite View Post
I didnt feel a difference i commute home at 5am when its around 40 degrees......
And you are using the straight up DIY (not DOM $80) kit without restrictor ?
Old 04-17-2019, 02:07 AM   #422
dingobite
Member#: 82391
08 OBP Sti
Dom kit I didn't see all the diy talk til a day after I ordered from Dom.
Old 05-08-2019, 08:24 PM   #423
AndrewD5418
Member#: 366602
Your coolant is still pretty hot. This just allows more flow through the head. It shouldn't really effect the temperature a whole lot going into the heater core.
BTW, I made my own kit using AN fittings, silicone hose, aluminum t. I'm willing to bet it'll do the same difference as a dom or "OEM" kit. If I lose heat I'll simply throw on an OEM fitting.
AndrewD5418 is offline   Reply With Quote
Old 05-10-2019, 04:58 PM   #424
AndrewD5418
Member#: 366602
Just took it for a drive. Heat blows just as hot. I also did notice my temp tends to be just a tad, tad, tad, lower. Not much though. Not even noticeable unless you drive the car every day.
This was with AN fittings engine side, and the same type of T fitting in the kit.
Old 05-28-2019, 11:43 AM   #425
bergs
Member#: 124376
Following up with my earlier offer to perform some testing....
I am unable to participate in data collection for the foreseeable future as I have some personal things that came up. My apologies to the group for no following through on my offer.
