Welcome to the North American Subaru Impreza Owners Club Monday December 2, 2024
Old 08-06-2024, 04:09 AM   #1
hedron
Member#: 535911
2011 Impreza 2.5l Pr
Default sporadic tire pressure light
I've been getting sporadic TMPS sensor light all summer long. The first time it happened I immediatedly filled the tires, but they were already set. I set the pressure at 35psi for all tires.
My going theory is that the heat messes with the sensor, but IDK how the sensor actually works so that's why I'm asking.
Also, thought this might just be a quirk with the car itself? But I doubt it.
Do I really need to unseat the tire to check the sensors? That's what i'm reading in other threads.
Some video said it could be one of the sensors needs its battery changed. I have no idea when or if the battery was ever replaced.
hedron is offline   Reply With Quote
Old 08-07-2024, 07:44 AM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
This should really be in "tire and wheel" section.
A tire shop can tell you which sensor is an issue and likely what the issue is. This is with a scanner with the wheel still on the car (for most sensors.)
Yes, some sensors have replaceable batteries. Lots of short trips kill them faster than lots of long trips. The reason for this is when you first start a trip, the car pings the sensors a lot, later they ping them once in a while. Short trips means less time in big lapses of pings.
Yes, to change a battery requires you to pull the wheel, then dismount the tire.
Charlie-III is online now   Reply With Quote
Old 09-16-2024, 10:48 AM   #3
Odie Kessler
Member#: 539098
High temperatures can affect the sensor, causing the tire pressure to suddenly increase or decrease and activate the warning light. Another possible cause is that the sensor battery is low, and replacing the battery often involves removing the tire. You can try checking the sensor with a diagnostic tool without removing the tire. If the problem persists, taking the vehicle to a professional repair facility to have the TPMS sensor tested and repaired may be the best solution.
Odie Kessler is offline   Reply With Quote
Old 09-30-2024, 12:56 AM   #4
Calebmontoya
Member#: 539226
Default Solve
If you find the solution to this problem let me know.
Calebmontoya is offline   Reply With Quote
Old 09-30-2024, 10:17 AM   #5
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Yes, it would be good for everyone to know what happened instead of a dead end thread.
Old 10-21-2024, 06:33 PM   #6
ReinaldDegarmo
Member#: 539388
La plate-forme de Casino Lucky31 est disponible dans une superbe édition mobile, qui permet aux joueurs de profiter de leurs jeux et bonus préférés, où qu'ils se trouvent et quel que soit l'appareil qu'ils utilisent. Étant donné que la version mobile a été optimisée pour les appareils iOS et Android, il n'y a aucune différence dans la qualité de l'expérience de jeu entre la version mobile et la version de bureau. De plus, la version mobile permet de basculer très facilement entre différents jeux et bonus*https://lucky31casino.org/ en seulement quelques clics de souris. Parce que le jeu peut être joué sur un appareil portable, c'est maintenant faisable. De plus, toutes les informations de votre compte et vos transactions financières sont stockées en toute sécurité dans le cloud, ce qui signifie qu'il n'y a aucune possibilité de perdre des données pendant que vous jouez. Cela garantit que vous aurez toujours accès aux données que vous avez stockées. Il existe une version mobile du Casino Lucky31 qui vous permet de jouer à tous vos jeux de casino préférés, que vous soyez à la maison ou en vacances.
ReinaldDegarmo is offline   Reply With Quote
Old 10-22-2024, 03:01 AM   #7
hedron
Member#: 535911
Well, I still have the sporatic TMPS light coming on, so there is no solution(aside replacement,but I haven't done than so I can't say that's a solution.) I guess from these responses I am not alone in this issue. By November I should at least know whether it's the heat or not, it's been unseasonably warm up here north of Albany, so I'm not ready to say that it's definitely the weather.
