Welcome to the North American Subaru Impreza Owners Club Monday December 2, 2024
Old 03-18-2010, 04:35 PM   #1
japspecjohn
Member#: 222993
2017 WRX
Dgm
Default I just put 04 Sti take offs on my 03 wrx...now theres a vibration at highway speeds?
Hey
Just put 04 Sti suspension on my 03 wrx....I did the fronts a week ago. Drove around it was fine.... did the rears yesterday drove home and there seems to be some vibration now. (seems constant some times and random other times at highway speeds 60ish I cant tell if its coming from front or back its wierd) I noticed it first when I got on the highway. The suspension it self is much firmer and handling is night and day. I can really feel every bump in the road...but could the vibration be due to an alignment being needed? I mean its only 10mm drop but I planned I getting an alignment still but Im waiting on my RCE Lowering Camber plates for the front first (should have them on probably this weekend)... This is my first subie so I didnt know if its a little more sensitive to suspension changes with an awd compared to a Fwd.
thanks
japspecjohn is offline   Reply With Quote
Old 03-18-2010, 04:48 PM   #2
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
get an alignment, yes.
then we might be able to help.
wcbjr is offline   Reply With Quote
Old 03-18-2010, 05:50 PM   #3
japspecjohn
Member#: 222993
2017 WRX
Dgm
k hopefully next week...its strange some roads it does it some it doesnt more around 60-65mph....low sound almost drone like
Old 03-18-2010, 06:47 PM   #4
JDwhiteWRX
Member#: 190502
Are your wheels on the same side they were before the swap?
JDwhiteWRX is offline   Reply With Quote
Old 03-18-2010, 08:22 PM   #5
japspecjohn
Member#: 222993
2017 WRX
Dgm
sure are
Old 03-19-2010, 08:15 PM   #6
japspecjohn
Member#: 222993
2017 WRX
Dgm
any other input or should i come back after the alignment?
Old 03-19-2010, 11:53 PM   #7
JDwhiteWRX
Member#: 190502
Your toe will be out but not by too much, I'm not sure it would be enough to cause vibration anyway. You need to make sure everything was installed correctly, conical washer facing the right way up etc. if things are not installed correct then the alignment wont fix anything and you will have to pay for another one after fixing any install issues.
Old 03-20-2010, 07:35 AM   #8
japspecjohn
Member#: 222993
2017 WRX
Dgm
The vibration started after I put the rears on....I had the fronts on for almost a week before I had time to do the rears....and its not constant...idk maybe its the crappy roads combined with crappy sumitomo tires and stiff susp.
will d2 coilovers fit on my 03 wrx if there off a 00 gc8 allwheeldude Brakes, Steering & Suspension 0 02-27-2009 08:46 PM
Can I put an STi cat-back on my 06 WRX? LXguy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 07-27-2007 06:20 PM
04 sti brembo bolt on into 03 wrx? SICK03SONIK Brakes, Steering & Suspension 2 02-16-2007 06:19 PM
Brake Gurus!How do I put 04 sti rear brembos on my 02. turbokonejo Brakes, Steering & Suspension 2 03-26-2006 07:23 PM
